C32 Rear Wheel Size?
Old Nov 3, 2008 | 07:31 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Is it a 17" and if so how wide is it and what's the bolt pattern?
Old Nov 3, 2008 | 08:29 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Here's your specs for the C32 rear:
17 X 8.5
5 x 112mm bolt pattern
ET34 offset
Old Nov 3, 2008 | 09:27 PM
17 X 8.5
ET34 offset
thx Scott, do you think I can fit a 275 on a 8.5" rim?
Old Nov 3, 2008 | 09:35 PM
SilverBulletAMG's Avatar
C32 AMG
Not safely, and the tire guys will hate you if you ask them to try and squeeze that onto an 8.5" rim. You would also have to roll the fenders to accommodate that wide of a tire.
Old Nov 3, 2008 | 09:55 PM
SB, I'm trying to find a wheel setup where I can run a MT ET Street Radial in a 275/40/17 on my E55 because the widest size that they have in a 18" is a 265/40/18 that will fit my car and I need all the rubber I can get to launch this thing fairly hard!
Old Nov 3, 2008 | 11:08 PM
C32 AMG
There are plenty of 18" and 19" rims with a 9" or even 10" wide rim which would be fine for a 275. I don't know how much space the E has for wide tires. I know the C would definitely need cut or rolled fenders to fit w/o rubbing though. 275 is an odd size so I'm not sure what size tire even comes available in a 275.
Old Nov 4, 2008 | 12:29 PM
I currently run a 275/30/19 and some of the other E guys have stuffed 295's out back I figure with a 17" rim and some wide & sticky mickey thompsons I will not only be able to hook up very well but I may turn rpm's a tad quicker with a smaller wheel & tire combo.
Old Nov 4, 2008 | 12:51 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Hey SBAMG:
If you are ONLY interested in DR, you can mount a 275 on a 8.5" rim. I know, I have done it on my stang with a set of ROH's. You are correct that it would roll over WAY too much for road racing, or even street use. However, straight line DR, it would NOT be a problem. Again, I know this from ACTUAL use at Keystone dragway my friend.
See yeah
Old Nov 4, 2008 | 01:07 PM
Originally Posted by MRAMG1
Hey SBAMG:
See yeah
This is good news, My plan is to only use them at the strip and take them off once I am done.
Old Nov 4, 2008 | 02:34 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Hey Hammer Down:
Just DON'T go below 20 psi and you will be fine. Anything lower and you are risking the tire coming off the bead of the rim. I ran right around 22psi for my Drag radials with a 17 x 8.5 ROH as stated above for a few years without any issues. Have fun and let us know your results my friend.
See yeah
Old Nov 4, 2008 | 04:23 PM
C32 AMG
Hey SBAMG:
See yeah
Good tip for the drags!
