What are these leaks from? Are they serious?
Old Sep 7, 2008 | 02:51 AM
lupasa's Avatar
Silver 1999 C43 AMG
Hey Guys,
I changed my oil today and noticed these two areas underneath my car to be coverered in a shiny oily liquid. I've noticed it before but it seems to be getting worse for some reason. One is behind my oil pan and the other I think is the AC Compressor. It doesn't drip on my garage floor, so that's a good thing I guess, but it just seems to be covered in this layer of goop which does not make me feel confident in it's condition.
Could somebody let me know what exactly I've looking at and if it is serious enough to make repairs? How much will these parts/repairs cost me?
Thanks guys.
Attached Thumbnails What are these leaks from? Are they serious?-0906_175514.jpg   What are these leaks from? Are they serious?-0906_175534.jpg   What are these leaks from? Are they serious?-0906_175636.jpg   What are these leaks from? Are they serious?-0906_175738.jpg   What are these leaks from? Are they serious?-0906_175909.jpg
Old Sep 7, 2008 | 09:10 AM
£ C43 £ AMG £'s Avatar
E55K AMG
Have the same engine oil under mine, there might be a very small leak somewhere?
But I have put it down to all the oil fill ups that have dripped down from the top and also the oil filter changes which both can be messy.
Old Sep 7, 2008 | 04:36 PM
lupasa's Avatar
Silver 1999 C43 AMG
My oil filters changes are never messy and it nevers drips to the point of making those areas of my car look the way it's shown in the pictures.
Anybody else have some insite what could be the problem?
Old Sep 7, 2008 | 04:47 PM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
why dont you try cleaning up around the area as much as you can then drive the car around for a little while and recheck. that should help you locate the source of the leak...
Old Sep 7, 2008 | 07:20 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
I don't think that will pinpoint the leak. It looks like a gradual leak over time.
Old Sep 7, 2008 | 08:08 PM
SeeKlasse's Avatar
it will help pinpoint the leak. thats how dealerships and mechanics work to find leaks, the mechanics wipe it clean and wait for the leak to restart. the dealership steam cleans your motor so alot of the seal areas are spotless, making the discovery of the leaky area alot easier...
Old Sep 7, 2008 | 08:27 PM
midasmike's Avatar
'93 300CE
just spray the area with berrymans or pj1 then run it for a day. you'll see where the leak is.
Old Sep 7, 2008 | 08:59 PM
sickc43owner's Avatar
99 c43
oil leak
rear main seal-very common on 112 an 113 engines-front leak is possiblt from front cover psi plug cap running down
Old Sep 7, 2008 | 11:31 PM
MarcusF's Avatar
2002 CLK430
On the CLK55, there's an oil cooler next to the filter. I believe the o-rings harden and leak with age. Do C43's have that same oil cooler? If so, and the o-rings are leaking, I remember reading a "how-to" in one of the CLK55 forums. It was a rather simple fix.
Old Sep 8, 2008 | 04:24 AM
bevy's Avatar
C43 AMG, 512 TR, FIAT Coupe Turbo, Toyota MR2 MK2
Right, i have the same leak on mine, the oil is coming from the cooler just before the oil filter and fall on the AC compressor...
Old Sep 8, 2008 | 01:18 PM
lupasa's Avatar
Silver 1999 C43 AMG
Do you or anybody know where I could find the DIY article for the replacement of the O-Rings on the Oil Cooler?
Old Sep 8, 2008 | 03:44 PM
NitrogenBalance's Avatar
none
I posted a topic in this forum with really big pictures and a DIY instruction for the oil cooler gaskets. They are pretty small and amusingly expensive considering its a tiny bit of rubber.
Reading through the replys I think I'm going to check my rear main seal as I still have a little oil on the trans like in the picture...
Old Sep 8, 2008 | 03:55 PM
lupasa's Avatar
Silver 1999 C43 AMG
Found it, thanks Nitro.
Does anybody know how much this repair would cost at the dealership?
I'm in Seattle and would probably have it done at Phil Smart or Barrier.
Thanks.
Old Sep 8, 2008 | 04:32 PM
none
based on the amount of oil I cleaned up on mine I would say your leak is more than the oil cooler alone. It was very specific to the front area. I say this because mine is dry and the tranny pan still has a little oil on it, which I need to investigate.
I would get a mirror, check all sides of the oil cooler and clean it good. Check the bolts for tightness, then proceed. It may just be that the bolt(s) could be a liitle loose. You may get lucky.
