Washed engine, now car won't start
Car sat over night until this afternoon, I go to start it and nothing. Car doesnt turn over, or even make any noise for that matter.
Alternator is new.
The lights work and the key works to unlock the doors and stuff so I am assuming it is not the battery or the key.
Any one know what it could be? Could I have gotten water somewhere it shouldn't be somehow?
I'll be back tomorrow afternoon to try to start it again..
Charge the battery key out via the underhood charging post and a good clean negative connection to the chassis.
Then try to start.
If it starts you will most likely have abs esp warning lights but just turn the steering wheel all the way lock to lock and back a few times to reset the steering angle sensor.
So I got home and the siren was going off, since the battery had died and the alarm stopped working. I charged the battery and jump started my car, and it worked. So far it's been good
So maybe the water wasn't the issue? I did start the car after I washed the engine, but then it sat after that....
Not sure how to battery could have died, I didn't leave anything on
or why the alarm randomly went off
or why the alarm randomly went offbattery, but only to provide supplemental charging. one should determine
the degree of battery discharge before selecting the method needed to
recharge. if the battery is below ....mmm....12 vdc, you really should go
with a trickle or 10 amp charger.
