Modifiying my C32
2004 C32K
Modifiying my C32
Hi all, im from south africa and i drive a 2004 C32, i am currently in the process of ordering a few parts from LET motorsport,ie heat exchanger,phenolic spacers,181 pulley kit, johnson CM30 coolant pump and intake kit.
For the moment all i've done is remove the cats, i am really excited about modding the car as from what ive read in this forum that these parts really make a huge difference.
The car has been run on 2 dynos and has made 330rwhp.
Can anyone please give me some sort of idea as to how much more power i can expect?
Has anyone done all of what i am going to do to my car?
Thanks guys... this is a really informative forum, will be eagerly awaiting a response.
Super Moderator Alumni
I hate to say it, but for now you expect 0 hp increase. This is because LET has suspended all hardware shipments for the time being while they relocate their facilities.
When did you order the equipment? I thought the website was not allowing orders, except for the ECU tunes.
2004 C32K
I am in the process of ordering these parts, a tuning shop is ordering these parts for me via Jerry.
I believe that all that i need is in stock except the johnson pump, hope we get a response soon that the parts are in stock so i can order all of them together, im also really bummed at the fact that there are no 185mm pullies in stock, guess i'll just have to settle for the 181mm.
There are little to no C32's from where i come from, so nobody here can tell me much about modifying it.
Hope i get to place my order soon...
MegaMerc - you are in good hand going with the LET package.
I recommend you go back to the dyno shop. 330 rwhp for a stock car is not a normal figure; that's 50 hp crank over factory.
Post the graph if you have it.
330 rwhp stock
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
I had less with ASP 178MM crank pulley and tune....
2004 C32K
i dont have the graph, but maybe our dynos may read differently as opposed to yours over on that side of the world, could also be that we have a much higher octane fuel.
remember guys im only asking for advice on how much of a difference these mods can make on my car, and im not ruling out the fact that my dyno reading maybe incorrect.
So can anyone help me with my original question about the power readings and obsevations after the mods???
1) Your new dyno graph (with all the listed mods) will yield a bogus 370/380 rwhp. Making you the fastest C32 with a pulley/intake and no tune.
or,
2) Your new dyno graph (with all the listed mods) will yield a 320-330 rwhp considering your pull was done right this time...
In conclusion, you can get 40-50 crank Hp.
2004 C32K
Ok, based on your original data, you are going to encounter two scenarios:
or,
or,
2004 C32K
2004 C32K
and one more question... i've now learned that there are no johnson pumps in stock, with this part missing from my list, will this affect my performance even though i have a near brand new stock pump?
See this:
https://mbworld.org/forums/showpost....0&postcount=27
95, 93, 91, 2000019191919 octane it does not matter
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
Hmmmm so it makes 349 HP at the crank stock, add in the Nigeria scam factor, that adds at least 50 rwhp. I see so your car makes about 399 at the crank and about 330 at the wheels......
03 g35 coupe...........02 c32 Sold
It isn't a direct conversion since Europe goes by RON's and the US goes by something in between.
What kind of dyno did you use?
If the guy used a dynapak, then his number can be legit since a dynapak reads around 12-15% higher then a dynojet.
If you take 12-15% away from 330whp its close to 280whp on a dynojet, which is within the realm of what everyone else dyno'ed.
2008 A8L, 2002 996TT X50, 2009 X5
Could it be PS instead of HP?
Either way, you don't have a stock car like you think, or the dyno was mis-calibrated. 285ish rwhp, give or take a little, is pretty common for stock. I have almost the exact mods you're looking for (181mm pulley, cooling mods, no intake but headers + ECU tune) and my dyno looked like this:
https://mbworld.org/forums/c32-amg-c55-amg-w203/260384-let-stage-2-181mm-dyno-results.html
FWIW, this was on 93 octane. Good luck with your mods.
2004 C32K
i am willing to except that my dyno reading is wrong
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
but will run it again and see what figure i get...
2004 C32K
can anyone tell me, if the difference between the 181mm pulley in comparison to the 185mm pulley.![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Without the johnson cm30 pump, will my stock pump work with the let heat exchanger?
Yes, your stock pump will work with any aftermarket heat exchanger... it just may not be as effective as HE + CM30 pump.
FYI, it may be of interest to you that LET has posted that effective immediately they are no longer offering hardware for the C32 - did you read the link Scott posted above?
2004 C32K
FYI, it may be of interest to you that LET has posted that effective immediately they are no longer offering hardware for the C32 - did you read the link Scott posted above?[/QUOTE]
yes i have read the post... just getting my info so that i know what im doing...
thanks for all the help, really appreciate it...
2002 C32 1987 190E 2.3 334K miles and going
Time to check out Code3 Performance.
good Luck!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
