C32 Custom Intake
Old Dec 10, 2009 | 02:53 PM
  #126
Gramma_Benz's Avatar
2002 C32, 2012 S550
Nice, thanks for doing all the R&D on this. However, i still think the bottle neck is at the rear T-Splitter. You need to change that to at least an SL55 Y Splitter.
Good luck and more power to ya!
Old Dec 10, 2009 | 03:04 PM
  #127
SilverBulletAMG's Avatar
C32 AMG
Originally Posted by gt4awd
Any suggestions for a cheap but good heat wrap? There's some at autozone, it cost $20, and doesn't come with much... The main difference between this setup, and LET/EC is where I have the filters located.
Could you post a link please?
So, here's the update... Turns out there wasn't enough room in the engine bay to fit that huge coupler. The hood wouldn't shut... It did look like two huge turbos almost. All that stuff will be returned. I have a new plan now that is a lot cheaper. I'm just going to cut, and place an end cap on the open side of the pvc enclosures with an opening for the air ports. Thinking around 3" tubing should be good enough... Not sure what the end result will be, but I'm off to find another solution.
This was the very cheap setup I did in conjunction with the C3P intake - https://mbworld.org/forums/c32-amg-c...o-baffles.html
I purchased a bunch of heat wrap and some fancy heat resistant spray paint stuff that was about $80 for the setup (most expensive part) and it turned out pretty sweet. The pics in the thread were before everything was coated of course. I still have some spare parts for the heat wrap and may still have the receipt even. Will take a peek tonight and see where I ordered from and what all it was exactly.
Old Dec 10, 2009 | 06:59 PM
  #128
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
Do they get crushed a bit when the hood closes?
Yes, the PVC enclosure does hit the hood slightly when closed. Planning on placing some rubber separators to solve any rubbing issues...
Not bad at all...
Ehh, it's a good start...
Considering I have 4" air port, and six inch chamber to end it with a 2 1/4" pipe isn't working for me either. I completely agree there is room for improvement past the filters. How much is the SL55 splitter, and what size are the openings? Could go the custom route for a new splitter...
Thanks, let me know!
By the way, I popped the hood after a long drive. The entire intake was ice cold...
Old Dec 10, 2009 | 07:18 PM
  #129
320 dreamer's Avatar
2003 porsche 996 turbo
sl55 splitter is around 111$ from parts.com remember the temps in dec are vastley different than the temps in august. if you have metal tubing you will need to wrap them. my temps on my s/s tubing was in excess of 180* after a 20 min drive in the summer. wrapped them and the temps dropped to under 100*
Old Dec 14, 2009 | 10:08 PM
  #130
ML500K's Avatar
C32 '02
Old Dec 15, 2009 | 08:32 AM
  #131
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i believe the sl55 splitter has a 3'' opening.
Old Dec 15, 2009 | 10:26 AM
  #132
c32used's Avatar
LET C32 2002
Good luck to you My only argument is I'm not crazy of the look of our engines without the covers..it just don't do it for me..also I've noticed with my last setup that to little to too much filtration when dirty tends to minimize air flow so I'm removing the ITG filters and putting in the K&N filters back in the SL55 airboxes...I noticed my MPH were down and even colder temps outside and waiting 1 hour between runs they would not go up much at all. Its nice to get more HP numbers but if air is scarce at top it don't matter.
Old Dec 15, 2009 | 05:23 PM
  #133
gt4awd's Avatar
Good to know!
Good luck to you
Thanks, plan on cutting down the PVC more, and making several changes so it fits without touching the hood.
I think the opposite... I've always liked the look of the engine more with the covers off. That way you can see all the components.
I agree. Think the drop in top end noticeable on my dyno runs was due to IAT with stock HE and possibly due to stock t-splitter flow restrictions...
Old Dec 15, 2009 | 05:38 PM
  #134
jturkel's Avatar
02 C32 AMG
i think this statement is right on!
Old Dec 17, 2009 | 09:52 AM
  #135
C32 AMG
Sorry for the delay, but I found my old packing slip with all the info on the heat wrap and extra treatment.
I ordered it all online through Summit Racing. Part #'s THE-11022, THE-12002, and THE-13575. That is for exhaust insulation wrap, some special paint stuff (mainly just wanted it for color and for a more "finished" look), and heat shielding. Total was $72 plus shipping.
Old Dec 17, 2009 | 08:44 PM
  #136
430's Avatar
430
SLK32
You may want to reconsider the use of PVC in your intake system:
When PVC is heated to 170~180°C, chlorine and hydrogen in the molecules are eliminated and release of hydrogen chloride becomes evident. Once such decomposition starts, unstable structures are formed in the molecule, which further accelerate HCl elimination and decomposition.
Hydrogen chloride gas, is a corrosive, highly toxic gas.
Because of its acidic nature, hydrogen chloride is a corrosive gas, particularly in the presence of any moisture.
Not what I would want my engine injesting.
Old Dec 18, 2009 | 12:04 AM
  #137
Dingleberry's Avatar
Marsaydees
Agreed, combustion of vinyl chlorides produces many potent carcinogens such as dioxin. The last thing I want to do is be responsible for my engine growing a tumor.
Old Dec 18, 2009 | 01:38 AM
  #138
gt4awd's Avatar
I'll check it out...
Interesting information, but my intake will really never hit 170C (IAT @ pre-charge), so no worries...
Old Dec 18, 2009 | 01:58 AM
  #139
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
....hey ....nevermind
Old Dec 18, 2009 | 09:38 AM
  #140
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
your intake doesn't, but your engine bay does as well as the valve cover that the PVC pipe is leaning against.
ThermoTec sells heat barrier cloth that stands up to 2000F. spent some $100 bucks and you can cover your entire airbox with it to prevent it from any engine heat soak.
Old Dec 18, 2009 | 02:57 PM
  #141
gt4awd's Avatar
True, but as you said, won't be an issue once the heat shielding is done, and it's not an issue right now because of the temperatures outside... The PVC actually sits directly on top of the coil packs, and I have everything spaced out now with cut up sections of the hood insulation that I didn't use. Also, cut down the PVC, so it fits perfectly in the engine bay now.
Old Dec 18, 2009 | 04:09 PM
  #142
1qikctr's Avatar
Merc power
Looks like 2 BIG Azz Turbos top mounted on the engine. hahhaah. It's good to see some ppl making their own intake, at the end of the day, your own opinion counts.
Old Dec 18, 2009 | 04:21 PM
  #143
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
would agree......uh interesting I guess...
Old Dec 20, 2009 | 08:28 PM
  #144
430's Avatar
430
SLK32
Of course we should not worry about the fact that Hydrogen chloride (HCI) is also known as hydrochloric acid. Personally not something I want traveling through the intake path of my engine. But hey to each their own.
Old Dec 20, 2009 | 08:33 PM
  #145
TemjinX2's Avatar
maybe look for a abs equlivalent maybe?
Old Dec 20, 2009 | 09:08 PM
  #146
gt4awd's Avatar
Sure go a head, but I'm not going to worry about it. Once the heat shielding is done it won't matter. Originally I wanted to use a plexiglass section so the filters would still be visible. Can't really heat shield it, and keep it visible though.
Old Dec 20, 2009 | 09:11 PM
  #147
Marsaydees
newsflash! hydrochloric acid exists in an aqueous environment. HCl is not "known" as hydrochloric acid
Old Jan 15, 2010 | 10:47 PM
  #148
c32kompressor's Avatar
CLK55 AMG
c32 custom intake
just made a custom intake saw it on a youtube video (creadits to them) works perfectly heres some pics
Old Jan 15, 2010 | 11:18 PM
  #149
Marsaydees
this will definitely increase the flow of hot air into the motor
nice hot air intake
Old Jan 15, 2010 | 11:20 PM
  #150
CLK55 AMG
im going to get elbow pipes to extend it, i know its hot air but it works
your so funny idiot
