C450/C43 Wheel Fitment Guide
I'm planning to put 225/35 winter tyres for front which will be probably stretched more than enough to fit, and for summer switch to PS4S - either 225/35 or 235/35 - I know they are running a bit wide, so maybe 225 wouldn't be that bad as well?
No rubbing on lock to lock turns. Slight rubbing on the plastic fender liners on dips.
Here are some pics of the clearances to the knuckle.
Can I ask for a quick sanity check before I pull the trigger? I've read the thread, just making sure these will fit my 2019 C43 Sedan without issue.
Front: 19 x 8.5 et 30 running 235/40/R19
Rear: 19 x 10 et 45 running 265/35/R19
The car is stock ride height for now, but thinking about lowering on KW V3s in the near future.
Thank you in advance for any feedback.
Rims: JR SL01 (Flow Form)
- Front: 19 x 8.5 et 32 with 225/40/19
- Rear: 19 x 9.5 et 40 with 255/35/19
I'm pretty happy with the rear, but the front somehow looks a bit tucked in. I'm thinking of adding additional 3mm spacers there but not sure if it's not going to poke out too much with et29, especially that I'm planning to switch to 235 and 265 for the summer.
I am Stock suspension with 19" Stock wheels, I plan on lowering it on H&R sport lowing springs first before I order wheels.
Ya'll might hate me after this but I love these ESR CS12's, I will be sticking with the stock tire sizes too. (will have all details below) Here are the wheels.
Like I said I will have H&R sport lowing springs before I do wheels.
ESR CS12 details
Front: 19x8.5 +30 (5x112) / kumho tires 225/40/19
Rear: 19x9.5 +22 or +35 (5x112) / kumho tires 255/40/19
I figure some sort of 5mm to 12mm spacers will be needed.
Note: - I want the stretched tires and lip of rim poking out.
- Will have to adjust for camber as needed as well.
35 is safe, but you might need a spacer. If you're okay with potentially having the offset machined down to fit on the +22 that could work but I would not go into +22 without rolling fenders and having to massage the offset with custom machining (also not sure how much material would even be there for that).
Maybe show an example of the look you're going for, specifically, otherwise fo safe with the 35.
Check out their posts on here and message them
Stance SC-9 by Stance Wheels
19x8.5 et32
19x9.5 et48
(Stance has a few other styles that will work too, however I cannot recommend 19x8.5 et35 without checking brake clearance with a template (for instance Stance SC-1 by Stance Wheels)
Two wheel choice by TSW in this fitment: 1. TSW Bathurst Rotary Forged by TSW Wheels 2. TSW Geneva by TSW Wheels
19x8.5 et32
19x9.5 et39
(would recommend the car be lowered and running OEM tire sizes)
Two more from TSW in this fitment: 1. TSW Interlagos Rotary Forged Wheel by TSW Wheels 2. TSW Nurburgring by TSW Wheels
19x8.5 et32
19x9.5 et41
(better off running OEM tire sizes so the rear tucks in)
Two wheels by Vorsteiner in this fitment: 1. Vorsteiner V-FF 107 Carbon Graphite by Vorsteiner Wheels 2. Vorsteiner V-FF 103 Carbon Graphite by Vorsteiner Wheels
19x8.5 et35
19x9.5 et46
(verified that 19x8.5 et35 clear brake calipers in the V-FF 107)
5 options from Vossen in this fitment: 1. Vossen CV3-R by Vossen Wheels 2. Vossen CVT by Vossen Wheels 3. Vossen CV7 by Vossen Wheels 4. Vossen VFS-1 by Vossen Wheels 5. Vossen VFS-2 Silver Polished by Vossen Wheels
19x8.5 et30
19x10 et55
