supercharger problem !!!!! need help
here are some pics of my new rims
and here's a pic of the rear lip
SC Clutch - You may want to also see if the SC clutch is engaging, you can remove the electrical connection on the clutch and see if there is no difference.
One way you might be able to tell: If the car is cold, and you start it up do you get any feeling of a normal level of power if you immediately launch the car. If its the clutch the S/C will never engage and you'll never make boost. If its the water pump, the S/C should engage until the IAT goes above a certain threshold, and then to prevent heat damage the S/C should be disengaged by the clutch. (Unless the IAT jump up so quickly with a broken water pump that you don't have time to test this).
