Rebuild Front Calipers
Old Jun 26, 2017 | 08:09 PM
mickey13's Avatar
1999 AMG C43
probably not but i'll ask.
is anyone rebuilding front calipers on this? my front passenger caliper is binding a bit. i get spin when the front end is up, but only about half the spin i get on drivers side.
i installed new hoses on all four wheels and did a flush as well. on front passenger, i pulled off the caliper and the drum spins nicely. i squeezed caliper open using two vices and reinstalled. everything spun nicely. i smashed down on brake pedal and free spin in that wheel gone.
guessing sooner or later it is going to seize up or cause other problems.
Old Jun 26, 2017 | 08:40 PM
mickey13's Avatar
1999 AMG C43
i found this. these look like ours,,, can someone confirm?
http://www.brakewarehouse.com/catalo...arts/141.35103
and
http://www.brakewarehouse.com/catalo...arts/141.35104
Old Jun 26, 2017 | 09:50 PM
eFifty5AMG's Avatar
2004 E55
Do you know for sure it's the brake hanging up? Have you checked the hub bearings, if it's too tight it could bind up.
Old Jun 26, 2017 | 10:31 PM
mickey13's Avatar
1999 AMG C43
i pulled the caliper off and the hub spins very nicely. i open the caliper with vice and reinstall. still spins freely at the point with pads and caliper installed. next i start the car and smash the brake down. wheel no longer spins.
Old Jun 27, 2017 | 04:24 AM
DRBC43AMG's Avatar
Originally Posted by mickey13
Looks very much like ours, but probably need closer investigation for ID# and measurements
Old Jun 27, 2017 | 05:36 AM
cm60k's Avatar
These calipers for "C43/Clk55/E55",,
also for "BMW/VW"..
-;ZAYED;-
Old Jun 27, 2017 | 11:02 AM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
I ordered new pistons and seals for the front and rear calipers as well as new pins for the rear. I was told by the dealer to never separate the calipers as they will never seal properly once separated.
Old Jun 27, 2017 | 08:50 PM
mickey13's Avatar
1999 AMG C43
hey can you explain further?
Old Jun 28, 2017 | 03:52 AM
nkctb7's Avatar
Hey Mickey. I was going to separate my front calipers by loosening the round head Allen bolts in order to thoroughly clean and rebuild them with new pistons and seals. The MB dealer mechanic stated that they'll never seal the same way as they once did and will more than likely leak fluid where the join is. That in itself deterred me from separating mine. My father in-law is a retired lifelong mechanic and he also advised against separating due to the very same reason. After I removed the pistons and seals, they were much easier to clean. I'll post pics tomorrow.
Old Jun 29, 2017 | 12:26 AM
mickey13's Avatar
1999 AMG C43
ok so im guessing you can somehow break the caliper down into two pieces (sorry i havent taken a really good look at them)
ive been driving around and while i can tell the caliper isnt functioning properly - just the slightest vibration when hard braking, (probably only because i know its acting up)
after a long drive with hard braking, i checked the temperature on both front wheels and both are the same temperature to the touch, not hot enough to burn my hand even if i hold it on there. so it seems that the caliper while just slightly dragging is performing acceptably.
and since there is no rush to replace, i also have the option to "upgrade"
i'd be interested in oem if they werent that expensive. 2 things i'd want is (1) at least equal stopping power and (2) weight savings.
i know there are actually tons of threads on this, but suggestions?
otherwise, $140 for the rebuilt calipers is probably a deal
Old Jun 29, 2017 | 03:26 AM
nkctb7's Avatar
Perhaps one of the pistons is badly pitted which is causing the vibration. It might be a good idea to remove the calipers to inspect the pistons.
Old Jun 29, 2017 | 06:36 AM
fredtga's Avatar
w202
If you're interested in used C43 calipers, I have both fronts. No issues with them, I replaced the front brakes with a C36 setup. $80 + shipping
Old Jun 29, 2017 | 08:18 AM
KJI3jflarryfe93's Avatar
do stealership sell the front caliper pisstons and gasket seals individually for C43?
Old Jun 29, 2017 | 09:01 AM
DRBC43AMG's Avatar
They are listed under the #77 (repair kit) so it certainly does look like it.
File Type: pdf
File Type: pdf
Old Jun 29, 2017 | 11:03 AM
mickey13's Avatar
1999 AMG C43
yeah i agree, definitely some dirt or grime, possibly pitting causing the problem. did you buy new pistons? what did they cost you?
sent PM
i saw the gasket kit pretty cheap but...
part 77 looks like its around $180 each
Old Jun 29, 2017 | 01:11 PM
mickey13's Avatar
1999 AMG C43
found a great review of centric v a1 cardone rebuilt brakes on a different forum. the review speaks volumes about centrics' rebuild process.
http://www.passatworld.com/forums/an...1-cardone.html
based on the review i pulled the trigger and bought two rebuilt centric front calipers from JC Whitney. i got them for $53/each plus $10 discount bringing price down to $48/each, free shipping, 1 year warranty. these also come with the bracket and the best part is that i can paint them out of the box without sanding or cleaning. probably silver... or maybe red
Old Jul 1, 2017 | 12:55 AM
nkctb7's Avatar
Centric supplies replacement pistons for the C43 front/rear calipers. ECSTuning offers the rebuild kits which includes the pistons and seals for $32.03 each for the front and $22.73 each for the rear. I just finished the prep work for painting. I'll be installing the new pistons and seals once the paint sets.
Attached Thumbnails Rebuild Front Calipers-img_1060.jpg   Rebuild Front Calipers-img_1061.jpg   Rebuild Front Calipers-img_1063.jpg   Rebuild Front Calipers-img_1064.jpg   Rebuild Front Calipers-img_1065.jpg
Old Jul 1, 2017 | 12:59 AM
eFifty5AMG's Avatar
2004 E55
Centric supplies replacement pistons for the C43 front/rear calipers. I just finished the prep work for painting. I'll be installing the new pistons and seals once the paint sets.
Looking good! What color will you be going with? I'd just ceramic coat those
Old Jul 1, 2017 | 01:06 AM
nkctb7's Avatar
Thx Fifty! Ceramic coated would be nice but isn't that very expensive? I was going with G2 caliper paint in a custom color.
Old Jul 1, 2017 | 01:11 AM
brad_c43's Avatar
'99 C43, '88 560SL
Theyre so clean! Overall, how would you say its been to rebuild the calipers?
Old Jul 1, 2017 | 01:30 AM
eFifty5AMG's Avatar
2004 E55
Yeah, ceramic coatings can get pretty pricey, but Cquartz is right around G2's price. Modesta BC-09 offers great protection as well but that'd be around $300.
Old Jul 1, 2017 | 01:33 AM
cm60k's Avatar
Looks great D..,
good job & Thanks for sharing info. & pics..
-;ZAYED;-
Old Jul 1, 2017 | 02:11 AM
nkctb7's Avatar
Rebuilding the calipers is a very simple and inexpensive process. The most time consuming part was the cleaning.
Old Jul 1, 2017 | 02:12 AM
nkctb7's Avatar
Originally Posted by cm60k
Looks great D..,
-;ZAYED;-
Thx Z! My pleasure!
Old Jul 1, 2017 | 12:52 PM
nkctb7's Avatar
There's no part# for new replacement pistons through the dealer. They only sell replacement seals. Centric sells replacement pistons for C43 calipers.
