when to shift
Old Jan 23, 2004 | 10:56 AM
slobote's Avatar
c32amg
when to shift
Can anyone tell me how fast my c32amg is going at 6000 RPM in each of the gears. The tach is small and I would like to use the large cluster MPH to tell me when to shift.
slobote
Old Jan 23, 2004 | 11:19 AM
AMG BRED's Avatar
CLK63 Black Series
damn man.. the Tach aint that small..
Old Jan 23, 2004 | 12:51 PM
MgnFicnT's Avatar
'02 C32 AMG
its an auto, what do you need to shift for?
Old Jan 23, 2004 | 01:17 PM
AMG BRED's Avatar
CLK63 Black Series
maybe he has a special ordered AMG tranny that's 7 speed manual with twin-plate clutch.
he is talking about touch-shift..
Old Jan 23, 2004 | 01:19 PM
cschow's Avatar
2006 Corvette Coupe
According to Road & Track:
1st . . . 6,000 rpm = 38 mph
2nd. . . 6,200 rpm = 64 mph
3rd. . . 6,200 rpm = 100 mph
4th. . . 6,200 rpm = 141 mph
5th. . . 5650 rpm = 155 mph (governed)
But without the "M" mode in the transmission how are you going to force upshifts? I think the transmission computer will just do it for you when it hits 6,000 or 6,200 rpm if you're driving hard, and less if you're not.
Old Jan 23, 2004 | 02:21 PM
MiamiAMG's Avatar
C63
What is "M" mode? I've never heard of that. With the AMG speedshift, you can downshift & upshift manually. It will not do it automatically.
Old Jan 23, 2004 | 02:54 PM
Carl AMG's Avatar
2002 C32 AMG Orion Blue Charcoal/Blue
No M mode on a C32 in the U.S. but the M mode only shifts when told to by the driver. If your C32 doesn't automatically upshift when approaching redline in any gear setting run to the dealer!
Try this...put your car in "1" and floor the car to run up to redline. Don't touch the shifter at all and watch it shift to "2" automatically at redline. The transmission will continue to shift automatically at redline without your intervention until you back off the throttle so as to not approach the redline. For example, if you run to redline in first and second and then back off in third the transmission will remain in "3".
Old Jan 23, 2004 | 03:11 PM
KL316's Avatar
03 silver C32 AMG
so for best results, if i was to punch it while going 60mph on the freeway, i would downshift from D to 2nd gear correct?
an if i was going 80mph i would go rom D to 3rd gear then?
Old Jan 23, 2004 | 03:26 PM
Carl AMG's Avatar
If you leave the trans in "D" you're not going to see the number on the dash of what gear you're in; it will always say "D". In the situation you described all you need to do is punch it and the transmission will down shift to the appropirate gear for your speed via the "passing gear" kickdown.
You really don't need to overthink the transmission but a thorough read of the owner's manual would be a good idea.
Old Jan 23, 2004 | 04:04 PM
arthur12345's Avatar
to chrisc32
who is the girl in the blue shirt (your signature)?
Old Jan 23, 2004 | 06:28 PM
Pierre32///AMG's Avatar
Porsche Turbo Stage 4, Cayenne S ... gone C43, C32, ML55 & Ducati 999.
According to me:
1st . . = 42 mph
2nd. . = 69 mph
3rd. . = 108 mph
4th. . = 154 mph
5th. . = 186 mph
...using stock 17" with a red line of 6.225 RMPs and "S" mode.
Old Jan 24, 2004 | 02:08 PM
jcanabal's Avatar
2006 SLK 55 AMG
3rd?
Is that stock numbers or your moded C32?
I don't think mine shifts 3rd at 108! I think it is around 103-104 in mine.....huuummmm!!!
Old Jan 25, 2004 | 03:34 AM
this is what my car was doing with 17"...
with 18" (255/35/18) changes a bit..
1st . . = 42 mph
2nd. . = 70 mph
3rd. . = 110 mph
4th. . = 156 mph
5th. . = 189 mph
