started tear down for paint
Old May 17, 2011 | 05:51 AM
  #276
DRBC43AMG's Avatar
+1
I imagine the flap is to stop junk flying directly inside the intake tubes to the air filters. I even installed a second flap on the other side (M113 engines have two intake pipes). My worry is not so much junk, insects, stones, etc. getting in, but more the problem of water ingress when it rains. True, removing the flap(s) will improve air flow (+50hp minimum ), but even with the flap I can imagine the ram air effect of the moving car should be sufficient to get cool air in. Cool air is better than hot air taken from an intake in the engine compartment. Must also be a reason why the MB engineers put the flap there in the first place... If the flaps are removed, I guess you will need to clean (change) your filters more often.
Old May 17, 2011 | 10:46 AM
  #277
Saaboteur's Avatar
eclectic assortment of cars
I'll find out when I drive the car again. But the intake is relatively high, so I don't think it'll be a huge issue.
The intake snorkel on my S2000 is substantially lower, below the bumper rebar, plus the car is a lot lower than the AMG. That snorkel ingests piles of road crap. I dumped out a bunch of sand and general muck out of the intake box earlier this spring. On the S2000, I think I will add a piece of mesh to prevent the larger pieces getting in. Perhaps I will do the same with the AMG.
I'll post a pic later so you guys can see the comparison.
Old May 17, 2011 | 10:51 AM
  #278
DRBC43AMG's Avatar
A mesh screen is perhaps a good idea to keep the large muke out of the intake box, but it may reduce somewhat air flow less though than the flaps. I may just try that also
Old May 18, 2011 | 11:16 AM
  #279
Saaboteur's Avatar
Here's some pix of my S2000 for comparison. The intake is a Spoon replica - same shape, same mounting point, without the JDM pricetag! Nurburgring sticker adds 50hp too.
Anyway, the intake sits quite low to the ground, much lower than the grille on the C43. I'd be surprised if opening up the area on the C43 grille results in much more crap getting into the airbox. At any rate, all the stuff is stopped in the airbox by the filter.
I remember one of the S2000 guys, with a similar Spoon style intake, finding a dead mouse in his airbox. Ewww...it does provide an access point into the airbox for little critters.
Yesterday at Home Despot I picked up a roll of screen door material. I'm going to fix that to the intake on the S2k, and maybe on the C43 too.
Old May 18, 2011 | 03:21 PM
  #280
DRBC43AMG's Avatar
I see you have the 50hp sticker on the CF intake pipe. Nice and clean job.
Old May 18, 2011 | 03:50 PM
  #281
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Who needs a SC or 5.5 swap??? Combine the 50HP Nurburgring sticker MOD with the 50HP C43 grille cut out MOD and you just upped your ride 100HP!!!
Old May 18, 2011 | 04:46 PM
  #282
ob1kenobi's Avatar
moon buggy
Jacking your thread
whoring my former Silverstone S2000. It has 19k miles when I sold it to someone from Calgary.
Old May 18, 2011 | 06:31 PM
  #283
Originally Posted by ob1kenobi
Jacking your thread
That might be the cleanest engine bay I have ever seen
Old May 19, 2011 | 10:52 AM
  #284
Saaboteur's Avatar
Clean S2k! My car under the hood is.... not as clean! Charger going on this weekend though, should be fun....been waiting to do the install for months.
Back to AMG talk, here's a pic of the grille after two coats of Plasti-Dip.
Old May 19, 2011 | 06:16 PM
  #285
Not so sure the SC install will be fun but the final result will be
Good luck with the install
Old May 24, 2011 | 12:43 PM
  #286
Saaboteur's Avatar
Got the grille fitted back to the car, and thankfully too.
I didn't manage to finish my supercharger install on the S2000 over the weekend, so I'm driving the C43 this week. About 90% done, just need to tidy up some wiring and hoses, and should be good to go. Didn't want to rush last night, so going to finish it off this weekend.
Here's a pic of the grille and some pix of the charger install on the S2k:
Starting out with an NA S2k with some mild mods:
...to nearly finished supercharger kit install!
Old May 31, 2011 | 07:05 PM
  #287
Saaboteur's Avatar
Here's the finished product on my S2000:
and another photo for kicks:
Obligatory AMG content: looking forward to my upcoming roadtrip holiday to Vancouver. I've got a pile of parts waiting for me in my shipping depot across the border - most of which will find their way onto the 55 motor. Aiming to tackle the 55 swap in August
sometime.
Power adder filled summer!!!
Old May 31, 2011 | 07:31 PM
  #288
sometime.
So hows the power??? Are you satisfied with the finished result?? How does it compare to the C43?
Old May 31, 2011 | 07:56 PM
  #289
Saaboteur's Avatar
Yes, very cool, I like the charger a lot. It doesn't fundamentally change the character of the car, just adds power in a very linear way, just with a lot more of the same.
A lot of the larger components utilize OE Honda fasteners, which was very impressive. Unfortunately, once installed you can't see a lot of the bespoke brackets made by Science of Speed, the maker of the kit. They are gorgeous anodized black aluminum pieces.
Compared to the C43....the S2k is still feeble in the torque game! Stock the S2000 has about 155 ft lbs of torque (the torque spec to bolt up the crank pulley 192 ft lbs!!). With the charger, that's up to about 250 ft lbs, so stock the C43 still has more torque, but of course weighs 700 lbs more than the S2000. The S2k now should put out about 300rwhp, give or take, about a 100hp jump from stock.
Still have to wind up the S2000 to make power, but that's fine, that's the character of the car and why I like it. The C43 is very different, which is why I'm glad of having both.
Old May 31, 2011 | 09:01 PM
  #290
Motorsport3's Avatar
Dynocomped C43K, 08 X5
Hello Mr. Saabo!!!! how are ya??
Have you ordered the wavetrac lsd??? did you recieve them??
Old Jun 1, 2011 | 01:21 PM
  #291
Saaboteur's Avatar
Life is good now I have that charger strapped onto my S2k!
I haven't ordered a Wavetrac LSD. I wish I had put my name down on one, as I may have missed the boat. I understand there is a waiting list now, and that production may be limited. Boo. I was waiting also to see others' experience with them, I understand 320 Dreamer and AusMBTech had orders in.
Old Jun 1, 2011 | 04:48 PM
  #292
DRBC43AMG's Avatar
Glad you like both cars! Enjoy and use them well
Old Jun 4, 2011 | 06:07 AM
  #293
Yea.. I should have put my name on the list as well. The company seems to make good quality LSDs. I want an lsd so bad
Old Jun 22, 2011 | 11:34 AM
  #294
Saaboteur's Avatar
Went on road trip to Vancouver and northwest Washington, came back with piles of goodies!
There's about $300 worth of seals, gaskets and engine mounts in that photo (might have some S2000 stuff mixed up in there too though).
Now I can start tidying up the 55 motor and get it ready for the swap.
After that I want to get a new Bluetooth and iPhone compatible deck into the car, and maybe some gauges too. As much as I'd like to get European gauges, I think I may head with Autometer Phantom IIs - they are white faced during the day, but with night time illumination the faces are darkened - just like the stock C43 gauges.
Old Jun 22, 2011 | 01:15 PM
  #295
KJI3jflarryfe93's Avatar
me lajk the LEMFÖRDER parts.
Deutschen qualität über alles
Old Jun 22, 2011 | 01:20 PM
  #296
Saaboteur's Avatar
Yeah, the Lemforder is good stuff. Unfortunately, some of the parts were Meyle. I had one of their replacement fuel pumps and it was crap. Hopefully they can make a half decent seal though!
Old Jun 22, 2011 | 02:11 PM
  #297
ob1kenobi's Avatar
moon buggy
Off topic:
How many hours does it take you to get to Van city from Edmonton?
Which route do you take? Coquihalla?
Planning an August road trip to Vancouver Island (Tofino). I'm thinking of adding Edmonton in there too depending on the road condition and my available time.
Old Jun 22, 2011 | 03:53 PM
  #298
Saaboteur's Avatar
We took it easy and split it into two days, overnighting in Golden, BC both on the way there and on the way back. Edmonton to Golden is about 5ish hours, Golden to Vancouver (via the Coquihalla of course) about 7 or 8. It's doable in a day, my Dad used to drive it in one haul when I was a kid and we would visit the relatives there every summer. I think I might 'ironman' the drive next time and drive straight through without an overnight stop.
I think it's about the same distance and time whether you go the southern route via Calgary/Golden or the northern route through Jasper. It will be a bit longer further south via the Crowsnest Pass though, but there's the awesome Frank Slide area to behold in that region.
Old Jun 22, 2011 | 04:58 PM
  #299
Jovsky's Avatar
2000 C230 Kompressor Sport
Wow! Approximately 12-13 hours driving time. That's a lot of miles you've got there. Did you use the C43 in your road trip?
Nice black grille by the way. What exactly is "Plasti-Dip"? Is it a brand name?
Old Jun 22, 2011 | 05:01 PM
  #300
Saaboteur's Avatar
12 - 13 hours each way, plus driving all over Vancouver and our side trip to Seattle too! I think we put about 3,500km on the road in those 10 days. We took my wife's Land Rover LR3, actually. More room for stuff in the back!
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
