A few random questions
2) Anyone know how to access the bulb array in the sunvisor? I can't seem to get to it without breaking something.
I'm looking for paint/dye suggestions, rather than service suggestions.
http://www.performanceproducts4benz.com
http://www.performanceproducts4benz....or-option.html
Get you by until redye time rolls around
Nobody has any paint/dye info?
For $60 or so (the dye is only $35), you could do your entire interior at least 3 times. If you're just doing a steering wheel, plan on having a lifetime supply of leftover dye. You could do the wheel and two-tone seats and you'd still have a ton of leftover.
For $60 or so (the dye is only $35), you could do your entire interior at least 3 times. If you're just doing a steering wheel, plan on having a lifetime supply of leftover dye. You could do the wheel and two-tone seats and you'd still have a ton of leftover.From the factory, are the steering wheels dyed or painted? Because from the wear, it looks like the factory painted the wheels. I can't see dye being "worn off." Not sure if I should go with dye or paint (if that even exists for interiors).
Almost all leather is painted.
If you dye it, you'll have to strip it first.
I finally figured out what LED bulb I needed for the vanity mirrors and ordered them; they came in today. I still don't know how to easily access the bulbs.
Anyone happen to know, before I break something?
