C32 Launch
Old Dec 31, 2015 | 08:42 PM
LGAFF's Avatar
2011 E550 Coupe, 1992 Corvette ZR-1, 1991 368ci ZR-1, 1990 ZR-1, 1987 Callaway TT, 05 SL600, CLA45
C32 Launch
I have an 03 with 118K miles on it...its a daily driver for me, I have several 500+hp vettes for fun. The C32 is strong from a roll....but if you launch from a stop it does not even break the tires loose,it bogs.....how would you describe your cars launch from idle?
Old Jan 1, 2016 | 04:32 AM
C3Duece's Avatar
2002 C32AMG
my car screams off the line and I'm still on the stock pulley. I've got a good set of conti tuned in a 255 out back and I really need ease into the throttle for the first 30 feet to keep from going up in smoke. Once I'm out 20-30 feet I can matt it and it blasts off.
It feels every bit as fast as my 6spd, 400hp/406tq mustang it replaced.
Old Jan 1, 2016 | 09:07 AM
LGAFF's Avatar
and thats an off idle launch? I thought the delay might be to the supercharger not engaging until 1500
Old Jan 1, 2016 | 09:42 AM
Morphh's Avatar
C32 amg
I have pulley tune, intake, and first gear is completely useless all tire spin. Even if I try it from roll it's just useless. Even when I hit it second gear 60-70 kilometers my esp lights up
Old Jan 1, 2016 | 09:58 AM
LGAFF's Avatar
Is that just with ESP off? or dyno mode?
Old Jan 1, 2016 | 11:35 AM
Morphh's Avatar
C32 amg
Just with esp off
First gear is literally useless, even breaks lose in second gear
Make sure ur IC pump working that would rob u of all ur power
Old Jan 1, 2016 | 12:12 PM
C32Mark's Avatar
E55 AMG
In esp mode mine starts to spin and esp kicks in. Esp off mine melts the tires off off and fish tales as long as your in it. These cars have roots style super chargers so it's instant boost. I think you have something else going on.
Old Jan 1, 2016 | 01:17 PM
///AchMeinGott's Avatar
none... for now
Im 99% sure it's "always" engaged. The "full torque off idle" phrase is true, as soon as the ECM reads throttle input, not XXXX rpm, any top-mount supercharger makes boost. The only time it's not making boost is when there's steady state, limited throttle cruising and a bypass valve opens, or in MB's case the electronic S/C clutch disengages(the reason I say 99%).
Old Jan 1, 2016 | 02:17 PM
LGAFF's Avatar
At full throttle I am making 190-198 KPA, which I believe is about 13-14 pounds of boost. IAT temps are low....I noticed timing is -8 to -10 at idle; not sure what is normal.
Old Jan 1, 2016 | 02:30 PM
Morphh's Avatar
C32 amg
I hit 16.7 psi boost in first with my mods and then goes up to 229 kpa in third gear
I'll check my timing for u
