C450/C43 AMG
C450/C43 Wheel Fitment Guide
Old Apr 24, 2020 | 10:48 AM
  #576
SupremePower's Avatar
SPONSOR
GT3RS, 356, Raptor, M2, Sprinter 4x4
New shipment of spacers has arrived! Let us know if you guys need any! Shoot us a PM or email: sales@supremepower.com
Old May 10, 2020 | 02:01 AM
  #577
Jeremyc250's Avatar
C-450 Amg
C450 with H&R lowering springs and 15/17.5 rear spacers. Rides super smooth and looks amazing. also has a JB4 tune and intakes. A beast on the streets.
Old May 11, 2020 | 10:46 PM
  #578
ckdude's Avatar
2018 C43
I have 2018 C43 with OEM 19" wheels. It comes with Pirelli run flats in front 225 /40 R19 and rear is 255 /35 R19. I already had a blowout on RF tire after hitting a pothole on freeway. My complaint with this car is ride is too stiff. It has the performance seats too. I'm thinking of getting regular tires such as the Pirellie CINTURATO STRADA SPORT AS or Michelin - Pilot Sport A/S 3+. I want to get the most comfortable tires. Can I go with a thicker sidewall such as front 225 /45 and rear 255 /40 without modification? The tires will increase diameter from 26.1" to 27" and sidewall from 3.5" to 4". What is the maximum that I can go without any modification such as front 235 /45? I don't want it to rub against any parts and effect the handling too much. Thanks.
Old May 13, 2020 | 03:15 AM
  #579
VitaminJB's Avatar
C43 AMG
Originally Posted by ckdude
I have 2018 C43 with OEM 19" wheels. It comes with Pirelli run flats in front 225 /40 R19 and rear is 255 /35 R19. I already had a blowout on RF tire after hitting a pothole on freeway. My complaint with this car is ride is too stiff. It has the performance seats too. I'm thinking of getting regular tires such as the Pirellie CINTURATO STRADA SPORT AS or Michelin - Pilot Sport A/S 3+. I want to get the most comfortable tires. Can I go with a thicker sidewall such as front 225 /45 and rear 255 /40 without modification? The tires will increase diameter from 26.1" to 27" and sidewall from 3.5" to 4". What is the maximum that I can go without any modification such as front 235 /45? Thanks.
You absolutely should get regular tires, part of the reason why it's so stiff is because of your run flats. You will notice a significant difference when you go to regular tires. Get the A/S 3+ if you want all season.
Do some research on how tire fitments work. Reading through this thread I can't believe how many people want to spend thousands on wheels and aren't really keen on how wheel offsets and tire sizes work and are willing to trust random internet people on big wheel purchases. People like "Hey..figure this out for me". lol. Man YouTube and google, it's easy. Get smart on this stuff it can save you a lot of money and you'll be able to explain how you modded your car too when someone asks you.
Go measure the gaps that you have in the front and back. Jack it up yourself or take it somewhere. This is easy since you aren't getting a different wheel. Take a picture of it so you have it. Notice some people in this thread posted pictures of how much gap they had between their tire and their suspension? Measure what you have now and compare. I wouldn't spend any money until you measure it for yourself.
Judging from your post your main complaint is the comfort. If that's the case then go for a wider tire. Look at this website https://tiresize.com/calculator/ and compare the size difference from a 225/40R19 (stock front) to a 235/40R19. There is a .4" width difference so you are going to need an additional .2" inside for a good fit. You obviously know that the handling will be affected by a bigger tire...how much bigger do you want to go? "I don't want it to rub against any parts and effect the handling too much"....this is really subjective and personal preference, pick your poison.
Personally I like to go with a tire that is pretty close to an exact fit for the wheel that I am getting. It's cheaper, better handling, technically better gas mileage. I have 8.5" and 9.5" wheels with 235/40 R 19 and 265/35 R 19 in Michelin PS4S. I think that is pretty much the chalk for 19s staggered.
225/40 R19 and 255/35 R19 is perfect for the stock setup if you ask me, just not in a run flat. If I were you I wouldn't rage out and go for a huge tire and a drastic change because you want more comfort...once you experience how much better the car is on a standard tire vs. a run flat you'll see.
Old May 16, 2020 | 09:31 PM
  #580
ali.shamim's Avatar
C450
I've read through most of the thread and think I have a pretty decent understanding of what will and won't work, but still good to get a second opinion on this.
Will this fitment work on a C450 on H&R springs?
Vorsteiner VFF-101
front: 19x8.5 +45 (gonna use a 15mm spacer to bring to +30), 225/40/19
rear: 19x9.5 +46 (possibly using a 5mm), 255/35/19
Old May 25, 2020 | 04:28 AM
  #581
Synarchist's Avatar
2017 C43 W205
2 - 19x9.5 48 offset
2 - 19x8.5 45 offset
Will these sizes fit? Thank you.
Old May 25, 2020 | 04:58 AM
  #582
TModelle's Avatar
C190
with 15mm spacers in front you should be good.
Old May 25, 2020 | 05:52 AM
  #583
Synarchist's Avatar
2017 C43 W205
How about the rear?
Old May 25, 2020 | 06:07 AM
  #584
TModelle's Avatar
C190
Rear is fine.
Old May 25, 2020 | 06:13 AM
  #585
Synarchist's Avatar
2017 C43 W205
Rear is fine.
Thank you for the info.
Old May 25, 2020 | 06:35 AM
  #586
TModelle's Avatar
C190
If you can find suitable 13mm front spacers, that would be a better balance to the rear that you chosen.
Old Jun 8, 2020 | 03:04 PM
  #587
Nickkenny's Avatar
c43
in the country where I live it is allowed max 235/30/20 front and max 265/30/20 and not 275/30/20 at the back, this would cause problems for the 4 wheel drive.
Normally I would take a tire of 225 and 265 would be ideal for 4 wheel drive
the rim at the front is 8.5 y, should I take a 235 ?
Old Jun 13, 2020 | 02:02 PM
  #588
Matt Henderson's Avatar
c450
for your rear spacers what kind of extended bolts did you use? I have 15mm spacers i would like to install and I dont know what size bolts to get
Old Jun 15, 2020 | 04:41 PM
  #589
SPONSOR
We have the bolts in stock. Shoot us a DM or email kim@supremepower.com and she can get you set up
Thank you!
Old Jun 15, 2020 | 07:55 PM
  #590
Slpr's Avatar
C450
I ended up going with Rotiform OZR 19x8.5 et45 with 15mm spacers all around. With 245/35/19 Michelin Pilot Sport 4S all around as well. I'm lowered on H&R lower springs. Sorry for the dirty pictures, it was raining when I decided to take fitment pictures.
Old Jun 15, 2020 | 11:10 PM
  #591
xX G Xx's Avatar
Tuned '18 C43 coupe & Stock '18 GLE43 coupe
225/45/19
255/40/19
I just did that. You will be fine.
Old Jun 16, 2020 | 02:18 PM
  #592
Mojorodt-23's Avatar
AMG C43 2017
MSW 30 Black / polished
Finally got my MSW 30 by OZ Racing on the car. It took some time for the factory to have the 7,5” narrow (to be 19”) front rims manufactured in current Covid situation.
So I have stock measurements for both rims and tires. No spacers, no modifications. I don’t understand how you guys can go for 8,5” wide in front without rim poke out and risk of touching the fender
Old Jun 17, 2020 | 12:37 AM
  #593
TModelle's Avatar
C190
[QUOTE=Mojorodt-23;8083581I don’t understand how you guys can go for 8,5” wide in front without rim poke out and risk of touching the fender[/QUOTE]
Careful selection of the offset will enable you to go for a 8.5” wide front wheel. ET30-32 would be about right.
Old Jun 17, 2020 | 11:38 PM
  #594
phillyAMG's Avatar
2016 c450 amg
Vossen hf-2 wheels
hello there. New to the forum and purchased a 2016 c450 amg with the 19 inch wheel option. Bought some vossen hf-2 wheels in this spec.
19x8.5 et 30 front
19x9.5 et 45 rear
Also purchased toyo proxes sport in these specs.
Front 235/40 R19xl 96y
Rear 265/35 R19xl 98y
Just had fountain tire tell me these do not fit and that they rub on the inside and poke out pass fender.
im loss for words as i researched this forum like crazy yet my calculations arent correct. Do i need wheel spacers or am i stuck now.
If wheel spacers are needed which is my best option for this set up i purchased.
Old Jun 18, 2020 | 12:04 AM
  #595
TModelle's Avatar
C190
19x8.5 et 30 front
19x9.5 et 45 rear
Front is fine. Rear is really at the edge. May or may not rub depending on the tire brand and side wall shape.
Old Jun 18, 2020 | 12:12 AM
  #596
mo11's Avatar
2017 C43
19x8.5 et 30 front
19x9.5 et 45 rear
The rears should be fine. They’re probably just worried about the fronts, though I don’t see why they think it would rub and poke. I have the same wheel spec for the fronts with WIDER tires and they don’t rub inside nor poke out... one way to find out... have them install it and see.
Old Jun 18, 2020 | 12:21 AM
  #597
phillyAMG's Avatar
2016 c450 amg
im starting to think that the guy testing them out didnt realize that this car is staggered setup and tried my rear wheel on rhe front. Haha
also with your set up did you require spacers at all?
Old Jun 18, 2020 | 03:17 AM
  #598
mo11's Avatar
2017 C43
I’d really be worried if my tire guy, after all these years this model has been out still doesn’t know this car has a staggered setup, hahaha!
My wheels are custom so I was able to have the exact offsets I wanted front and rear. 19x8.5 +30 f, 255/35 19f and 19x10 +55 r, 295/30 19r.
Old Jun 18, 2020 | 09:48 AM
  #599
alexasa's Avatar
c
yeah, nothing about those specs seems alarming.
being at stock ride height it's not the most ideal set-up. The suspension should also be tested loaded for clearance not on a lift
Old Jun 18, 2020 | 01:13 PM
  #600
phillyAMG's Avatar
2016 c450 amg
damn if you managed to fit those specs with a set up that extreme im wondeeing how mine doesnt fit haha. You using spacers at all and is your clearance very minimal on everything? No rubbing at all up front or on the rear?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
