C450/C43 Wheel Fitment Guide
Stance SC-9 by Stance Wheels
19x8.5 et32
19x9.5 et48
(Stance has a few other styles that will work too, however I cannot recommend 19x8.5 et35 without checking brake clearance with a template (for instance Stance SC-1 by Stance Wheels)
Two wheel choice by TSW in this fitment: 1. TSW Bathurst Rotary Forged by TSW Wheels 2. TSW Geneva by TSW Wheels
19x8.5 et32
19x9.5 et39
(would recommend the car be lowered and running OEM tire sizes)
Two more from TSW in this fitment: 1. TSW Interlagos Rotary Forged Wheel by TSW Wheels 2. TSW Nurburgring by TSW Wheels
19x8.5 et32
19x9.5 et41
(better off running OEM tire sizes so the rear tucks in)
Two wheels by Vorsteiner in this fitment: 1. Vorsteiner V-FF 107 Carbon Graphite by Vorsteiner Wheels 2. Vorsteiner V-FF 103 Carbon Graphite by Vorsteiner Wheels
19x8.5 et35
19x9.5 et46
(verified that 19x8.5 et35 clear brake calipers in the V-FF 107)
5 options from Vossen in this fitment: 1. Vossen CV3-R by Vossen Wheels 2. Vossen CVT by Vossen Wheels 3. Vossen CV7 by Vossen Wheels 4. Vossen VFS-1 by Vossen Wheels 5. Vossen VFS-2 Silver Polished by Vossen Wheels
19x8.5 et30
19x10 et55
Do you happen to have any additions to this list?
So please help...I want to use my stock tires: 225/40/19 and 255/35/19- cause are new. I don't want to use spacers to this new wheels, but would be great if rims stick out 10-20mm.
To this tires I guess the rims should be 8" and 9" width.
I can buy Borbet VTX front: 7,5 ET30, rear 8,5 ET40, so the front will be 3mm wider and rear 13mm, but I'm not sure If it fits and looks good...
Also I found this wheels: https://www.ebay.co.uk/itm/Schmidt-R...-/323413421656 but I'm not sure it the rims will fit without spacers...
Any ideas?
Sorry for language mistakes
Offset would be 39 rear and 43 in the front.
I'm only asking, as I already have a set of wheels from an Audi, but think they *MIGHT* fit on a w205. If they clear, then I may have found my next car!
What I can say is, I just tried, much like quite a lot of members here to search for rims out of the box that would fit and clear the front brake caliper/inner knuckle/control arm, with a set of Savini rims for CARID $1800. You can search that post and see photos of the lack of inner clearance hitting the knuckle and how far the rim stuck out past the front fender. Even though "Savini engineers" guaranteed fitment. I was putting on 20x8.5 eta 32 front and rears.
One of the problems when MB incorporated the larger suspension bits from the C63 on my C450 AMG was they forgot to put the wider side fenders of the C63 lol.
From what I can gather, not saying that a 8.5 wide rim/tire couldn't fit on the front, just from my recent experience and many posts here that it is very difficult to get it right and or can lead to suspension problems.
Currently, so far to avoid the $8-9K forged rim setup; I went with another post recommendations and ordered some TSW Mallory rims from my local discount tire sized:
19x8 eta 32 front and 19x9.5 eta 52 rear (going to be hard to find many options in a 19x8 rim; tire rack has good options such as another member had mentioned with the OZ rims)
once I test fit the TSW... will work out the right tire sizes for the rear to compensate for stretch and low profile with the M. Pilot sport 4S's.
So far Discount tire guys are suggesting front: 235/40 R19 (their system couldn't choose 225/40 nor 225/35 R19 since it stated that the vehicle exceeded the weight capacity of the tire) & 265/35 R19 in the rear.
Hope this helps
Best regards
I was looking at some 19" TSW wheels as well. I like alot of the Vossen's, but many are 20", which i want to go with 19"s
Just test fitted the TSW Mallory’s (19x8 eta32 & 19x9.5 eta53) at my local discount tire and they fitted up real nice. Good clearance of the control are and caliper and fit flush with the fenders. So far no spacers needed.
All the guys at the shop and myself were shocked.
So much so I didn’t think to take pics lol.
Ordered the M. Pilot 4S’s. Once I get everything in and mounted hopefully by next week I will post the final pics.
I have a set of aftermarket wheels (Verde) but seems like a pain in my *** lately to get perfect fitment. Fronts are vibrating a bit which I am thinking because of the 5MM spacer that needs to be hubcentric so I ordered 10MM fronts now so lets see. Rears are 19x9.5 with 255 tire on it. Seems a bit more tucked in vs the rear being out too much.
Post your complete spec. Wheel size f and r, original offset of the wheels, size spacers used, front and rear tire sizes...
Do you plan to drop the car or keep it at stock height?
225/40/19
255/35/19
19x8.5 ET25 with 5mm spacers (valve stem hits caliper)
19x9.5 ET43 with 5mm spacers
i bought angles valve stems to see if the car will take it so I don’t need to run a spacer. I think I’ll put 10mm spacer on rear if it does work
Unfortunately, if you’re already stuck with the wheels you have and can’t return it, you’ll have to play with spacers to make it fit. This is exactly why I just opted to have forged wheels made and waited the 6 weeks for the set to be delivered. The $2400/set I spent was well worth it and avoided all the headaches of spacers, balancing and wheel weight. Plus, the ride even improved because of the wheels being lighter, it lessened the rebound weight on the suspension.
They're a square set of 18x8.5 w/ ET45
Edit - I actually just noticed there's a custom ET option, anywhere from 30-50. It'll add two weeks to the delivery but I'd rather go that route than adding spacers.
Looking for suggestions on thickness of spacers for my stock wheels. Fronts are 225/40/19 and the rears are 255/35/19. I am not lowering the car. Just looking to bring the wheels out a bit.
