now i have nice new wheels....
i need some low dust brake pads to keep em clean!
ebc redstuff any good?
CHEERS
CHEERS
CHEERS
Akebono FTW Originally Posted by varoom
now i have nice new wheels....i need some low dust brake pads to keep em clean!
CHEERS
Quote:
+1Originally Posted by 503C43 ////AMG
Akebono FTW Junior Member
Akebonos are great for dust but I just can't get over the nasty spongy brake feel. I love the initial bite on the OEM pads, and am thinking of switching over to red stuff to try to get that back without getting the same level of dust.
Too bad theres no Hawk pad application for our cars!
Skip on the EBC stuff. I've been using them on a couple of my cars but not they're not very impressive. After a little while the pads look like charcoal and crack/chip, and I ended up with about the same amount of brake dust for both the EBC red and yellow brake pads.
New OEM pads. I had them put on, ZERO dust. Its insane. The rears get dirtier than the fronts now.
rears old oem part.. fronts new oem part.
AMG3.2
close
- Join DateJun 2011
- LocationSilicon Valley, CA
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveC63 AMG, P30
Liked:171 Times in 146 Posts
I've heard nothing but great things about EBC red pads. I've never actually had them on my car though.
im not sure what pads i have as i havent had the car long but after one 30mile drive i have loads of dust
ExploreSuper Member
I just installed Akebono pads and Balo rotors and so far I have lots of dust. I thought that they were dust free? Maybe after they get wore in a little? The bite feels the same as the oem pads.
Mike T.
Mike T.
have had akebone for 10,000 Km. almost no dust good bite no squel. have u changed fluid & bleed brakes properly ? i am 100 % happy.
I cannot recommend Disc Itailia from brakeworld enough. I do not track the car so I can't discuss fade. But absolutely no brake dust. Feel is great too.
http://www.brakeworld.com/ProductLis...&mod=C32%20AMG
Disc Italia Hyper Ceramic
EBC
....used them B4 on my other cars and it seems to deteriorate if the car is autox'ed or tracked.
Akebono Ceramics
....little to no dust but stoppind distance not as good as oem but unnoticable for daily driving or even auto'xing.....
if your brakes feel "spongy" you probably need to bleed your brakes. You shouldn't feel a difference regardless of what pads you use, just a difference in the stopping distance.
....used them B4 on my other cars and it seems to deteriorate if the car is autox'ed or tracked.Akebono Ceramics
I'll swap out my old ones RIGHT AWAY!!!!Originally Posted by pointman
New OEM pads. I had them put on, ZERO dust. Its insane. The rears get dirtier than the fronts now.rears old oem part.. fronts new oem part.
NOT!!!
I thought the Akebono's were great until I switched them out for Porterfield RS4's and realized how mediocre the bono's really were. Of course the akebono's were half the price. Though from TopBrakes.com $119 was pretty reasonable for the RS4's compared to the $170 from Porterfield themselves.
Quote:
How are the Porterfield's with Brake dust?Originally Posted by 02C32guy
Quote:
NOT!!!
NOT!!!
kent426
close
So you can't have your cake and eat it too, all the manufacturers that have great stopping pads put out dust. No dust equals no stopping.
Do not use EBC Redstuff for the street, they are a track pad, you will crap your pants because they do not stop when cold. I run EBC yellows, the dust is not as bad as stock but they stop great.
I can't get any of these makes you guys can as I'm in the UK.Originally Posted by kent426
So you can't have your cake and eat it too, all the manufacturers that have great stopping pads put out dust. No dust equals no stopping.Do not use EBC Redstuff for the street, they are a track pad, you will crap your pants because they do not stop when cold. I run EBC yellows, the dust is not as bad as stock but they stop great.
But i can get EBC from my local supplier....
so you reckon i should go for the yellow stuuuf?
Cheers.
The redstuff is the street pad and the yellow stuff is the street/track pad.
Like previously stated, skip on the EBC stuff. The way these pads deteriorate before the life of the pad is up is ridiculous. They get a bit squeeky too.
kent426
close
I don't know where you are getting your info from? I use my Yellow stuff on the street and track, have no issues with wear or squeaking, I have 10K on them so far, in one track session with stock pads, I took out 30% of the pad life.Originally Posted by firstshadow
The redstuff is the street pad and the yellow stuff is the street/track pad.Like previously stated, skip on the EBC stuff. The way these pads deteriorate before the life of the pad is up is ridiculous. They get a bit squeeky too.
Yellow stuff is an improvement over Red, Red was almost meant as a track pad like HP Plus, they work excellent when they are hot.
http://www.ebcbrakes.com/selector.shtmlOriginally Posted by kent426
I don't know where you are getting your info from? I use my Yellow stuff on the street and track, have no issues with wear or squeaking, I have 10K on them so far, in one track session with stock pads, I took out 30% of the pad life.Yellow stuff is an improvement over Red, Red was almost meant as a track pad like HP Plus, they work excellent when they are hot.
I don't know Originally Posted by kent426
maybe straight from the source - the EBC website. *edit* Dang, beat by Gramma_Benz, hahahaI ran the red pads at the El Toro / Top Gear US track for a day and a half, 15 minute sessions, and by the time I was done the rotors were glazed and the pads toast. Every few days they would build up brake dust in the caliper and make the brakes squeek unless I braked hard. I'll upload some pictures of the toast redstuff pads w/ glazed rotors tomorrow night for reference.
Currently on the yellowstuff pads and the rears squeek sans hard braking. Maybe I'll snap some pics of them when I put the car up on jacks for the next service.
