Leaky valve cover
Is this a normal thing for these cars? It could just be a bad seal, but it could also be too much pressure in the system, which means bigger problems.
Also check the inside of crank pulley and see if the oil has found its way down to it. Some say oil cant get into the crank bolt and that maybe true but its good to have your eye on it, get it fixed ASAP.
Also check your motor mount they go bad and leak too. I'm on my 3rd set
Here is a link to a nice DIY that just posted in the W211 forum, should be the exact same job sans 2 cylinders and a few less valve cover bolts. Ignore the coil/plugs/wires part as thats not needed in your application unless you've never changed them, which would be a good time to do it.
https://mbworld.org/forums/w211-amg/...lug-wires.html
From what I've seen many M113/M112's have weaping or leaky valve covers. Mine are due for this job.
The screen name refers to my profession. All legal of course.
