Help! C32 Transmission Gone - Can a Crossfire one be used for swap?
That plate sits on top of the valve body. That stuff unbolts from the bottom once your have the pan off. It does not require full transmission disassembly.
There's a chance that your conductor plate is part of the trouble you're having now. New plates must be coded when they are installed.
There may be internal valve body differences between the chrysler versions and the C32, that I don't know.
As the guy above me said, I would start by replacing your conductor plate and harness plug, as that is often the cause of the issue you're seeing. The rest of the 722.6 is very good, and quite durable.
P2600 The voltage supply of circuit 87 has under voltage
P220A the speed comparison of Y3/6n2 to Y3/6n3 is Implausible
P2222 the signal of component Y3/6b1 (transmission oil temperature sensor) and or Y3/6s1 (starter lockout contact) is implausible
P2502 the gear is implausible or the transmission is slipping
I did a full ATF flush a few months ago as I had the Valeo radiator and and I specifically asked the indy to replace the connector as they are known to leak. So if I'm not mistaken, it probably leaked and ruined my conductor plate? Now I wonder if my TCU is flooded with ATF as well, though I have never seen a single drop of oil on the floor. I hear a whining noise when pressing the gaz on cold start. After a while the noise goes away. The car is a 2003 one but was built late 2002 and has only 90K miles.
Hopefully some people can shed more light
UPDATE: further research are indicating a ruined torque converter causing that whining noise. Can this happen in a span of 6 months? Full flush was done 6 months ago.
So this is my plan:
- check transmission filter to see if there are any metallic debris - replace torque converter
- check conductor plate if flooded with ATF - replace conductor plate
- check TCU if flooded with ATF - clean
