Tires sizes C55
Old 02-09-2009, 09:39 PM
drug delivery's Avatar
2005 C55 AMG
Tires sizes C55
What is the widest tire I can put on OEM C55 wheels? Visually it looks like a another 10 mm both front and rear (235/255) would be okay. If so, what's the best tire to move to?
Old 02-09-2009, 09:45 PM
SoCalC55's Avatar
2019 AMG C43
Im going to second this question.
Being new to car tires: wouldn't a wider tire give better off-the-line grip? Can we even go any wider with the stock rim/setup?
Old 02-09-2009, 09:56 PM
Former Vendor of MBWorld
hooleyboy's Avatar
C55,SL55,C63
235's fit up front and 255's fit in the rear. you could even go 265 and possibly 275 in the rear if you wanted
Remember wider tires weigh more and in the worst place to add weight
Old 02-09-2009, 10:01 PM
SoCalC55's Avatar
2019 AMG C43
mmm so its better off just getting a new set of 245/35ZR18s, just in a tire that dosent suck like the Continentals?
Or does a slight increase in size make up for the slight increase in weight
Old 02-09-2009, 10:10 PM
hooleyboy's Avatar
C55,SL55,C63
The Conti's suck for sure, Had them and hated them. I ran 255 on my stock wheel and I didnt notice any power loss. I bet a dyno would have shown a bit of power loss though.
I wouldnt go bigger than 255's in the rear on the stock wheel, but thats just me.
Old 02-09-2009, 10:13 PM
RedG's Avatar
a g
Just because a tire is wider, doesn't mean it is also heavier.
I would suggest 265/30-18s or even better 275/30-18s (rear), they should fit nicely.
Old 02-09-2009, 10:17 PM
2005 C55 AMG
Depending on the tire an extra 10mm on all tires would add no more than 10lbs.
The car currently has Pirelli PZero. These come in a 255/35/18 and 245/40/18 and would add about 8lb of extra weight.
Old 02-09-2009, 10:55 PM
Quick Silver's Avatar
2019 CLS450 4matic, 2013 CLS550 4matic (totaled), 2005 C55 (traded), & a Ford F150
I'm running 255's on the rear of my C55 with absolutely no problems
Old 02-09-2009, 11:14 PM
RedG's Avatar
a g
Width, profile, and construction all factor into weight, but just because it is wider, doesn't mean it is heavier.
Old 02-10-2009, 12:02 AM
crazeazn's Avatar
C55
its a 9.5 rim isnt it? 255 is the norm
Old 02-10-2009, 12:38 AM
advans's Avatar
C55 ///AMG, 535xi
I run a 235/35/19 front 265/30/19 rear for the c55. tried running 275 on my coupe, it rubbed a bit.
Old 02-10-2009, 12:44 AM
Quicktwinturbo's Avatar
CLS, SLK, ETC
I though anything bigger than 255 in the rear requires fender roll...
I would go with 265 next time then
Old 02-10-2009, 11:04 AM
AMG Sleeper's Avatar
2005 C55 AMG, 2010 VW GTI (Stage 1)
i'm a big fan of my Toyo T1R Proxes... great tire, great grip, pretty good wear as well... and good value buy
my setup is 235/255 as well
Old 02-10-2009, 07:48 PM
2005 C55 AMG
I thought the stock rim was 8.5 inches.
Old 02-10-2009, 08:15 PM
CLK-320's Avatar
CLK 320
255.
Old 02-10-2009, 09:58 PM
SoCalC55's Avatar
2019 AMG C43
According to MB it is:
Old 02-10-2009, 11:07 PM
2005 C55 AMG
Interesting. If the front is only 7.5 inches then will a 235 even fit well? I thought 8 inches was the smallest a 235 would go on without have any issues.
Edit: Well, AMGSleeper says he's running a 235, so I guess its workable.
Old 02-11-2009, 06:57 AM
xplosiveg06's Avatar
Mini Cooper, M5
im running goodyear eagle f1s in 265 in the rear and they rub when i have people in the back seat. a good fender roll and grinding down part of the bumper tabs cured it
Old 02-11-2009, 09:17 AM
i checked mine last night, i have 235/265 setup
Old 02-12-2009, 05:03 PM
workable... AND effective
Old 02-12-2009, 09:47 PM
CLS, SLK, ETC
Does ur tires sticks out at all? Do share some pics of ur car with 265s.. I should be replaceing my Kdws soon and I'm thinkin about putting bigger ones this times
Thanks in adv!
Old 02-12-2009, 10:53 PM
2005 C55 AMG
Are those 265s on the C55 in the photo?
Old 02-13-2009, 03:25 AM
Mini Cooper, M5
yes.
but now that i think of it, 265s are too wide for a 8.5in wide wheel thus why i am now looking to get aftermarket 9.5in wide wheels in the rear now. i'll take a pic of what 265s look like on a stock 8.5 tomorrow. 255s i think is the way to go with stock wheels.
Old 02-13-2009, 09:51 PM
SoCalC55's Avatar
2019 AMG C43
Im going to have to come over and take a look at the tires Marc, although im going to end up going with the 255s.
How are the F1D3s(id assume thats what they are)?
Old 02-15-2009, 07:06 PM
Mini Cooper, M5
the tires are much better than the stock continentals i had on the car before. i am loving them in the rain
here are some crappy pics i took to try and show how they extend over the lip of the wheel. i think they have a rim guard, but they protrude more than there supposed to due to being too wide for the wheel
Quick Reply: Tires sizes C55
