Code 3 SC Pully
Old Sep 14, 2010 | 07:22 PM
Hawaii C32's Avatar
c32 amg
Code 3 SC Pully
Does anyone know how to get the Code 3 supercharger pully? If so please enlighten me.
Old Sep 14, 2010 | 07:25 PM
jturkel's Avatar
02 C32 AMG
you can look for a used one in the classifieds section here or on the srt6 crossfire forum (same motor)
you can post up in this section asking if anyone is selling one
i just went to their website and noticed they don't have them for sale anymore. you can try to contact them (good luck with that) and see if they have any extras they might be willing to sell.
here is their home page: http://www.hpautowerks.com/
Old Sep 14, 2010 | 07:41 PM
320 dreamer's Avatar
2003 porsche 996 turbo
hp no longer sells the c3. manufacturing issues. only way is used and none of the forums has any for now. hot item hard to find!
it has been prposed to have the oem machined down but never saw anyone do it
Old Sep 14, 2010 | 10:48 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
TVT Design can machine down your OEM pulley.
http://www.tvtdesign.com/srt6_c32_slk32
Old Sep 14, 2010 | 11:47 PM
buffyclk500's Avatar
clk500
tvt will go down 2 69mm any lower u need a new bearing
but if i am right c3p are 68mm
if u can find a code 3 do it if not tvt is still a good way 2 go
Old Sep 15, 2010 | 01:00 AM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
Didn't even know TVT had a website. Looks like they have some nice goodies on there! Might go with them for fuel system upgrades...
Old Sep 15, 2010 | 01:01 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
the code3 pulley is 65mm
Old Sep 15, 2010 | 01:19 AM
clk500
good call i was not sure about it
Old Sep 15, 2010 | 04:46 AM
Hawaii C32's Avatar
c32 amg
I need a new pully because the backing plate on my pully is coming loose, so machining my stock pully will not solve my problem, unless there is a fix for the loose backing plate
Old Sep 15, 2010 | 05:25 AM
gt4awd's Avatar
I'm sure there has to be a way to fix the back plate. I have not personally examined the full pulley/electromagnetic clutch design, so can't be of much assistance. If you could provide some photographs and more information on how the back plate is held in place that would help us to help you.
Old Sep 15, 2010 | 09:59 AM
loudandheard's Avatar
C32/C55 AMG
I don't understand how difficult it would be to have a similar pulley made.
This looks like a completely custom pulley and it's suppose to be 58mm.
Old Sep 15, 2010 | 12:50 PM
c32kompressor's Avatar
CLK55 AMG
what would the difference in power if you went with code three, or machining down to 69mm, like Temjin x2 said the c3p pulley is 65mm
Old Sep 15, 2010 | 01:52 PM
2002 C32, 2012 S550
Just less boost. Already, the C3 pulley at 65mm is equivalent to a 178mm crank pulley.
Old Sep 15, 2010 | 05:34 PM
Hawaii C32's Avatar
c32 amg
Thats pretty cool, so the aftermarket pullies eliminate the electromagnetic clutch?
Old Sep 15, 2010 | 09:34 PM
C32/C55 AMG
Nope, I think it's still there. I am assuming the black portion is the electromagnetic clutch, I could be wrong. There has to be a shop that can make one of these pulleys. I'll check around and see what I can find. My dad has an srt-6 and a buddy of his said that he could probably make him a pulley. So I'll see what he says.
Old Sep 15, 2010 | 10:36 PM
gt4awd's Avatar
The larger black pulley behind the smaller pulley is the electromagnetic clutch. Basically the front pulley free spins on it's bearing until the clutch engages and develops a magnetic field that interacts with the shaft to make what you could call a solid connection. If someone had access to a machine shop with CNC and could source a smaller bearing capable of handling the increased RPM you could likely make a small enough pulley to equal the 185MM RPM. Can someone calculate what the pulley size would need to be in order to do so?
Old Sep 16, 2010 | 08:50 PM
CLK55 AMG
what size is the oem s/c pulley on the c32?
Old Sep 16, 2010 | 09:11 PM
TemjinX2's Avatar
74mm
Old Sep 17, 2010 | 01:36 AM
2002 C32, 2012 S550
I think the main issue with going to such a small pulley is that you will not have enough area for the belt to grab sufficiently. Even with the regular C3 pulley you would still get some belt slip.
Old Sep 17, 2010 | 02:14 AM
gt4awd's Avatar
That's an easy fix though either get a smaller belt, or increase the pulley size of another or multiple pulleys.
Old Sep 17, 2010 | 02:44 AM
2002 C32, 2012 S550
No, I mean on the supercharger pulley. When you punch it, the belt slips on the supercharger pulley causing you to lose power due to belt slippage.
See this thread:
https://mbworld.org/forums/c32-amg-c55-amg-w203/284517-anyone-have-code3-belt-wrap-kit-installed.html
Old Sep 17, 2010 | 06:47 PM
Newzchspy's Avatar
PLAID
[QUOTE=Gramma_Benz;4251156]Just less boost. Already, the C3 pulley at 65mm is equivalent to a 178mm crank pulley.[/QUOTE]
and there was a reason why Brandon did that!! He had some smaller ones and also stacked ones, BUT they were all throwing CELs. I know of a fellow forum member with 178 and Code 3 and hes always throwing Cels.
Old Sep 17, 2010 | 07:18 PM
TemjinX2's Avatar
154/65 x 6 = 14.2k rpm
185/74 x 6 = 15k rpm
154/61 x 6 = 15.14k rpm
So you need a sc pulley at 61mm to equal a 185 crank.
Old Sep 17, 2010 | 08:17 PM
C32/C55 AMG
Damn, so a 58mm supercharger pulley and a 180mm crank pulley would be running 18.62k rpm?
Old Sep 23, 2010 | 10:08 PM
2002 C32, 2012 S550
Here you go....
https://mbworld.org/forums/engine-performance/368426-f-s-code-3-pulley.html
