Paddle GearShifter for c32 w203
Old Dec 31, 2009 | 02:04 PM
knightrider2k2's Avatar
2003 C32
Is is possible to retrofit a paddle shifter to C32?
Old Jan 1, 2010 | 05:52 PM
dlwiser's Avatar
C32 AMG
i would love to kno this too
Old Jan 1, 2010 | 05:58 PM
moosejaw's Avatar
none
I have seen it done to C55 but even that is a PITA
A question FrankW can answer better than me regarding C32's.
BTW if you start in first and floor your car to the redline, it shifts itself.
Old Jan 1, 2010 | 05:59 PM
jturkel's Avatar
02 C32 AMG
well, ANYTHING is possible when there is enough money. but, IIRC, the C32 cannot be retrofitted with the mercedes C55 or other paddleshifters. i believe searching the forum would support why as i cannot remember why, but i'm about 99% sure it canNOT be done. sorry! would be cool though!
Old Jan 1, 2010 | 06:35 PM
Robert AMG's Avatar
Cls63 & C32
i have done it, it is now working from at least 6 months with no problems,
we have connect the paddle shifters on the steering wheel to the shift knob so when you hit the paddle shifter is like hitting the shift knob.
Old Jan 1, 2010 | 06:57 PM
320 dreamer's Avatar
2003 porsche 996 turbo
any write ups on how to do it and a parts needed list?
Old Jan 1, 2010 | 07:08 PM
Robert AMG's Avatar
Cls63 & C32
i cannot cause it deals with electronics, a guy here who works with electronics did it to me, i remember he did an electronic board connected to the wires coming out the shift knob and a wire to the steering wheel. tomorow i'll get pics.
Old Jan 1, 2010 | 10:35 PM
2003 C32
Thanks for the comments guys.
Robert, did you installed a new steering wheel or just the paddles somehow?
Old Jan 1, 2010 | 11:30 PM
francoisisp's Avatar
AMG
interesting that sounds like a relly good shortcut instead of changing the whole stearing wheel. is there a way you can get in touch with guy im sure if enough people put money together maybe he can be motivated to put together a kit or something. because im sure just about all the C32 owners on here have always wanted to do this. this route sound like you wouldnt need any star to make it work. and the only thing needed is to mimic the contact created by movin the stick on the stearing wheel level. ................. by the way anybody know if E55 Come with any kind of shifting at the stearing wheel level ?
Old Jan 3, 2010 | 06:24 AM
Robert AMG's Avatar
Cls63 & C32
you need an OEM steering wheel with paddle shifter for the look to be OEM, no steering column, i went with the clk550 steering wheel and i ordered now the paddles of the 63, the silver one, no star.
I took today some pics and i talk with the guy who did it and said that he will work on a kit with instruction for shipping to you guys, i will be in touch.
Old Jan 3, 2010 | 10:53 AM
ok i have a stupid question. with the steering wheel you used costing 1200$ can the oem wheel be used? i just read a bmw thread were they used amg paddles costing 100$ and installed them on the bmw wheel. a template was made and the backside of the wheel padding was cut away for the paddles to set in place and a 2 holes were drilled in the wheel, 1 for the wires and 1 for the screw to hold the paddles in place.
so... if we can use the oem wheel this could be done for a couple hundred depending on what the cost of the electrical kit costs. much more in line with what i would like to do
robertamg would you happen to have any fotos of the backside of your wheel with the paddles installed?
heres the link i found . doesnt look to hard! with a kit for the electrics this is a big custom mod!!
http://www.bimmerboard.com/forums/posts/610491/
any thoughts?
Old Jan 3, 2010 | 03:49 PM
2003 C32
This looks promising.. These paddles were also used on a LX thread. Not bad for $100-$150 of investment.
http://www.lxforums.com/board/showthread.php?t=114669
Old Jan 3, 2010 | 10:59 PM
dlwiser's Avatar
C32 AMG
looks promising
Old Jan 4, 2010 | 12:15 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
proper way takes too much money. i.e. new SAM, wiring harness, programming, etc. not possible with what's already in the car unless you change'em and you still won't get the Manual mode like the C55.
the above way seems possible if you have someone with the electronics know how. too much hassle, but at the end of the day it's just two buttons sending the same signal as if when the gear lever is pushed left and right.
Old Jan 4, 2010 | 01:58 AM
Quicktwinturbo's Avatar
CLS, SLK, ETC
Do ya really wanna spend $1000s on a set of button that shifts slowly?
I told that to my friend n he gave up his dream like an asian guy in a dunkin contest.
Old Jan 4, 2010 | 02:50 PM
Robert AMG's Avatar
Cls63 & C32
This is my setup, i paid 250$ for the streering wheel used and swap from the C32 one, i spent more then 12k dollars on the car and this upgrade is the best one i ever did, you don't believe how much i enjoy it, why? cause you don't have to puch the manual mode on the shift knob like the C55 each time you want to use them, they are always ready every second.
And who told you that they are slow? same as shift knob.
Old Jan 4, 2010 | 03:11 PM
robertamg im always up for something out of the ordinary. no slk32 has them and if its not to diff. to do ill try it!
Old Jan 4, 2010 | 03:30 PM
Robert AMG's Avatar
Cls63 & C32
i got the steering wheel cheap because of that i didn't think of installing them on the C32 one, i think it can be done, you have to check inside the OEM C32 st wheel and if there is a steel plate where you can hold the bolt and the paddle and if not you can install one and hold it with a nut if there is place.
Old Jan 4, 2010 | 08:17 PM
CLS, SLK, ETC
I was referring to transmission shift speed.
Yea, its fun to play with paddles / buttons but i dun think it's worth it since our tranny is pos.. Strong though.
Old Jan 5, 2010 | 01:38 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
for anyone that don't know. on the C55 in the manual mode tapping the gear lever has a quicker response than the steering wheel button. why it happens I don't know, but it happened on two C55 that I've driven.
Old Jan 5, 2010 | 02:14 PM
german32er's Avatar
C32 & C63PP, 203CL
Originally Posted by FrankW
........and you still won't get the Manual mode like the C55.
i have the "M-mod" in my C32, it`s a spezial option from performance center in affalterbach.
in normal drive you dont need it, but to drive in montains, or "on track" its perfekt.
paddles on the steeringwheel makes this option perfekt.... i am on the way to have once.
sorry for my english, i read much here, but i can`t write........
greets ralf
Old Jan 5, 2010 | 02:25 PM
Biscuit's Avatar
'03 C32, '08 ML63
That has always seriously irritated me. That and, at least on mine, if I have it to the floor and tap up to the next gear it will ignore that tap until it hits redline or I let off on the gas some. I wish there were ways to change those two behaviors.
Old Jan 5, 2010 | 08:34 PM
AMG
I'm glad somebody pointed that out "tapping the grear lever has a quicker response than the steering wheel button" so with this setup that we have been talking about its a mere extention of the gear lever to the steering wheel, which mean the response time should be the same using the jerry riged padle shifter given that its using the same contact as the lever to operate I think robert is on to something i will definetly be interested if the guys can have some kind of information as to which wire goes to where and the how he wired it. I've hear plenty of people say padles cant be done on c32 well obviously it can
Old Jan 5, 2010 | 08:56 PM
CLS, SLK, ETC
Remember, for Upshift, it's alot quicker in S-mode
Correct me if i'm wrong..
Old Jan 6, 2010 | 12:58 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
greets ralf
damn you!...but great info...lol
