engine troubles ahead ?
Old Oct 18, 2009 | 03:02 PM
lepez's Avatar
CLS320cdi, GL350BT, ML270cdi
so ... i think i might get into troubles with the amg ...
yesterday evening, i went for a short ride, and after about a km or so, the engine started doing weird...
it was like it didn't get enough fuel or something. the engine behaved weird, the iddle rpm was going up en down. when i was braking and the car was almost stopped, it kept pushing forward when the rpm was on the highest point when going up en down..
so i was thinking what could the problem be ? one of the fuel-injectors ? fuel pomp not good ? air mass meter ? ...
i'm going to take it this week to the garage also, but it would be nice to know what could be wrong...
the car has about 30 000 km's and is from 2003 ...
Old Oct 18, 2009 | 04:17 PM
testknight's Avatar
CLS55
Intercooler Pump, likely. Hard to follow your explanation, but if it runs fine for a while, then after driving a bit, if the IC pump is failing, it'll feel like its falling on its face (mine kind of jerked and just wasn't accerlating much at hard throttle)
Old Oct 18, 2009 | 04:27 PM
lepez's Avatar
i have read about the ic pump, but most claim at 60 to 80K miles, mine has just about 20K miles ...
however, it has it's age ... but would'nt it be a bit soon ?
yeah, the explanation could be a bit difficult to understand, im from belgium so my english isn't that good ...
grtz
Old Oct 18, 2009 | 05:32 PM
Zeppelin's Avatar
C32
It sounds like either a bad TPS or CPS sensor. It should not be too difficult for the mechanic to troubleshoot provided it is still doing it or it threw a code.
Old Oct 18, 2009 | 05:36 PM
lepez's Avatar
wel, i got the "check engine" light...
next day, i fire it up again, engine runs normal , no check engine light or what so ever ...
anyway, one of these days i'm hooking it up on the star and i'll see what the prob is ...
grtz
Old Oct 18, 2009 | 06:31 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
grtz
Don't wait for "one of these days". Get yourself a little OBD2 reader here:
http://cgi.benl.ebay.be/Scanner-de-d...item53d5b3e2ac
Old Oct 19, 2009 | 01:17 AM
eddie1628's Avatar
C32
Check Throttle Position Sensor and Throttle Body Actuator
Old Oct 19, 2009 | 05:13 AM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
I had the same symptoms. After researching on the forum I reseated the plug that connects to the throttle body. I also put a zip tie to secure it. I havent had any problems yet......
Old Oct 19, 2009 | 06:24 AM
lepez's Avatar
i'm not driving the car for now
I have a daily driver w203 220cdi for daily use, I'm not gonna risk it driving it around...
grtz
