c32 alignment issue...
. I took it in to get it aligned again, thinking this time it would be fine. I got the car back, this time they told me that since my back tires are bald it is still going to pull to the right, but they told me if I got new rear tires, it would be fine. I got the rear tires, and it still pulls to the right. I am taking it in to get it aligned again for the third time with all 4 new tires. I am starting to get a little worried thinking it might be something else. Has anything like this ever happened to you guys? Your opinions will be appreciated. Thank you in advance. BTW, it is completely stock with stock suspension, rims, and brakes.
It just doesn't make sense that BALD tires caused it to pull. I know cause I run my tires into the ground before replacing them, and Have NEVER had any pulling issues. The only way that tires would cause it, are if one is new and one is bald on the same axle. Look for the obvious first before chasing ghosts my friend.
see yeah
Seems that with what is happening is that you are not taking it to a mercedes dealer shop or a good suspension shop that works on mb's and has the hunter alignment machine.The operator of a hunter machine would first check for worn or broken or bent suspension parts and then if everything passed muster they would have you dead on specs and the car would track properly.
Get Ye to a hunter machine and a better shop
Why are you driving around on bald tires
I will take it in today for the last alignment and will let you guys know how it goes.
I still think the shop was just trying to sell you some tires. That, or they're incompetent and don't know how to properly do an alignment.
, but I will try it again and see what happens since they will do it for free this time. I dont think it requires that much skill to do an alignment on a car with 4 BRAND NEW tires. If that does not work, I will check the brakes and go from there. Thanks for the advice SilverBulletAMG.
I dont think that the tires should make that much of a difference where I have to push the wheel to the left for the car to go straight. Once I accelerate fast from a stop, I have to immediately hold the wheel to the left so the car can go straight. I am really mad about this and I dont know what else to do. Tomorrow I will try swapping the front tires to see if it makes a difference. I checked the tire pressure and its correct. Please give me any suggestions. Thanks.
You should post the alignment print out he gave you..so we can get a better idea.
I have attached it after I scanned it I dont know how to post it, sorry.
i'll see if i can find the stock oem alignment specs.
Ours was realigned to correct a drifting problem to the right. The correction was to install the caster kits and crank in a small difference between the right side [which was pulling, so it got more caster] and the left. Here is what we wound up with after the adjustments at the dealer:
Caster: L: 9.51 deg R: 9.76 deg [to correct the right drift]
Camber:L: -0.12 deg R: +.029 deg [pretty much unchanged]
Toe: L: 0deg17min R: 0deg16min
The spec on toe for the front is 0deg11min to 0deg21min
The spec on toe for the rear is 0deg17min to 0deg24min
Translation: it sounds like a bit more caster on the right side will correct your drift; everything else I'd probably leave alone.
Thanks for all your replies guys.
Sorry to say this may be normal.
