replace or no
Old Jun 24, 2008 | 03:22 PM
e30t387's Avatar
s/c 99 c43 amg
replace or no
so my brakes dont feel like they used to so i was thinking of replacing rotors and pads or can i just resurface the rotors and replace the pads?? i havent really found any good deals on rotors so far.
Old Jun 24, 2008 | 04:09 PM
MarcusF's Avatar
2002 CLK430
Mercedes rotors typically are not resurfaced. Use a micrometer to measure the thickness. If they're in spec, just put on new pads. If they're out of spec, AMG rotors are expensive.
If the brake pedal feels spongy or not as firm as it used to, you may want to change the fluid. I think the spec for fluid changes is every two years.
Old Jun 24, 2008 | 08:15 PM
ohlord's Avatar
fronts
see the most action and for same price as oem you can get cryo treated slotted
http://www.frozenrotors.com/search/i...electedIndex=7
then pick up a set of rears from www.autohausaz.com
http://www.autohausaz.com/search/pro.../Brake%20Rotor
and get a set of akebono pads from tirerack.com or oem pads from autohausaz.com
if rotors are dead smooth(mirror smooth)pm me and I can explain how to scuff them up and you can just install pads.
per above,they do not make them thick enough to put on a lathe.
ohlord
autohausaz.com may quote front directional rotors but for the price the frozen will last longer and stop faster than you will have the car.
Old Jun 25, 2008 | 10:44 AM
e30t387's Avatar
s/c 99 c43 amg
heard e430 and clk 430 have same rotors as us is that true.
Old Jun 25, 2008 | 11:00 AM
v0ac's Avatar
C43 AMG & E55 AMG
Same brake pads, not rotors, stick to AMG oem rotors, dont go with something else.
Old Jun 25, 2008 | 11:59 AM
MBHustla858's Avatar
fresh fluid should be the FIX. good luck!
Old Jun 26, 2008 | 09:04 AM
e30t387's Avatar
s/c 99 c43 amg
after taking the wheel off and having a closer look seems like the rotors are still in good shape its the pads that need replacing, i was thinking of going with the EBC green stuff of EBC red stuff what you guys think
Old Jun 27, 2008 | 04:06 AM
KJI3jflarryfe93's Avatar
Hey bud get some Portersfield R4S street pads, pricey but great, only downthing is they don't bite as good as the factory Jurids, I guess it's the compound.
Buy directly from Portersfield.com
Old Jun 28, 2008 | 08:57 PM
go w/ OEM pads, BIG DEAL if you blow thru pads, i'd rather replace 80 dollar pads then 500 dollars in rotors.........
Old Jun 30, 2008 | 09:24 AM
e30t387's Avatar
s/c 99 c43 amg
yea i guess your rite, where can i get oem pads from
