Are these Magnecors for C32?
Thanks guys...
How do I know? I almost bought a set from Eurocharged one week ago, and their chief mechanic told me that the OEM's are far superior in terms of conductivity over the latter.
I did however install some NGK Iridium cold plugs (7's), that were gapped at .31 - The car runs like a beast!
The reason I got these cables is because as soon as I replaced IK16s with IK20s and gapped them down to .033-.034", the car started occasionally, having these sputters as if the engine was misfiring but only at idle. I was told perhaps, in the process of R and R my plugs more than twice already, I may have damaged the cables (folding them out of the way, flipping them around, etc).
Like I said, the misfiring occur occasionally during idle, even after I have made sure all the cable sockets were properly secured to the plugs.
Thanks guys...
the only problem people has with Magnecor is the boot on the plug end might be a little loose if you don't hear it click when installing.
In the process I discovered the last two cables driver side in the rear were
switched!! hmm. wonder if that's the reason for the slight misfire.
Anyways, all is well. The car runs great!! A lot more responsive.
the dual spark is designed to have same sequence at lower rev and staggered firing at med-high range. having the cable switched could cause high end misfire, but not low.
