Difference between C55 engine and E55
Old Jun 16, 2010 | 04:17 PM
clemson_tiger's Avatar
2006 C55
...and pretty much any other AMG 5.4L engine? Is it nothing more than a computer program that changes the HP or is it much more than than...heads, intake, etc?
Old Jun 16, 2010 | 04:18 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
E55 has lower compression AND a Supercharger.
Old Jun 16, 2010 | 05:37 PM
King320's Avatar
03 C32 AMG
Old Jun 16, 2010 | 06:03 PM
OverDrive's Avatar
Volvo
Theres a lot thats been changed, I think the head is pretty much the same (Valves and such) (The Intake system is way different than the N/A 5.4) but the bottom end is different. Rods, Crank (I Think) and Pistons.
Old Jun 16, 2010 | 07:11 PM
Dingleberry's Avatar
Marsaydees
not all e55's have superchargers...
Old Jun 16, 2010 | 07:33 PM
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
All good ones do..
Here are some other differences
Water pump
Oil filter housing
thermostat
Injectors
I hear that the 55NA pistons are actually stronger than 55k pistons. Might have to do with overall thickness of the higher compression piston. Dont take that statement as fact though. From my findings The 55NA bottom end can handle a good amount of boost.
From an NA stand point. It has to be up at the top of the list for NA motors that can take a bunch of boost. Where Mustang GT, 350Z, and other engines would crumble at anything over 10psi of boost the 55NA keeps going. If your tune is good.
Old Jun 16, 2010 | 07:56 PM
MarcusF's Avatar
2002 CLK430
Assuming you're talking K versus non-K, they have a lot less in common than you would think. In addition to what's already been said, the 55K motors have different
  • Crank
  • Rods
  • Rod bearings
  • Pistons
  • Block
  • Heads
  • Cams
  • They use the same intake valves, different exhaust valves
  • The K motor has double valve springs
Old Jun 17, 2010 | 09:30 AM
2006 C55
Thanks guys!
Old Jun 17, 2010 | 02:03 PM
MercedesFTW's Avatar
Cee Fiddy Five
Planning something fun?
Old Jun 17, 2010 | 03:40 PM
2006 C55
Haha, I wish. I was just curious what made the difference in HP. I'm fairly new to the AMG world.
Old Jun 17, 2010 | 06:24 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
The big supercharger is what makes the difference in horsepower. Everything else is just there to handle it.
Old Jun 18, 2010 | 06:25 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Originally Posted by MBH motorsports
All good ones do..
Water pump
Oil filter housing
thermostat
Injectors
I decided to play it safe by converting to an E55 short block because 8psi fried two of my piston rings...maybe it was the tune or maybe it was the NA pistons/rings.
Old Jul 13, 2018 | 12:41 AM
WingNutNZL's Avatar
E55
Everyone - I have a related question that I would love some help on. What if anything is different between the C55 AMG and E55 AMG exhausts? The reason I ask is that I have recently picked up a 2005 AMG E55 from a friend of mine, who for some reason, replaced the factory exhaust with what appears to be a straight pipe with some baffling (but not much). The end result of is that the car is offensively loud. It also seriously reverberates and between about 1500 and 3500 revs it is almost unbearable. So I am going to have to go back to a factory exhaust option or something else. Another friend has the factory AMG exhaust setup from his AMG C55 which I could use. Are they the same?
Old Jul 13, 2018 | 08:48 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
You may be able to use the mufflers if they fit the e55's stock area where its mufflers were. I'd skip the resonator altogether as it just changes tone and does almost nothing for overall noise levels. I'd be extremely surprised if much exhaust tubing can be used due to different floorpans. If the mufflers will work, they should be plenty as they're known for being just quiet enough but also being fairly unrestrictive.
