donk donk donk...
Old Apr 10, 2008 | 01:04 PM
pointman's Avatar
a car that can't do the throttle reset.
donk donk donk...
I can't replicate it on demand. But sometimes stopped at a light (only happens when completely stopped), several seconds after stopping I hear a "donk donk donk".. happens in fairly rapid succession and sounds to be coming from underneath the car, middle or rear of car. Tried to record it, but like I said, impossible for me to force it to happen. And its fairly subtle. Never happened before. I know the dealer is gonna say they can't replicate. So I am hoping someone else has had this phantom noise occur prior.
04 c32.
Old Apr 10, 2008 | 01:07 PM
silence's Avatar
sounds like airplane
http://images.google.com/images?hl=e...-8&sa=N&tab=wi
sorry i couldn't be of more help
Old Apr 10, 2008 | 02:02 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
04 c32.
Only thing I can think of, that I've noticed before in certain cars, is gas sloshing around in the tank if you stop fairly aggressively... but that's not exactly a "donk" sound...
Old Apr 10, 2008 | 07:32 PM
fivepointfivev8's Avatar
C55
next time you come to a stop, shift the car in Neutral jus tas you roll to a complete stop to rule out something in the transmission. I had an old piece of ***** Dodge that did that and it turned out being the tranny.
Old Apr 11, 2008 | 12:37 PM
pointman's Avatar
Hi. Its definitely not the case. I thought about it too.
Old Apr 11, 2008 | 12:38 PM
pointman's Avatar
****. I was afraid to hear this. Thanks. I will try it.
Old Apr 11, 2008 | 01:26 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
my parents 96 XJ-12 does this. comes from the tranmission tunnel. probably a tranny mount is bad?
Old Apr 11, 2008 | 01:50 PM
loudandheard's Avatar
C32/C55 AMG
I'm not sure that you're having a clunking problem in the rear of your car, but I was having that clunking issue. My service advisor told me that there is a common problem with the w203 chassis and when the shocks in the rear start to go bad a part starts to warp and it causes that clunking issue. I was only havign the problem during acceleration and when I was braking. Hope this helps.
Old Apr 13, 2008 | 11:00 AM
pointman's Avatar
Thanks guys. When I get some time, I am gonna drop it by the dealer and see what they come up with. Hopefully I have some helpful info to share with you all.
