FutureAMGxx's C55 Build Thread
Old Apr 19, 2020 | 12:10 PM
  #126
FutureAMGxx's Avatar
C55 AMG
Originally Posted by eurochargedw210
What kind of power did those needswings intakes make? Have you dynoed since the headers?
Pretty negligible, I have since put the stock airbox back on. I only dynoed it the one time so far!
Old Apr 19, 2020 | 01:02 PM
  #127
Robjr's Avatar
Veteran: Army
2005 Mercedes Benz C55 AMG..1967 Lotus Europa..1987 Lotus Turbo Esprit HCI..2020 Mercedes Benz E350
Future....
Thanks for the info.........The Bilstein rep told me that shocks/struts for our C55's automatically lower the car as they are shorter in height from the factory right out of the box. I'm not interested in any lowering as I'm running Michelin's 275/18's on the 9.5" wide rims on the rear and 245/18's on 8.5" wheels in the front. I've got a fender roller which was necessary to mount the new wheels. Here's a few pics........
Rob
Old Apr 20, 2020 | 07:40 AM
  #128
C55 AMG
Looks good Rob! I did some measurements once I got everything adjusted to where I wanted it and you may be able to still run those sizes with lowering it a bit- depends on the offset/backspacing of your wheels. But yes I believe the window of adjustment is 1.2-2.4 inches, so it would automatically lower you over an inch minimum.
Old Apr 20, 2020 | 07:46 AM
  #129
C55 AMG
I forgot to add I also got the carbon fiber front lip from Gary last spring.
Old Apr 20, 2020 | 10:53 AM
  #130
Robjr's Avatar
Veteran: Army
Future.....
Thanks for the compliment....Also, your car looks very good and the upgrades, i.e., mechanical/cosmetic, etc., certainly enhances the car and provides great pride of ownership, too!
Well, because of my new wheel widths.....all of the manufacturers of coilovers, i.e., Bilstein, Megan Racing, KB, Koni, Spax, etc., will drop the fender right on top of the tires. It would literally require quite a large fender roll to clear and avoid any tire rub. I also think the shock/strut would have to be set on the most rigid setting, too!
I used to buy my front lips from a company in Walnut but they lowered their quality on the last one I bought. So, after another concrete parking bumper mishap, I bought my next lip from Gary Suvneer (Pomona) and the quality is top notch. Plus, no shipping since his shop is only 9 miles away!
Thanks, too, for the confirmation of the "out of the box" lower ride height as per Bilstein. At 124,000 miles on the clock, my shocks/struts are still good to go. But I'm watching and testing them for leaks/sagging every couple of thousand miles. Keeping fingers crossed.
Rob
Old Apr 20, 2020 | 11:07 AM
  #131
amgen's Avatar
C55 AMG T with Kleemann K2 and some stuff: 414 hp and 562 Nm :-)
One way to adjust the ride height in the rear is to change the rubber bushing on top of the spring.
They come in 4-5 different thicknesses and can be easy recognized by the dots on the side if
you take the wheel off.
Old Apr 20, 2020 | 12:41 PM
  #132
Robjr's Avatar
Veteran: Army
amgen.......
Great point...that could do the trick.......would FCP Euro/ECS Tuning have the various thickness? ECS Tuning has them at 5mm, 9mm, 13mm & 17mm height and priced from $5.55 to $10 each....
Thanks....
Rob
Old Apr 20, 2020 | 12:51 PM
  #133
amgen's Avatar
I do not know that.
Mercedes have them for sure!
Old Apr 21, 2020 | 08:51 AM
  #134
Robjr's Avatar
Veteran: Army
Amgen..
Hi......yeah but at what price? I have a wholesale account and I'll check it out later this am when they're open.
Rob
Old Apr 21, 2020 | 09:20 AM
  #135
amgen's Avatar
These rubber bushings can´t be expensive.
These rubber things are discussed here before in other threads, search and you will find!
I´m going to change mine after aggressive driving on Autobahn last summer, they have
collapsed a bit. I´ve already changed springs and dampers (OE) but didn´t think of collapsed
bushings, now I do thanks to my excellent MB-technician. Problem is the tyre can touch the
inner wheelhouse in certain cases with my 255´, I want to raise the rear on my wagon, but
how much is still an open question.
Old Apr 21, 2020 | 12:03 PM
  #136
Robjr's Avatar
Veteran: Army
Amgen......
Retail price for the 5mm bushing is $13 and $15 for the 17mm. Wholesale is about $5 less each.
Rob
Old Apr 21, 2020 | 12:28 PM
  #137
amgen's Avatar
Thanks Rob.
I live in the northern Europe but for other forum members your price information can be useful!
I will decide with my mechanic the rear ride height when I visit the MB shop.
Old Apr 21, 2020 | 02:50 PM
  #138
Robjr's Avatar
Veteran: Army
Amgen....
You're welcome
Rob
Old Apr 23, 2020 | 11:58 AM
  #139
Franci's Avatar
C555/SLK32/Lancia Delta Integrale/Jeep Wrangler JK
Originally Posted by Robjr
Future....
T
Very very nice build - would love to get those carbon parts - can you share a link where to buy?
Old Apr 23, 2020 | 01:50 PM
  #140
Robjr's Avatar
Veteran: Army
Franci.....
Thanks for the nice comments.......The cf front lip was purchased from Gary Suvneer on MBWorld vendor (he works 9 miles from me); the cf diffusser was purchased on Ebay from seller AAAmotors; I hand layed the cf canards (I'm a old surfer with extensive fiberglass repair experience); lastly, the interior cf stuff was purchased on Ebay several years ago from an individual seller.
Good luck.....
Rob
Old Apr 23, 2020 | 02:21 PM
  #141
brauhaus313's Avatar
asdas
Originally Posted by FutureAMGxx
Just finished the install of the bilstein b16 pss9 coilover kit. It gives the car a nice ride and let's me adjust the ride height at all 4 corners. This kit also has 9 different firmness settings that adjusts the valving inside the shocks.
Does it ride nice compared to stock, or a nice ride for coilovers?
Old Apr 23, 2020 | 04:58 PM
  #142
Morphh's Avatar
C32 amg
I have same pss9 It has transformed my car the way it rides, it has tighten the car
Old Apr 23, 2020 | 06:18 PM
  #143
Robjr's Avatar
Veteran: Army
Morphh...
Did it loosen any tooth fillings....lol ...? After finding out that I can install thicker coil spring to bushings, I'm pricing the B16 PSS9's.....should know tomorrow who's got the best price from reputable retailer.....
Rob
Old Aug 3, 2020 | 05:34 PM
  #144
chicago_fog's Avatar
see signature
any updates?
Old Aug 3, 2020 | 06:16 PM
  #145
Morphh's Avatar
C32 amg
No not at all the best mod I have ever done but I redid front and rear suspension at same time.
the rear bushing that the spring fits in u have to buy separate I went 3dot
Old Oct 1, 2020 | 10:23 AM
  #146
see signature
Thanks! Yes basically, they came off an 05 slk55 the 340mm 6pot! I also have the 4 pot rears. Getting ready to sandblast and repaint them!
Did you end up putting a 2.5mm spacer on the fronts if you used the c55 rotor?
Resurrecting an old thread...does anyone have the part numbers for the larger calipers that will fit the C55?
Old Oct 1, 2020 | 09:20 PM
  #147
robbyt18's Avatar
C55, w211 E55, ML320 CDI
First Option Front Calipers: r171 non 030 SLK55, w209 CLK55 (340 mm rotor)
R 003 420 48 83
L 003 420 47 83
Second option Front Calipers: r171 030 SLK55, w209 CLK63 (360 mm rotor)
R 003 420 68 83
L 003 420 67 83
Rear calipers
R 003 420 30 83
L 003 420 29 83
Old Oct 2, 2020 | 12:31 AM
  #148
see signature
R 003 420 48 83
L 003 420 47 83
R 003 420 68 83
L 003 420 67 83
Rear calipers
R 003 420 30 83
L 003 420 29 83
Wow! Thank you --and great avatar. I've wanted a pair of 6's my whole life the Infrared's have escaped me.
