started tear down for paint
Old Nov 16, 2012 | 03:39 PM
  #776
Capn's Avatar
03' CL600
The 5.5 badge looks great
Old Nov 18, 2012 | 01:54 AM
  #777
Saaboteur's Avatar
eclectic assortment of cars
Kowalski - that looks like a decent piece, something along the lines of what I had in mind.
ProjectC55 - haven't done anything with the swap. Winter happened, a bit earlier than usual. We had snow before Halloween, and a big dump in the past couple of weeks too. I don't really want to get into such a big project in the cold, so I'm just gonna wait until spring. Everything's on hold for now, so nothing to report unfortunately! I'm keen for warmer weather to arrive, lemme tell you, I can't wait to get stuck in...
Old Nov 18, 2012 | 05:07 AM
  #778
KJI3jflarryfe93's Avatar
Old Dec 6, 2012 | 11:50 AM
  #779
found the proper w202 cover.
#202 828 00 30
you need to drill the holes yourself esé and then install 52mm gauges.
does anyone know the size of these gauge sensors for mercedes?
need to know size for Oil temp and oil pressure?
is it M14x1,5 or something else?
look at these pics, borrowed them from another bloke.
he used old style audi gauges for this mod
I will use white face VDO gauges to colormatch my speedo
Old Dec 6, 2012 | 12:00 PM
  #780
mbsickness's Avatar
1996 C36
Wow that looks really good...I might have to pay the dealer parts department a visit.
Old Dec 6, 2012 | 12:11 PM
  #781
DRBC43AMG's Avatar
Nice idea and great update.
If I installed such a panel, I would choose the following dials to monitor the following:
- Engine oil temperature
- Engine oil pressure
- Gearbox oil temperature/rear axle temperature with a two way switch
Old Dec 6, 2012 | 01:39 PM
  #782
I was thinking about this design
http://www.egauges.com/vdo_grou.asp?...Viewline_White
or
http://www.egauges.com/vdo_grou.asp?...=Vision_Silver
oil pressure gauges comes in 5 bar and 10 bar versions.
I assume a 10 bar gauge is suitable for a V8 or.........?
Old Dec 6, 2012 | 04:32 PM
  #783
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
How would you mount up the trans temp sender seeing as there's no drain plug on the trans?
#202 828 00 30
Also just checked out this part, it's euro only for Taxi use and can't be bought in the US from dealers.
Old Dec 6, 2012 | 07:38 PM
  #784
Saaboteur's Avatar
The trans has a drain plug. But DRB was talking about the diff. That one's a bit more difficult. You could find a sender with the same thread pitch as the drain plug, but that'd be difficult. Other option is to drill into the diff cover itself, tap it and then thread the sender unit there.
Regarding oil temp and oil pressure, there is the oil pressure test port on the front of the motor, that would be the easiest way. But it'd only be easy to get one sender in there. If you want to run two, then I would run an adaptor into the port, a length of stainless hose, then a 'T', and then the two senders into the T. Even if you run just a single sender, it would be a good idea to run the stainless line. Doing so allows some relief to the sender. Not saying it would crack and fall off in normal driving conditions, but it might - and that's the last thing you want.
I've done the same process on my old Saabs, and on my S2000 (and another fellow's S2000). Something along these lines:
http://www.s2ki.com/s2000/topic/8924...-sendersensor/
Old Dec 6, 2012 | 07:39 PM
  #785
Saaboteur's Avatar
What we need is for one of our European friends - Kowalski or DRB - to sort out a group buy for us!
Old Dec 6, 2012 | 07:52 PM
  #786
nd4spd13's Avatar
Whoops! Same size as the oil pan? That'd sure be nice.
Regarding the oil pressure, do we have a stock sender of any kind? Is there just a level sensor somewhere that sets of the oil light in the car?
Yes!! I'm checking with Canadian dealers tomorrow just to be sure, seeing as they are a little more euro friendly here.
Old Dec 6, 2012 | 08:30 PM
  #787
Saaboteur's Avatar
There should be a stock oil pressure sender to trigger the idiot light, but I can't recall exactly at the moment. There is an oil level sender too. I knew all of this when I tore the motor apart two summers ago, but have since forgotten. I'll have a look at my 55 motor later to jog my memory.
I've also checked with my parts guy at the local Benz indy shop I use for that part. See what's what.
Old Dec 6, 2012 | 09:17 PM
  #788
nd4spd13's Avatar
#202 828 00 30
The oil pressure test port is M12 x 1.5 and the adapter to hook up the actual pressure tester, or sender, or stainless line is #166 589 00 63 00
Don't know what size the trans or engine oil pan plug is.
Old Dec 6, 2012 | 09:55 PM
  #789
Saaboteur's Avatar
I was going to post that the oil pressure test port is M12x1.5, I think I made that post sometime ago in this thread!
Most aftermarket senders (at least on this side of the Atlantic) are going to be 1/8" NPT male. I would thus find a male M12x1.5 to male -3 or -4 adaptor, run the stainless line (something off the shelf from Earl's or Goodridge or Aeroquip - $20-25), then to the T. Might be easiest to get a 1/8" NPT female T, then need a -3 or -4 adaptor to the NPT for the stainless line. Then plug in the senders and away you go.
One other problem, or hurdle I guess, is that there is not a lot of space between the test port and the rad and the belt. Might need an angled adaptor in there too, so as to get the line routed nice and safely.
Then it's just a matter of running the wiring and you're done!
Old Dec 6, 2012 | 10:05 PM
  #790
nd4spd13's Avatar
Yeah I noticed how it was pretty tight with the belts there. Hopefully wouldn't be much of an issue with it vibrating into the pulleys.
Am I right in thinking that the plus of having two senders is just more accurate readings?
Also, from what I've found, test port is M12 x 1.5, engine oil plug is M14 x 1.5, and trans plug is M10 x 1. The site that Kowalski quoted above has senders in all these sizes (or you can get the one main size that comes with adapters for a little cheaper, but I'm not sure how great that'd be)
Old Dec 7, 2012 | 02:46 PM
  #791
nd4spd13's Avatar
Confirmed! Canada is more Euro friendly. Dash piece on backorder from Germany, they said 3-5 weeks, and ~$35.00 CAD, and also got the test port piece, ~$3.50.
Old Dec 7, 2012 | 03:09 PM
  #792
what is the testport M12 x 1.5 you refer to?
is it the oil cover infront of the engine?
is it for this part in my pic?
what are the sensor sizes for oil pressure and oil temp gauge?
what are the adapters you refer to?
is there a 1 piece multiadapter for both oil temp + oil pressure gauges sensors?
Old Dec 7, 2012 | 03:48 PM
  #793
nd4spd13's Avatar
Yep, that's it. A "hole" in the block to plug in a oil pressure gauge. This is definitely the easiest place to permantly plug in a pressure sender. It's right underneath the oil filter housing in between the belts.
The sizes for the senders are the same as the bolts that fit in there now, so you can refer to my last post. the oil temp, if putting the temp sender where the oil pan plug is, is M14 x 1.5. For the oil pressure, if you put the sender directly into the port, it'll be M12 x 1.5, or you can connect a hose to that port, and have the other end of the hose have a connector in whatever size you like (whatever is the cheapest size sender )
For the adaptors, you can either buy a sender in the exact size you need, or a generic size that comes with washers to make it fit whatever size the hole is. So basically, you can buy an M14 x 1.5 size sender, or a generic size sender with adapter-washers that make it fit an M14 x 1.5 size fitting.
Or you may have been referring to the oil test port adapter, p/n #166 589 00 63 00. This is what you need to hook up something to the test port.
Also all this info is just from my research yesterday, so if anyone knows better, please chime in. I'm just excited for this because after seeing Kowalski and Saab talk about this, it is the perfect price/difficulty for the winter-break project I was looking for
Old Dec 7, 2012 | 04:00 PM
  #794
Saaboteur's Avatar
I'd be wary of putting a temp sender into the oil pan drain plug hole. There's a slight step on the inside of the pan (hard to see unless the pan is off the motor). Depending on the length of the sender on the inside, it might interfere with the lip. Not sure if it will for sure, but might need to trial and error to be sure. The ideal, I think, would be to remove the pan entirely, then drill and tap a hole for the oil temp sender to be mounted permanently.
Old Dec 7, 2012 | 04:13 PM
  #795
is there 1 or 2 bolt holes on bottom oilpan?
1 bolt at the bottom of the pan and 1 bolt on the side if I'm not mistaken?
should each of these wirelooms for oil temp + oil pressure be dressed by a SS - braid to avoid heat or something else?
Old Dec 7, 2012 | 05:05 PM
  #796
Saaboteur's Avatar
Only one drain plug. Weird, because my C55 has two...
The only protection I would do on the wiring would be to fit it inside a length of plastic wire loom. Of course, whenever I've done wiring, I always soldered and used heat shrink wrapping. Doing anything less, eg. butt connectors, is easier but in my view, a lot less secure. I basically rewired my Saab when I put it on stand alone engine management, and I soldered and heat shrunk every connection. Never an issue. It's been about 10 years since I did all that work, and while I don't own the car anymore, it is still on the road.
Old Dec 7, 2012 | 08:05 PM
  #797
nd4spd13's Avatar
Good catch. I think it will clear without an issue. From looking at pictures of the inside of the oil pan online, and looking at just how shallow the temp sender is, it should clear. But if not, drilling and tapping a hole won't be that bad.
Old Dec 8, 2012 | 02:48 PM
  #798
nhmercracer's Avatar
Here is what I did for the oil pressure gauge:
Metal panel soldered and screwed to the factory cubbie. I had to cut away most of the cubbie to make this work.
"Pagoda" adapter I built to route the line away from the belt. I did not want the tubing to exit from inside the belt routing.
I have plans to replace the nylon tube with stainless, but have had no troubles thus far.
Another side view of the parts I used. All but the adapter from my local Mom & Pop hardware.
The adapter I sourced from AutoZone. It is an AutoMeter stock part. I believe you are all correct, and it is M12 x 1.5 to 1/8 NPT. IF I remember correctly.
Old Dec 8, 2012 | 03:00 PM
  #799
you should have filled that cover with another 2 gauges, looks kinda empty now with only one gauge.
gauge feelin' lonely?
Old Dec 12, 2012 | 01:52 AM
  #800
hey SAABO.
what are you saying here?
if using these brass senders would they come off from engine vibrations?
when these sensors are screwed in they should sit tight?
would it be any good using Loctite threadlock gunk?
is it normal that they eventually fall off under normal driving situations?
are there any problems connecting 2 brass sensors onto the engine?
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
