Wheel spacer ?
Old Dec 1, 2007 | 10:30 PM
Mikegpr03's Avatar
C63
Wheel spacer ?
Hey guys Im going to lower the car and I was wondering if any body lowered the car and added wheel spacers too...if you have pics please post and size mm?
Old Dec 1, 2007 | 10:35 PM
moosejaw's Avatar
none
Hey Mike
My c32 is lowered and i had to add 5mm spacers to prevent the wheels from rubbing against the strut when I turned left. However make sure they are hubcentric. My spacers made my steering wheel shake at 60 mph. It made the one wheel that is a little bent drive worse. I purchased spacers that said they were hubcentric but I dont think so. I'm going to let A rim shop check them out
Old Dec 2, 2007 | 11:59 AM
Zeppelin's Avatar
C32
If you are lowering the car with just springs then you will not need spacers no matter how low you go. If you are installing coilovers then you may need a spacer in the front to clear the strut.
Old Dec 2, 2007 | 04:16 PM
moosejaw's Avatar
none
I think I have stock struts and they wererubbing when I turned left. Looking under the car. The strut was mm away from the rim. I needed spacers bad
Old Dec 2, 2007 | 04:20 PM
sdsilverm3's Avatar
Your signature says you have the H&R cup kit which would imply you have aftermarket shocks which do not have the indentation on the shock body for extra clearance hence the need for spacers.
Old Dec 2, 2007 | 05:00 PM
ohlord's Avatar
Best
to get the right et rim in the first place,proper offset insures no need for spacers and on our autocross car the tech's will not even pass the car on inspection with wheel spacers.Safety issues .
Old Dec 2, 2007 | 05:40 PM
Mikegpr03's Avatar
C63
I actually want them on to push the whel a bit out for looks.
Old Dec 2, 2007 | 09:23 PM
dkflipse's Avatar
C32 AMG
Note: if you go 19" you won't want to push anything out!
Old Dec 2, 2007 | 09:29 PM
Mikegpr03's Avatar
C63
i already have 19's I still want to push them out more. I want them right up to the fender. I have a friend who did this to his 06 m3 on 19"s and the car looks sick!
Old Dec 2, 2007 | 09:34 PM
Mikegpr03's Avatar
C63
I have lm6 reps
Old Dec 2, 2007 | 09:42 PM
moosejaw's Avatar
none
No I have the indentation on the struts, so it must be stock, therefore I need to change my sig. I was told by the previous owner the car had the cup kit. Thanks for clarifying
Old Dec 2, 2007 | 10:47 PM
rlee02135's Avatar
2004 C32 ///AMG
if the shocks are silver, you have the cupkit.
Old Dec 3, 2007 | 12:26 AM
ohlord's Avatar
pushing the rims
out for looks puts a real strain on the wheel bearings and plays havoc with proper alignment .Get the correct rim width and ET and then you wont need the spacers and the suspension will like you for it
