tranny drain plug won't budge
Old Jan 9, 2008 | 04:09 PM
toamend's Avatar
99 C43
99 C43, 83k miles. I was trying to drain the tranny and put in some new fluid for maintenence reasons. I had the shop do this when I bought the car (at 40k miles) but this time I was doing it myself.
I cannot budge that little ***** of a drain plug. As far as I can tell it's a 5mm hex socket, but that size feels alittle loose to me. My question is should I just drop the whole pan (torks bit) and then drain the TC as well, or can I pump out the fluid through the dip stick tube with a fluid extractor?
I realize that you can only get about 4 quarts out from the pan and the rest is in the TC. Speedybenz seemed to have good luck just swaping out 4 quarts at a time as a hassle free way of doing it.
Todd
Old Jan 10, 2008 | 12:13 AM
MBHustla858's Avatar
might wanna get a new drain plug before you pull that one out, the threads might be fugged, and run a tap through it to make sure the threads are clean.... you can roatate the TC to expose the drain plug and drain that as well. once u drain the TC and pan, add 4 quarts, start the car and add about 4.5 more and check it.... should be right
Old Jan 11, 2008 | 02:20 AM
speedybenz's Avatar
AMG C43, 1999
Try putting in your 5mm hex and then giving it a firm tap or two with a medium wt. hammer. Often that will free up the bolt by the impact. It also seats the hex into the bolt better so you have less chance of stripping the internal hex portion of the bolt. If the 5mm is loose try a 27 or 30 torx drive instead. It is one of those sizes that is slightly larger than the 5mm hex drive.
A good impact driver will also help complete the task.
Jeff
Old Jan 11, 2008 | 02:23 AM
BLACKROOF C55's Avatar
C55 AMG
Jeff
+1 WD40
Old Jan 11, 2008 | 05:48 AM
1via's Avatar
1996 Volvo 850 Turbo Wagon, 1991 Nissan 240sx track car
Originally Posted by BLACKROOF C55
+1 WD40
WD40 sucks compared to PB blaster and other comparable penetrating catalysts.
PB blast it, let it sit for a bit then try the plug again with some better leverage(pipe on socket seems best in this case). Keep at it.
Old Jan 11, 2008 | 06:25 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Try this idea...
If it becomes too much of a pain, go to a lube shop and find out if they have a Wynn's ATF flush machine - tell them you'll provide the fluid (preferably MB's - I used Mobil One Synthetic ATF). Ask them ahead of time and secure a price...I paid $68 more or less plus the cost of my transmission fluid. This machine will exchange your fluid via your cooling lines one-for-one. At 83K on your odometer, your filter can wait until the next service interval - or simply drop the pan for the next interval and replace the filter and fluid in the pan one-for-one.
Old Jan 11, 2008 | 07:57 AM
toamend's Avatar
99 C43
thanks guys I'll be back at it this weekend.
Todd
Old Jan 17, 2008 | 04:25 PM
TENNAc43's Avatar
1998 C43, 1995 Landrover D90, 1999 F250 Diesel, 1996 Lexus ES 300
Trans question
I have just bought all of the stuff to change my Trans fluid. The stuff from the dealer cost a total of $35. That is for a gasket and a bolt. The fluid I got from Advance Auto, Royal Purple ATF, $108 for a case. Is there anything else that I need or need to look out for?
Old Jan 17, 2008 | 05:16 PM
StapleGun's Avatar
Did I miss something - If you're gonna be there already where's your AT filter? It just pops in...
You're also going to need the red cap lock in order to secure the little cap for the 'what looks like dipstick' but will be where you refill your trans fluid. They're like .86 at autohaus LINK
You should have asked first, that kit is $15, here's a link for the gasket kit and filter too...LINK
Old Jan 17, 2008 | 05:25 PM
ohlord's Avatar
Just a quick question?
What are you guys doing putting regular fluid in a 722.631 trans?That was fine for the 722.4 but will surely lead to short trans life in the 5 speed.
diy for the 722.6 on
http://www.benzworld.org/forums/w210...1-06-08-a.html
and www.mercedesshop.com
you can use the new 7 speed fluid in the 722.6 but rp and mobil dex 3 clones will kill it sooner or later.
I have the special dip stick for 30 bucks delivered in the 48 lower.
And one caveat never use a lint rag or any rag prone to shedding wiping down the pan or insides of the trans,these 722.6 are very sensitive to any dirt dust or lint
Old Jan 18, 2008 | 11:32 AM
TENNAc43's Avatar
Thanks,
Thank u guys for the added advise. I have only had the car for one month and I am very green. I am taking the parts I bought from the dealer back today. Autohaus is the only way to go, thanks again. I also purchased a drag link and motor mounts, no I dont plan on doing this myself.
I know that there are discussions out there about trans fluid but is it a fact that we should only us MB? Everyone that I have spoken with says that Royal Purple is the way to go.
Old Jan 18, 2008 | 01:31 PM
Back2Benz's Avatar
Gone but not forgotten C36
What happened to the parts from the MB dealer? Issues?.
Old Jan 18, 2008 | 01:55 PM
ohlord's Avatar
Price
parts at autohausaz.com and germanstar.net are a fraction of the dealer prices for oem or oe products.Buying them and doing the diy jobs you are capable of doing is one way of making the so called "most expensive used car you can buy is a benz",not so expensive at all.
ohlord
Old Jan 18, 2008 | 02:23 PM
Back2Benz's Avatar
I got great service from autohausaz also...ordered about $200 bux of stuff that might have costed about $400+ and they shipped it the next day (cuz I ordered late in the day)!...can't wait to have my friend work on the car.
Old Jan 18, 2008 | 02:33 PM
TENNAc43's Avatar
The parts were fine they were just twice as expensive as the parts on the net. I simply took them back and said I found them cheaper. Here is a pic of my car "CAPONE" stock C43 98. I have only had it a month or so and I love it. I just want to take care of it like a child!
Old Jan 18, 2008 | 03:50 PM
ohlord's Avatar
Air filters
oil filters suspension parts all much less and don't forget free shipping over 50 bucks.
Old Jan 18, 2008 | 06:27 PM
StapleGun's Avatar
Have used them for a while, they should pay me - I'm always 'pluggin' them.
TENNAC43 that car looks outstanding!
Old Jan 18, 2008 | 09:27 PM
Back2Benz's Avatar
yup!..they must have a very effective and fast shipping staff!
Thanks to ohlord and StapleGun for all your guidances in this forum (as well as others that I haven't mentioned)
Old Jan 19, 2008 | 07:28 AM
StapleGun's Avatar
No worries - always comes back tenfold, let us know if anything new develops...
