C450/C43 AMG
C450/C43 Wheel Fitment Guide
Rating: Thread Rating: 3 votes, 5.00 average.
Old Mar 5, 2021 | 09:11 PM
  #726
speedlaw's Avatar
C 43
18 inch wheel replacement
One person's story, or the answer to "I don't want 20 inch wheels, I just want to replace the overpriced and flimsy Benz wheels...."
I bought the car with 18 inch wheels, because I live in a pothole prone area. The car is a DD...that last .01 g in a corner isn't really important. I wanted to replace my standard wheels with standard tires, with the same size..... I fell into the rabbit hole.
Read this entire thread-most folks modding were looking for the most possible. While not my use case, it was very instructional, and a few of you guys are brave, to say the least. I have a set of stock sized Michelin AS-4 to mount, not 245/35 on 20's.....
Checked tire rack, who oddly recommends ET30 front AND rear for C43.....but for the AMG sport C300, ET45 front and rear ? (different hubs ?)
Checked the euro wheel providers fitment websites, who recommended ET 30 front and ET 45 or 50 rear.
Read Benz, who spec-ed for this car in 2019 OE
44/49, the wheels on the car now...
36/52
33/40
33/49
My brain hurt.
The next problem was which wheel ? I didn't want spacers, but I did want TUV approval and something tough.
After staring at wheels long enough I ended up with BBS SR in Himalaya Grey. $290 each means that the pothole you miss is no longer a $1k day. Wheels are like jewelry or fine watches...I didn't need a Rolex for this and I was trying to get RID of overpriced wheels. That pothole is out there....and will be full of water....and in a shadow......
After too much time staring at the very helpful tire and wheel pages, I decided that the euros were probably right plus based on what Benz sold the car with, 30/45 would work. I called Tire Rack, who told me I was wrong (Customer Responsible for Fitment) but shipped promptly as usual. A set of BBS SR showed up two days later.
Took it to my tire guy, The Wheel Doctor in Yonkers, NY. I cannot recommend them highly enough, have used them many years. Mounted up without incident, so now
8 x 18 ET30 with 225/45
8x 18 ET 45 with 245/40
No clearance issues.
The wheels ended up about the same. I can't see any difference at the rear (49 v 45), and maybe a slight poke out at the front...very slight. Very pleased with the look.
Finally, when the Michelins wore out, I replaced them with DWS 06, but this time I went square-235/45. This picked me up a bit of sidewall, which in my world of horrible roads (try going from I 287 to I 87, or from I 87 to Saw Mill Parkway) is always good. This size is the ideal for an 8 inch rim, and I'm very pleased. Still can't rotate them due to offsets but I don't have to fear that hole you are bound to miss and hit.
Old Mar 17, 2021 | 11:21 PM
  #727
AmxnG's Avatar
2016 C450, 2000 E55
Hey everyone, I read this thread closely over the last week and unfortunately my notepad crashed w/o saving.
I'm hoping I can get some help with my C450 and some possible suggestions, glad to hear the ride quality issues comes from the run flats.
I just ordered a set of the H&R lowering springs (28811-2) and was planning on going with either of these wheel selections (Rotiform BLQ) (Verde Empire) (Vossen CV10) or (Mandrus 23)
I've seen mixed reviews on the Mandrus wheels, but I like the "oem" look that they have, kind of in between those and the Empires.
I don't mind buying spacers, but would rather avoid having to add them to the setup (along with bolts and costs).
I'm looking for help selecting the right tires too, I keep seeing the Michelin Pilot Sport All Season 4, was leaning towards those or Toyo Proxes.
Thanks yal!
Rotiform Specs:
Front 19x8.5 35mm Rear 19x8.5 36mm or 45mm
Verde Specs:
Front 19x8.5 30mm Rear 19x9.5 36mm
Vossen Specs:
Front 19x8.5 30mm Rear 19x9.5 45mm
Mandrus Specs:
Front 19x8.5 25mm Rear 19x9.5 35mm
Old Mar 18, 2021 | 08:20 PM
  #728
MBC450AMG's Avatar
2016 c450 amg
Originally Posted by alexasa
'mirin my fitment lol
what’s your setup? Are you lowered?
Old Mar 18, 2021 | 08:29 PM
  #729
MBC450AMG's Avatar
2016 c450 amg
Originally Posted by Jeremyc250
C450 with H&R lowering springs and 15/17.5 rear spacers. Rides super smooth and looks amazing. also has a JB4 tune and intakes. A beast on the streets.
do your rear springs look as compressed as mine? My c450 seems much more slammed than yours..
Old Mar 21, 2021 | 09:49 AM
  #730
Nickkenny's Avatar
c43
What is the tire pressure 20" front and rear? Thanks
Old Mar 21, 2021 | 12:32 PM
  #731
alexasa's Avatar
c
yes lowered on KW HAS.
19x8et25 235/40/19
19x9.5et38 265/35/19
Old Mar 29, 2021 | 12:02 AM
  #732
Senid Avdic's Avatar
Mercedes AMG C43 Sedan
step down a tire size (sidewall too tall) - you might have issues with rubbing through your fender liners. if you want a meaty sidewall you're better off with 19x8 and 19x9
235/40/19 and 265/35/19
Alexasa, I'm running the exact same setup with Rohana RFX 10's. What do you mean by step down a tire size? What tire specs should this set up run?
Old Mar 29, 2021 | 09:06 PM
  #733
AlabamaRiot's Avatar
C450 AMG
Originally Posted by chiefsalami
Enkei Raijin in hypersilver, 19x8 front and 19x8.5 rear. 5mm front spacer (necessary), and 7mm rear (for stance). Custom center caps, stock suspension on a C450.
I’ve got the same Enkei Raijin wheels (19x8 front, 19x8.5 rear) in matte black and would love to find custom center caps like yours - could you tell me where you found yours? Or what size center cap I should be looking for? I’m a newbie when it comes to this hobby so any help is definitely appreciated!
Old Apr 9, 2021 | 02:50 PM
  #734
Ruten's Avatar
c400
Guys will wheels from w222 fit on c400 coupe?
its set of 19”, 2x 8.5 et 36, 2x 9.5 et 43.5
Old Apr 10, 2021 | 09:49 AM
  #735
alexasa's Avatar
c
I think so. C400 has the same suspension as c300 so you're better off checking there. But it doesn't have near the same inner clearance issues that the c450, c43 have
Old Apr 12, 2021 | 08:09 AM
  #736
toosteeley's Avatar
Present: 2019 C43 Estate
Rear is fine. Front need to be et 30 to fit an 8.5" rim (ie, you'll need a spacer). That's for a C43. No idea about C400.
Old Apr 20, 2021 | 07:53 PM
  #737
aaronBLUEeyes's Avatar
‘17 C43 AMG, ‘10 C300 4MATIC Sport (previous)
Hello folks, I own a 2017 c43 and purchased directly from Vossen a set of custom finished CVTs for my previous w204 and would like to see if they’ll fit my w205.
My wheel specs: Vossen CVT 19” — 19x8.5 +45 Front | 19x10 +55 Back
In a Facebook group I’m in A couple folks said back wheels should fit as-is and that I’ll need a 15mm Spacer for the front.
Any thoughts?
Old Apr 21, 2021 | 07:28 AM
  #738
alexasa's Avatar
c
Any thoughts?
that's pretty much correct. I don't know bore, etc specs on w204 though
Old Apr 21, 2021 | 01:56 PM
  #739
What’s the wheel center bore for a w205 c43?
I believe w204 wheel center bore to be: 66.6
Old Apr 21, 2021 | 04:01 PM
  #740
mo11's Avatar
2017 C43
Same 66.6
Old Apr 21, 2021 | 09:24 PM
  #741
toosteeley's Avatar
Originally Posted by aaronBLUEeyes;[url=tel:8319489
8319489[/url]]Hello folks, I own a 2017 c43 and purchased directly from Vossen a set of custom finished CVTs for my previous w204 and would like to see if they’ll fit my w205.
Any thoughts?
You'll need 15mm spacers front and will likely want 5 or 10mm in the back.
All info is already in this thread.
Old Apr 25, 2021 | 12:37 PM
  #742
Any spacer brands you guys suggest? I reached out to modalworks so far.
Old May 7, 2021 | 01:32 AM
  #743
I’ve been in touch with modalworks and they don’t offer a 10mm and stated: “10mm spacer is not possible due to the OEM hub, so we offer either 5mm or 12.5mm.”
So based on your experience would you lean towards 5mm for the rear or 12.5mm with rear wheels sized at:
19x10 +55?
Thanks for your help.
Old May 14, 2021 | 04:58 AM
  #744
Ruten's Avatar
c400
I’m picking up my c400 16’ coupe with airmatic in two weeks and want to change wheels to 19” w222 s-class rims. Will they fit? It’s:
2x 19” 8.5” et 36
2x 19” 9.5” et 43.5
Old May 17, 2021 | 06:18 PM
  #745
Back again, I’m selling my Vossen CVTs because I’ve decided not to run spacers, mainly because no speed shops in my area are willing to install them.
Ordering a set of Vossen VFS-10s here’s the fitment:
20x8.5 +40 Front
20x9.5 +40 Rear
For the fitment gurus, will that be a good setup for my 2017 C43?
*Shop I was trying to order from said 10mm spacers needed for that setup, so I guess I’m not buying them. :0(
Old May 18, 2021 | 07:06 AM
  #746
toosteeley's Avatar
Vossen does custom offsets. Just order 20x8.5 +30 for the front. Rear will be fine.
Old May 18, 2021 | 09:15 AM
  #747
Yeah, I think I got my head wrapped around the concept of the correct fitment now
The problem with those wheels is that are they’re discontinued, so they are near impossible to find.
I’m considering another wheel after exhausting contacting a myriad of retailers.
I believe the Golden fitment I’m looking for is: 20x9 +30et, 20x10 +45et or 19x8.5 +30et, 19x9.5 +45et
Old May 18, 2021 | 10:11 AM
  #748
alexasa's Avatar
c
20x9 does not work upfront, realistically.
Old May 18, 2021 | 10:23 AM
  #749
Okay thanks for info!
Old May 18, 2021 | 12:05 PM
  #750
toosteeley's Avatar
Vossen HF3's (which I'm running) are very similar to the ones you posted above.
As discussed in this thread, 20/19x8.5 +30 front with 20/19x10 +45 or 20/19x9.5 +45et rear.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
