Oil Overfill Question
So they drained the oil, changed the filter, and replaced the oil with Mobil 1 0w-40 (after I had to convince them not to use 5w-30). However, when I got back into the car and checked the oil level through the computer, it said "Reduce Oil Level". I didn't get any error messages or anything though. I brought this to the attention of the mechanic and he said that it was fine, and that if it still reads Reduce Oil Level tomorrow morning I should bring the car back in and they'll take some out.
I drove maybe 2 miles from the shop back to my apartment, and haven't driven since. Am I risking serious engine damage, or is it fine like the mechanic said? They didn't measure how much oil drained out, so I have no idea if just using one plug got all the oil out, and now I'm concerned.
Thanks for your help.
As for damage, I doubt you’ve done any damage at this point, but I have no idea how many quarts a C55 pan will hold before things start going bad. If I were you, I’d (1) reduce the level as soon as possible, and (2) change mechanics.
This is why you don’t want to overfill a car with oil – if the pan is so overfull of oil, that the crankshaft hits the oil as it rotates, the oil will foam. Oil pumps are designed to pump oil in a liquid state. If they pump foam, metal parts that are supposed to have a layer of oil between them, will have nothing between them, and very expensive parts will wear rapidly. Also, if the oil level is higher than the oil pan gasket, the pan gasket will leak. If it’s higher than either the front or rear seal, that seal will leak.
No need to panic at this stage, but you may want to take it to the dealer, who will extract the excess oil with a pump. If you’re in SoCal, specifically the SCV or SFV, I could come by and pump it out. Pumping it out takes about 30 seconds.
Are you supposed to test the level when the engine is cold or hot?
i jut changed the oil last week
there are two drain plugs
get your oil changed somewhere else.
the place you took it to. they do not know what they are doing.
do a search to see what happened when too much oil was put in
i thought black holes could only be created if you tried to divide by zero!
Check oil level approximately 5 minutes after stopping
the engine, allowing for the oil to return to the oil pan.
You may want to check your owners manual. My owners manual allows for zero circumstances where I should see a message that says the engine has too much oil in it. My manual also says -
Do not overfill the engine. Excessive oil must be drained
or siphoned. It could cause damage to engine and
catalytic converter not covered by the Mercedes-Benz
Limited Warranty.
I recommend that you give serious thought to taking the car to either a Mercedes-Benz dealer, or a mechanic who can extract 1 or more quarts of oil from your engine. The shop that changed your oil has not demonstrated a great deal of competence in this area. Although they caused the problem, I would not recommend using their services to correct this problem.
If this still comes up, come by my shop. we'll take care of it.
