Low coolant/windhsield indicator.
And is this a DIY?
Thanks.
Good news Bold #2
I've experienced both. This is my 3rd supercharger and intercooler. Check the sensor first then retrace all of your hoses and make sure there isn't a leak or a punctured hose. Afterwards, try to run the car hard then pull over and smell for any coolant burns (I assure you the smell is very strong). I wish you the best of luck!
Should my only concern be about the coolant running into the intake runners? Or are there other concerns? And removing intake runners, is that an involved process or is it relatively easy? I searched and got the pictures and what to look for from it, so thanks for that.
My extended runs out real soon, and the dealer is saying everything is ok so I am big time concerned here. Any help is greatly appreciated.
Thanks. Oh, 04 c32. Original owner, no such issues in the past. New intercooler pump installed about 10k ago, I'm at about 39k now.
Second dealer, second opinion - same thing, just to top off the fluids when either light comes on, natch.
Mine kept coming on daily, which sounds like the OP's situation, not any of the other ones mentioned. If you don't replace the sensors, I'm not sure how topping off something that's already topped off fixes anything.
https://mbworld.org/forums/c32-amg-c...acing-sam.html
We have seen coolant entering the combustion chamber from leaky charge cooler, as well as trans contamination from radiator issues.
Good luck.
Good luck.
And is this a DIY?
Thanks.
