NEVER TELL ME YOU CAN'T....
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
I think you hate any car with a 5.5l motor blown or not.
The 4.3L motor is a nice motor and the 5.5L even better especially as an upgrade for the W202 C43.
ML320, Looking for my S4
No, I ment that you blew your 4.3L motor. Hence the tick tick boom thread, and I noticed one of your posts hinting towards you doing this as your next setup. No disrespect. Btw, I was that kid back at newport with the E320 about 2/3 years ago. I also delivered that c/f hood to you about 2 years ago aswell.
By the way nitro,I have not read the thread but did your motor really go bad?
If so your next move is very predictable.
Hey Tommy! I remember well, just wasn't sure if I was missing something by the way you wrote that.
Carl, it went kaboom alright..and I'm 99% sure it was my own fault
the handfull of metal and the completly drained oil pan confirms
I'm going to start a thread with pics when I start cleaning things up.
To keep this on the OP topic and not mine I have thought about the E55K swap. $ and capability will probably keep me to the N/A 55 swap. However, if a reciepe that can be easily followed pops up I wouldn't mind something like this.
The timing of his post is so ironic....*******s..
I'm going to start a thread with pics when I start cleaning things up.To keep this on the OP topic and not mine I have thought about the E55K swap. $ and capability will probably keep me to the N/A 55 swap. However, if a reciepe that can be easily followed pops up I wouldn't mind something like this.
I sometimes contemplate finding a nice Vortech kit for mines. But we'll see.
Right now Money-one is the man and I'm just chasing his progress.
However,I can assure you that you would love the N/A 5.5l option as well.
Nitro
You will like the amg 5.4L N/A motor. Especially if you use a better exhaust that gets rid of the precats. If you open up the intake side of things by boring out the MAF housing to 81mm and doing so with the elbow and if you cut the throttle body at a 7 degree taper to throttle plate you will get lots of extra flow.
With the intake changes and exhaust changes my ca r would run high 12 secs. at around 111mph if I recall right.
Anyhow while I really like the N/A engine the Kompressor engine would be awesome. That extra power would really put some steel in your stride.
Jeff
Jeff
The N/A 5.5 swap hands down the easiset swap. The only thing you had to do was re-route the cooling line on the back of the head for the factory trans. cooler on the C43. Everything else was plug and play. Don't forget reseting adaptations.
The 5.5 Komp. has a lot of little ignorant things that had to be done and modified. Too much to list. If you are Really intrested in this swap being done to your car I have pics.
This thing pulls quite nicely. No MAF clamp, No tune, No Coolant(waiting on radi.) and the fuel pump housing is leaking. Waiting on parts.....I hate waiting on parts
Would you mind sending me a PM about what this swap should cost without labor? I did plan on picking up the N/*** to replace my 4.holeintheblock, however I came across this.
http://cgi.ebay.com/ebaymotors/03-08...Q5fAccessories
I thought these sold for around 10K so this seems like a really good deal, too good maybe?
Sweet swap
Pay no mind to the folks that sipped a little to much haterade! Keep us posted especially on the tuning. I wanted to do this to my CLK 430 but was told it would be to expensive or wouldnt work with stock ECU or TCU etc.
I have to say that I am very angry at money for performing this swap. Now everyday at work when I see a 55 Kompressor engine, I sit there thinking about how much better it would look inside the engine bay of my C43. Thanks money for causing me to daydream and lose hours. :P
V12ttUpdate: Not sure what day it was but I finished making the intake pipe I let the car warm up and when the car got up to operating temp. #1 cylinder injector failed in the open position and flooded/fouled that cylinder. Replaced injector and plugs for that cylinder and she straightened out. 2 Fridays back the radiator and fuel pump came and were installed. This past wednesday I got the car to where i felt comfortable driving her home (going to go dyno thursday). 20 mins into the drive after several
hard 70-120ish pulls The last one gave out around 90mph. First to go was the coolant and second was the oil. Didnt take pics but everything was covered in oil including the whole driver side
Yesterday was spent cleaning the oil off and resecuring everything correctly. Today I wired in some resistors for the EGR and Air Switch Over solenoids. They were consistant codes but now after a 6 mile trip
Hard of course no, I repeat NO Check Engine. This is with 100% zero tunning. The MAF will i assume come on. Looking the car over I found the oil cooler line is trying to work its way off again
The cooler is too small and is acting as a restriction. And It also feels as though the bypass valve is not adjusted correctly there is a lag before kicking in. Buying a boost guage, UEGO guage and larger oil cooler.Few pics and vid. Please excuse my commentary.
http://www.youtube.com/watch?v=Q-GwnKcMeYM
I do what I can to help the community
You would never guess what I look at now and only think "Maybe if I waited a little longer that would probably fit"
V12tt
I need to plan a trip down there b4 fall. I'd love to see the beast.
Keep up the good work bro.
