WIRE and Plug concensus after search
I looked through myriads of posts and many were very old so I wanted to see if the current consensus on wires and plugs was still the same. This will be the first thing I do on the car.
Seems the Magnacore 65211 wires are the choice, and the Denso Ik16 plugs. This the way to go??
2008 A8L, 2002 996TT X50, 2009 X5
do NOT go with IK16s!.....thats a hotter spark plug, which you DO NOT WANT! people initially went that way a while back until they realized it was hotter and some have switched over. if you are going to change your plugs, stay either with the stock heat range (IK20 if you go with Densos) or with a step colder heat range if you plan on running more boost like me or other guys with the 185 pulley kit (not necessary for 178/code3 or even 185, but its safe on the 185).
as far as wires, i went with the 8.5mm Magnecor. I havent had any problems with my plugs or wires. Some people have had rough idle, but im thinking its b/c of a loose connection.
i only did mine b/c i was running more boost and my car had 80K on it and in AZ....my gas mileage was crappy and i figured changing them out was a good idea.....and my plugs were basically shot, so i'm glad i did
C32 AMG
If you're going to stay stock you can't beat the IK20s with the Magnecor 8.5mm Comp wires. If you plan to mod and want some extra head room, go with the IK22s. I have been running the IK22/8.5mm wire combo for ~20k miles and have no complaints at all. Pulled the plugs after ~5k miles just to see how they looked (I was a bit paranoid) and everything looked good.
One tip if you go with the Magnecor wires; crimp the tip of the wires some to make the "snap" firmer when you put them on the plug. Some had issues early on with wires not being snug and/or coming off. After people started crimping them down a bit there were no more issues.
There very well could be some wisdom in c32AMG-DTM's post and we all may be gaining absolutely nothing more than a lighter wallet, but at the same time I have piece of mind and know I'm surely not hurting anything. To me, if the plugs/wires need replaced anyway, why not give it a try?
they have a lot of great stuff. still trying to get a hold of Rob to see if that oil-catch can on the srt6 section fits the C32
I found this page interesting. Obviously being published by Magnecor it's biased, but a lot of the information seems credible. It steered me away from the Nology wires that Code3 is hawking. If you haven't seen it already, Check it out here: http://www.magnecor.com/magnecor1/truth.htm
C32 AMG
C32 AMG
2003 porsche 996 turbo
with your basically stock setup and the mileage on your car why not leave it as is and spend the money on upgrading a tune or cai. plugs are good for 100k if im not mistaken
I wasn't even looking to change mine, but you guys convinced me to. I just ordered Magnecors and NGK's from Needswings. I'm nearing 100K, so I guess it was time anyway. Not really looking forward to the install though...
I run the Magnecor wires and IK16's in a stock engine with no problem. If you mod, defenitely go with the cooler plug.
