Upgrade c55 brake
Old Sep 10, 2014 | 05:44 PM
capo_vendetta's Avatar
Mercedes C30 amg, Mercedes C32 amg, Mercedes C55 amg
Upgrade c55 brake
How can i upgrade my c55 front brakes without replacing the brake calipers.
I want to use my original 4piston brake calipers but i'm not pleased from the rotors. now i'm using ATE discs with Ferrodo shoes. they don't fade but sometimes they 'shake'. not always.
in the beginning i used the OEM rotors with OEM shoes but they were rubbish
Old Sep 10, 2014 | 06:27 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I find no issues with the stock OEM rotors
Old Sep 10, 2014 | 08:19 PM
dsp_tdi's Avatar
2005 C55
EBC yellow or carbotech.
I'am very happy with ebc yellow for track and street use. Also new brake fluid and brake line are a good idea.
I think the best rotor are the oem, powerslot looking good but I never try it. Also you can having 2 pieces rotor, but they are very expensive.
I having the same problem with ate and I crack them. I think that vibration are come from the brake deposit on the rotor. Right now, I run ebc plain rotor and it's a bit better. But I am not sure if the ebc rotor are not a basic Centric rotor. It's write the Centric number on them and they are not balanced.
Do you track you car?
Old Sep 11, 2014 | 09:22 AM
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
You've got a lot of options for rotors and pads. As dsp said, SS lines and better fluid are good, essential if you track the car.
I'm currently running Stoptech drilled rotors all around with Akebono ceramic pads. The Akebonos are great for street use and they generate very little dust, but I wouldn't recommend them for track use. Stoptech rotors are definitely reputable and paired with some better pads would prob be great for track use
(with of course also SS lines and fluid).
Planning on eventually doing SS lines and fluid and will probably go with EBC red or yellow. Disc Italia also makes a very nice set of rotors but they are very $$$$. I had these on my C230 and they are very nice rotors.
http://www.brakeworld.com/Product/Pr...1-brake-Rotors
Old Sep 11, 2014 | 09:54 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
The "shake" is probably glazing due to not heating them up enough to burn the glazing created between the pads and rotors. A few hard stops from 60mph or so should get them feeling smooth again. Obviously, do it somewhere deserted and safe.
ATE discs and Ferodo pads are a great setup, IMO. I used to auto-x a VW on those brands and could damn near lift the rear of my hatchback off the ground.
Try the anti-glazing stops before shelling out money.
Old Sep 11, 2014 | 10:58 AM
When i used the OEM brake pads, they "burnt" and left a hard layer on the pads. afterwords it was like the brake pad was 'finished', like it's metal on metal.
i've already replaced the brake fluid.
Sometimes i go on track but here we have some 'rally' roads...
I'll try the anti glazing stop. thanks!
Old Sep 23, 2014 | 04:23 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
If your looking for true performance two piece rotors,
check out what RacingBrake has to offer.
Front C32/C55 AMG W203 two piece rotors
Our light weight two piece rotors will shave off a couple lbs off your car increasing your handling, acceleration, and braking performance.
Weight
One-piece 26.7 lbs.
Two-piece 19.0 lbs.
Weight Savings: 7.7 lbs.
That's a total of 15.4 lbs!
Check out these reviews made by other MB owners.
Racing Brake makes me happy
World's First: RacingBrake 2-Piece Brake Rotors ...
The Ultimate Rotating & Unspring Mass Reduction Thread ...
E63 Front Rotor Replacement DIY - RacingBrake
https://mbworld.org/forums/sl-class-...squealing.html
Old Sep 23, 2014 | 04:26 PM
Thanks, i'll reconsider the rotors.
Old Sep 24, 2014 | 06:43 AM
swedepat's Avatar
2011 C63 AMG, 589hp
Interesting, i got some Ferodo uprated pads, and as you describe.
the shake from time to time.
I´ve been cleaning and cleaning, torquing the rims etc etc.. still sometimes they shake.
Might have a solution to my problem here, Thanks!
Old Sep 24, 2014 | 09:42 AM
C230 Mulac's Avatar
I feel like 2-piece rotors would be great for reducing unsprung weight but man they are expensive
Old Sep 24, 2014 | 11:59 AM
CLS550
Couldn't agree with you more,
but like the saying goes " you get what you pay for"
One thing to keep in mind though.
We offer our two piece rotor customers rotor ring replacements.
Once its time to replace the rotors, the only thing to purchase is our rotor rings.
they come with all the necessary hardware and instructions for a quick and easy ring swap. (Very straight forward!)
our rotor rings come in a pair for the price of $536.90
as opposed to paying $976.18 for the complete two piece rotor.
saving you a fraction of the cost!
http://www.racingbrake.com/C32-AMG-F...401-02-381.htm
Old Sep 24, 2014 | 12:11 PM
C230 Mulac's Avatar
Definitely get what you pay for. Something I would look into for the future for tracking the car.
If there is enough interest, would Racing Brake maybe do a group buy discount if say, 5 or more people wanted in for a set?
Old Sep 24, 2014 | 04:29 PM
CLS550
Certainly possible!
depends if we get enough requests,
if we do we may be able to.
Old Sep 25, 2014 | 07:43 AM
C230 Mulac's Avatar
Originally Posted by RacingBrake
Certainly possible!
That's great! I'll talk to some guys this weekend at our monthly dinner meet. Other forum members, feel free to chime in as well.
Old Sep 25, 2014 | 11:29 AM
cm60k's Avatar
Petar,
Rims looks Nice, are those ML's..?
ZAYED,,
Old Sep 26, 2014 | 07:45 AM
C230 Mulac's Avatar
Originally Posted by cm60k
Petar,
ZAYED,,
Thanks man!
Honestly not sure which model has them stock, but I think it's the newer S class. Maybe the ML? These are reps though
Old Oct 15, 2014 | 01:43 PM
dre5373's Avatar
2006 C55, 1995 C36
Certainly possible!
Your website lists the specs and price for the 2118 front rotors, but the link for the 2285 rear rotors take you to a kit for a W204 C350.
1. Do you make a 2-piece rotor for our stock rear calipers?
2. If so, could you kindly supply pricing and specifications?
My fronts are about due for replacement so it's decision time!!
TIA
Old Oct 16, 2014 | 01:41 PM
CLS550
TIA
Unfortunately we do not,
we only have the front two piece rotors.
Old Oct 19, 2014 | 07:15 AM
EVOII_Racer's Avatar
Mercedes Evo II
Weight
One-piece 26.7 lbs.
Two-piece 19.0 lbs.
Wow damn that's awesome!
