carbon fiber Driveshaft
Old Aug 2, 2008 | 09:00 AM
  #101
Newzchspy's Avatar
PLAID
Originally Posted by otoupalik
The manufacturer is supposed to come over this week to inspect and start the process!
Any more updates since 07/07/08 Been almost a month now???
Old Aug 4, 2008 | 03:09 AM
  #102
mb_c55amg_guy's Avatar
2005 c55amg, 2000 clk430, 2002 clk55amg, 2008 clk63amg black series
i would like to know as well.
Old Aug 4, 2008 | 12:42 PM
  #103
otoupalik's Avatar
MBWorld Founder
Yes, our manufacturer finally did come over last week. They examined a CLK63 BS and are starting the process of CNC'ing the flanges. The CF shaft itself is the easy part.
They do have one difficulty in the rear of the shaft with the way it connects to the diff, so they are working on that with the engineers.
Once they solve this, we will be good to go for these cars:
  • C32
  • C55
  • C63
  • CLK63/CLK63 BS
  • E55/CLS55
  • E63/CLS63
Brad
Old Aug 4, 2008 | 02:15 PM
  #104
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
  • C32
  • C55
  • C63
  • CLK63/CLK63 BS
  • E55/CLS55
  • E63/CLS63
Brad
What about the "old school" guys? The 202 &210 guys ?
Old Aug 4, 2008 | 02:19 PM
  #105
otoupalik's Avatar
MBWorld Founder
Just need to have customers who want to buy them.
thanks
brad
Old Aug 4, 2008 | 02:43 PM
  #106
C43AMG's Avatar
Veteran: Army
thanks
brad
How many ?
Old Aug 4, 2008 | 03:46 PM
  #107
Newzchspy's Avatar
PLAID
How many ?
What's the estimated cost of these for a C32??? Any "close idea?"
Old Aug 5, 2008 | 01:00 PM
  #108
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
I am still in for one of these
Old Aug 5, 2008 | 01:40 PM
  #109
bobby02c32AMG's Avatar
2002 C32 AMG
I would like to know the "ball-park" price of on of these for a c32 too?? Looks and sounds pretty nice tho and will def free up some of that lost HP!
Old Aug 7, 2008 | 01:56 PM
  #110
blackbenzz's Avatar
haters crazy
So nothing for a W208 CLK55? What is the ETA on these things anyway?
Old Aug 7, 2008 | 02:39 PM
  #111
racetested's Avatar
08 MB
I thought you guys may find this article informative mentioning strength, hp gains, etc..
http://www.americanchemistry.com/s_p...=1080&DID=6583
Old Aug 7, 2008 | 03:30 PM
  #112
SilverBulletAMG's Avatar
C32 AMG
Sounds like with a group buy these should sell for LESS than $1500, right?
$1200 group buy with 10 or more would be a pretty sweet deal I'd jump on. How about it otoupalik? You have some 32 boys ready to jump.
Old Aug 7, 2008 | 03:44 PM
  #113
otoupalik's Avatar
MBWorld Founder
Some updates.
How many ?
Well, it looks like we may be able to manufacture the front and rear flanges and C/V joints to fit any modern MBZ. The length of the shaft will be the difference. So, assuming I have accurate measurements from a customer or local car, I can make it for you.
$1200-1500 - still waiting to find out exactly. The additional cost may be due to the rear C/V that they are having to make may add a few bucks. The original manufacturer of the rear C/V's that ACPT uses (who is in Germany, and OE's this piece for BMW/Mercedes, etc) stopped making them.
See above.
See above I don't think it will be a problem. I know you would appreciate it for sure!
ETA is realistically 3 months. We can do it quicker by taking your stock shaft and cutting off the flanges and mating them to a CF shaft. However, ACPT does not recommend this for a number of reasons. However, it is a fall back plan.
No group buy needed. We will sell these as low as we can.
I am excited as I think it will be a great part for most Mercedes!
thanks
Brad
Old Aug 7, 2008 | 04:39 PM
  #114
hooleyboy's Avatar
C55,SL55,C63
3 months works for me. thats should be plenty of time to scratch together the loot and convince the lady that i need this.
Old Aug 7, 2008 | 05:18 PM
  #115
pshek's Avatar
2003 C-Class Sportcoupe
Rear C/V? As in Constant Velocity joint? Having a CV joint at the rear of the driveshaft doesn't make sense to me. Just wanted some clarification because I didn't understand. Do you mean a U joint? Our OEM driveshafts have a U joint(1) in the middle of the shaft connecting front and rear pieces. The stock end pieces(3) are just prop flanges with no U joint.
The last time I called ACPT they said they usually make them 1 piece.
Old Aug 7, 2008 | 05:25 PM
  #116
otoupalik's Avatar
MBWorld Founder
The CF shafts are one piece without any U-joint. The rear of the shaft has to have a joint/flange. The CF DS people call it a CV joint, so is it the same as traditional C/V joints - dunno. I just know that it has it and they need it! lol
Here are pics of the one for my M3:
Refer to the second to last picture to see what I am talking about above.
Brad
Old Aug 7, 2008 | 05:47 PM
  #117
pshek's Avatar
That makes sense. I was thinking of the type of CV joint at the axle half shafts. The CF drive shaft should have a joint. They must have chosen that type of joint over a U joint for a good reason though....
Edit...
The rear of your M3 driveshaft has a solid disc and the front has a rubber flex disc. Would we have the same type of end pieces as the M3 pictured? Rubber flex disc (OEM type) in front and C/V joint + solid disc in rear?
Old Aug 7, 2008 | 06:05 PM
  #118
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
CVs, at least some types, allow the shaft to move in and out as distances change between the transmission and the diff. Standard u-joint drive shafts have splined connections for the same purpose. They're there because transmission output shaft and differential pinion bearings don't like axial loads.
Old Aug 12, 2008 | 02:36 AM
  #119
Rouven036's Avatar
Cars with Stars
@otoupalik: is it also possible to produce such a cf ds for a w124 e500?
Old Aug 12, 2008 | 01:48 PM
  #120
otoupalik's Avatar
MBWorld Founder
I believe so, but will know more once they are closer to production. thanks!
Brad
Old Sep 7, 2008 | 01:45 PM
  #121
hooleyboy's Avatar
C55,SL55,C63
How is the development coming? any updates?
Old Sep 7, 2008 | 02:21 PM
  #122
I am in...
If it is made for the c55 i am so in.
Old Sep 7, 2008 | 10:08 PM
  #123
more151please's Avatar
2007 E550, 2011 BMW 335i
i think i would be in also, i just may not be one of the first. Sounds great so far though.
Old Sep 11, 2008 | 01:11 PM
  #124
otoupalik's Avatar
MBWorld Founder
The proper CV joints we spec'ed out will be here the end of the month.
Brad
Old Sep 11, 2008 | 02:01 PM
  #125
hooleyboy's Avatar
C55,SL55,C63
thanks for the update. are we looking at a October/November release?
