New Owner Could use Mod Opinions
I'm a gearhead having done all work myself (all mods on all cars, 5+ engine swaps on those or other cars, etc) So, that said...I'm already looking to start modding.
Anyway, I've read a ton here and just want to reach out for advice..I'm just having some trouble absorbing (work a lot) and would like someone to speak to where I am at.
OK, I have $1,500 (up to $2k, would like not to go that far if possible right now) for my first round of mods. Here's what I'm looking at and my questions (I appreciate any input):
- Res delete - I'll buy 3" SS online and get it installed (or should I go 2.75"??, does it matter)
- 2ndary cats - any power gain here...just not sensing there is, I'd really like to know even if 5hp. This is not currently planned unless its agreed I'd see some gains
- Pulley - I can handle this one, just want to know if I should be concerned or any risks or downsides with the 185mm (will get tune, see below)...is there something between 185 and 178 (if so, where)
- Intake - this one has me all confused...please tell me what my options are. COde three looks like a flat air filter (is ths same as the 'Green' everyone refers to??) Is there a dual setup option? Where can I get them..I see someone has an SL55 (did I get that right??) is this best for power? If so where is best place to get? My heads spinning tonight on this topic.
-Tune - I'm gong with LET..although its odd that with all other cars mail order tunes didn't do much...seems an accepted power option here...
SOrry lots of questions..looking to get res delete,air intake, pulley and tune ASAP. I look forward to any input (even if just one of my topics).
Last comment - great site, classy people. Big change from all other auto forums I've been on.
Res delete:
IMO, don't bother going with a SS test pipe unless you're in a snowy area with salt on the roads and are concerned with corrosion. Otherwise it won't make any difference except for price and I've never heard of anyone ever having a problem with a regular piece of pipe being welded in the same. Any exhaust shop can do the job for you for less than the cost of the SS piece itself.
There used to be a 181 pulley and they stopped making it as people generally wanted the 178 or 185. With a 185 you will also need an upgraded Heat Exchanger besides the tune. Otherwise it will not make power due to heat soak. Some good info in this current thread on the other forum:
http://www.crossfireforum.org/forum/crossfire-srt6/37470-best-s-c-pulley.html
For the C32's, we're much more limited regarding intakes than the Crossfire SRT-6's and I personally think the best option would be the LET/Eurocharged intake, but I have a SL55 intake as I got it for a great price.
http://eurocharged.com/index.php?page=shop.product_details&flypage=flypag e_new.tpl&product_id=76&category_id=44&option=com_ virtuemart&Itemid=99
Tune:
LEt does such great tunes because Jerry of LET used to have a C32 which he modded the crap out of and still is a C32 enthusiast. He has learned to tune them over the years and has lots of relevant experience with them. Besides the fact that he's a stand up guy, you will not go wrong with their tune.
Good luck brother!
The code 3 intake isn't a "green" filter (except in color). The green filters you're reading about are just a different brand of filters for the air boxes (like K&N or BMC). If you look at the engine you'll see two air boxes leading into to a splitter that goes into the intake manifold. On the stock Y splitter the back comes off. The code 3 intake goes on the back of the stock y splitter. It sucks engine air directly into the manifold. This produces horsepower and the SC whine that people like. Personally, I don't like the idea of sucking hot engine air into my engine anymore then I have to (but it does work). The other popular options are the LET intake which gets rid of the boxes altogether and uses two sponge like (itg?) filters. Everyone that has used this seems to like it. It has great fitment, good power, and fuel economy gains, but it's expensive and you lose any semblance of the stock look. Last time I checked the LET intake was $549. The other popular option is using the oem (sl55) Y-pipe and sometimes air boxes off of an SL55. The SL55 y splitter, intake tubes and airboxes are much less restrictive. Some only use the SL55 y splitter with their stock boxes. There are also many other custom intakes like Renntech and Kleeman, but they too are expensive. The SL55 setup can be pieced together from any parts website for around $350. I recently installed the full SL55 intake I bought off a member here and have been really happy with it. You have to modify it slightly, but no big deal.
Good Luck
code3 intake: if you look at the C32 intake, it is a dual setup. both sides converge at the back of the engine bay at what is commonly mistakenly called the "y-pipe." It is actually a T-pipe or T-splitter. If you look at it, the back end of it, you will see it is flat and it has a plate that covers it. This "plate" is removed and a filter with plastic gasket material goes there. This is the code3 intake. You can make one yourself for 15 bucks if you so wish to do so. the sound the code3 intake makes is addicting. i used to have it, and i miss it. the supercharger whine is ridiculous (cobra loud). however, it makes the least power of the intakes i believe. it also makes different power....it makes more on the low end whereas the other two make more top end power i believe.
SL55 intake: this is what i have now. it is made up of the SL55 intake hoses, airboxes, and larger splitter (no longer a T-shape, so code3 does not work with this). Does not make quite the supercharger whine you get with the code3, but it makes more power topend and i think overall. I have no dyno's to prove it besides my butt. I don't think you will actually find a dyno for the SL55 setup. We just all feel it makes more power. With my setup, I still get a very nice supercharger whine, though not as loud as I would get with a code3. Cost? eh....i assembled mine for like 280......the price has gone up a bit though....it might be between 350-450 now. if you're lucky, some SL55 guys sell some of these used. save some bucks that way!
LET intake: dual cone air intake. uses the larger SL55 splitter. dyno gains show 15whp or so if i recall correctly. A bit too expensive for me, but looks much cleaner that the SL55 setup (which requires some minor trimming, though nothing too major) with proven dyno gains.
also, just throwing in aftermarket filters in stock airboxes if you dont wanna do much or if you keep those stock stock airboxes. THESE are where we say to avoid the Green (brand name) filters. Stick with K&N filters if you are using the stock C32 air boxes or upgrade to the SL55 air boxes with that setup.
suggestions i will make:
Heat Exchanger. If you are getting a 185 pulley, you will want a larger Heat Exchanger to keep the IATs down so you don't get heat soaked easily (and it happens, and you'll probably experience it at some point in time if you don't get a larger one). LET and Code3 makes them.
further down the rode, consider splitting your coolant circuit....if you are really die-hard for the absolute coolest IATs
not sure how many miles you have on your car, but if it is somewhat high, i might consider changing your plugs. especially if you are going to run a 185 pulley, you might want to go to a step colder plug like many of us have.
your budget of 1500: will definitely be used up. not sure if you've looked at the prices of some of the items (intakes, pulleys, tune, etc...)...stuff adds up relatively quick.
good websites to check out and have bookmarked:
www.eurocharged.com
www.needswings.com - look through SRT6 and C32 parts (note: srt6 and slk32 have a roomier engine bay, we can't use the needswings intakes and manifolds on the c32. won't fit).
- many of us are members over there too because, again, they have the same motor
This should be your first round of mods.
Cut the resonator, leave the cats.
Save $ for a sl55 or LET/Euro intake and tires.
Best bang for your buck right there... 400+ crank hp in a consistant basis.
You'll be so happy with your purchase that you will want to throw an extra $2K only to find out it's not that easy anymore...
As a side note, the Code3 intake now has a yellow filter... the ones in green color were the first generation... or at least that's what I've got.
The recipe for putting a smile on your face. I saw the post talking about the C3 intake being loud, I though the LET intake was made the SC have a loud whine as well as I saw your car's flyby video.
He has learned to tune them over the years and has lots of relevant experience with them. Besides the fact that he's a stand up guy, you will not go wrong with their tune.Good luck brother
*** You mean Mr. BMW 135 Jerry!!!!!!
Mr. , I defected to the "dark side Jerry."+1, Jerry's tune made all the difference in the world to my car. get a hold of Jake or Jerry at Eurocharged, get a Code III pulley and the tune with an intake and soon you'll be in the 12s like most of us C32 guys!!!
In all likelihood, this setup will not make as much power as the 185mm Eurocharged crank pulley - if max power is what you want, that would be your pulley of choice. The power upgrades and, by extension, necessary cooling upgrades will blow through your budget, but PM loungn14... he might be able to "help you out" there.
Also need to decide on tune type...just still curious about effectiveness of a mail order tune (I did my own tuning on my Cobra back in the day when it wasn't as easy as it is now)...dyno tune get costly though.
Then intake, really want the LET but man $550 is steep. Anyway looks like I'll be reading more up on this stuff, which can be fun in itself. Thanks again for all advice. Look forward to sharing my own experiences.
https://mbworld.org/forums/parting-o...out-c32-6.html
