C450/C43 AMG
2016 C450 AMG turbo upgrade project
Old Dec 11, 2020 | 05:39 AM
  #176
Hrd_workin's Avatar
2016 Mercedes C450AMG sedan
Originally Posted by Trekt43
I am heading in that direction. I have upgraded lpfp and HPFP installed and upgraded rail on the way.
I believe injectors should be fine. I believe we have the same injectors as v8’s which run full e85!
Nice, that is great to know. Didn’t want to upgrade the fuel system only to get stuck at the very end with non-compatible injectors. Thanks
Old Apr 6, 2021 | 05:34 PM
  #177
Jinxsaw's Avatar
C450 AMG
Did you gave up on your project?
Old Apr 8, 2021 | 07:24 PM
  #178
Hrd_workin's Avatar
Moving forward
Just wanted to update everyone as it has been sometime.
Hope this continues to find you all safe and healthy. Been busy as s__ but worked out since waiting for the FX-180 HPFP, custom LPFP and fuel rail to come in.
Special thanks to Dan at Martintuning.com for all the help with getting these done. Very easy to work with and considering the scope was done fairly quickly.
Next step is to find a fair priced shipping company (closed trailer) to ship from Dallas to San Francisco for the full engine pull and build.
Anybody have any recommendations based on personal positive experience with specific car transport companies?
Thanks 🙏 Martintuning.com! Looking forward to getting these installed
Old Apr 8, 2021 | 07:25 PM
  #179
Hrd_workin's Avatar
Thanks for following
Old Apr 9, 2021 | 09:48 AM
  #180
Star4life's Avatar
2017 C43 AMG
Following!! Excited to see the results! Martin Tuning is an awesome new company. I like the support Dan gives!
Old Jun 3, 2021 | 07:28 PM
  #181
Jinxsaw's Avatar
C450 AMG
How is it going / i am so excited to see the finished build..
Old Jul 4, 2021 | 06:09 PM
  #182
Hrd_workin's Avatar
UPDATE. Happy 4th!
Thanks for following and Happy 4th of July to everyone.
Been a minute but here is an update on the project.
Finally glad to see things moving again, car has been shipped and taken delivery by my man Cesario and his team at SVG, Silicon Valley Garage.
Motor should be pulled next week after initial dynojet dyno and engine build begins.
Also decided to take it in the direction (apologies to the purists, couldn’t resist) with custom carbon fiber trunk and interior work as well as a full wide body kit and wrap.
Thinking about going with the Pearl AMG red.
Hopefully the build keeps moving forward to get this out to AMR for turbo installs/Meth/Tune upgrades and TCU tune.
cheers!
Silicon Valley Garage. Thanks for the connect Chris!
Wide body pic 1
Wide body pic 2
Wide body pic 3
Pearl red wrap to match carbon fiber/red interior & exterior
Old Jul 4, 2021 | 10:37 PM
  #183
b6tbfmp's Avatar
Mercedes and BMW
cheers!
Wide body pic 1
Wide body pic 2
Wide body pic 3
Great follow up! Cesario is awesome!!! Keep us posted.
Old Jul 6, 2021 | 08:00 AM
  #184
TurboKits.com's Avatar
SPONSOR
2014 CLA 250
Thanks for the update. What a build in process!!
cheers!
Wide body pic 1
Wide body pic 2
Wide body pic 3
Old Jul 6, 2021 | 08:18 AM
  #185
TModelle's Avatar
C190
Great to see this finally progress further, I’m glad that I had a hand in helping with the con rod selection and supply almost two years ago!
Can’t wait to see the final build.
Old Jul 7, 2021 | 10:43 PM
  #186
sliqdaddy91's Avatar
C450 AMG
unbelievable build, looking forward to the updates!
thank you for pushing this platform further and further
Old Sep 10, 2021 | 01:12 AM
  #187
Hrd_workin's Avatar
I know right! LOL. Thanks so much for the help with that. @TModelle
Old Sep 10, 2021 | 01:28 AM
  #188
Hrd_workin's Avatar
Hello all and hope this finds you all well.
Just an update, so SVG has been doing well and has expanded to a much larger shop so things have been moving along as expected for a “no rush” project.
That said we have been looking for a
dynojet dyno similar to the one AMR in CT has so that apples can be compared to apples with the pre build dyno and post build final tuned dyno.
unfortunately where my man Cesario is at there isn’t any to be found around within a reasonable distance. What seems to be common is the Mustang Dynometer.
So before the engine is pulled decided just to get some base dyno numbers.
So the base is with the AMR Stage 2 bench tune, Weistec DP’s, VTA’s, and AWE track exhaust on 93 octane pump on Sport+ mode.
Pre-build dyno
When all is said and done this will be compared to dyno numbers with the upgraded turbos, forged Pauter rods and low compression JE pistons, full upgraded fuel system, Wagner intercooler, upgraded HP and LP pumps, Water/Meth, AMR custom tune and TCU tune running on E85.
Old Sep 10, 2021 | 03:14 AM
  #189
Datastream18's Avatar
16' C450 AMG
Are you pushing for 550-600 awhp? The stage 2 numbers are impressive by them selves. I'd be curious about the tq curve with the new set up. Stage 2 would be like a quick punch than fades. New set up would, I assume (gasp I know) be more linear?
Keep it up dude. It's only money, right?!
Old Sep 10, 2021 | 06:01 PM
  #190
AhEmGee's Avatar
2004 E55 K Wagon &. '96 SL500
Pre-build dyno
I believe Mustang dynos read low compared to Dynojet ?
​​​​​​As on a Dynojet this car would typically Dyno 415-425 whp with those mods .
Old Sep 11, 2021 | 12:19 AM
  #191
C43HeartBoost's Avatar
C43
Really looking forward to some post-build results. Do you have any pre-build draggy or drag slips to compare to post-build? Good luck!
Old Nov 11, 2021 | 07:49 PM
  #192
Hrd_workin's Avatar
Hey thanks for following, I do have some dragy times…not too good but at least I have some plus the dyno.
thanks again
Old Nov 11, 2021 | 07:59 PM
  #193
Hrd_workin's Avatar
UPDATE: ENGINE FINALLY PULLED!
Hello everyone,
Just an update and finally a milestone in this project. My man Cesario over at SVG just sent over some pics!
Engine and assembly is dropped and engine build is on its way.
Pistons, rods, head bolts, Wagner cooler, HPFP, LPFP, Fuel rail is on its way to getting put in.
I’ll keep posting as I get update.
As planned once all this is done plus a new custom CF trunk lid it finally is going to make its trip up to CT to AMR for TCU upgrade/tune, install turbos, Meth kit, and custom dyno tuning.
stay tuned and thanks again for everyone’s continual help on this project and thanks to Cesario at Silicon Valley Garage!
On the lift at Silicon Valley Garage
Brand new rack holding the prize at Silicon Valley Garage!
There she is!
Old Nov 11, 2021 | 09:15 PM
  #194
BoolitSpunjBoon's Avatar
C450 AMG
I think everyone in the community is looking forward to these results. Thanks for the update!
Old Nov 11, 2021 | 09:31 PM
  #195
C43
Agreed.
Old Nov 12, 2021 | 07:59 AM
  #196
SPONSOR
2014 CLA 250
Excellent!!!!
Old Nov 13, 2021 | 02:09 AM
  #197
Hrd_workin's Avatar
Originally Posted by TurboKits.com
Excellent!!!!
Thanks buddy! Hope all is well.
yeah just hoping those @TurboKits.com turbos that have been custom PTP heat shield wrapped are still ok sitting over with Matthew at AMR now for the last year or so.??
Old Nov 13, 2021 | 02:15 AM
  #198
Hrd_workin's Avatar
BIG brake upgrade
Hello @Star4life and @TModelle again AMAZING work on the custom front and rear big brake caliper conversion.
I did respond to your all’s thread but figure I’d post here as well.
Since the whole assembly is dropped wanted to proceed with the front and rear big brake upgrade.
Once again I wanted to see if you all could guide me through this process on what all I need/ could buy and send over to SVG to get this rolling.
Sincerely appreciate your guys help, Thanks in advance.
Old Nov 15, 2021 | 09:44 AM
  #199
SPONSOR
2014 CLA 250
Yeah, should be good to go. Just make sure they are primed extra well before the first start so that the bearing system is saturated with oil. Would also be a good idea to squirt some oil into the oil feed with a syringe and manually turn the wheels by hand to work in some lubrication before the much higher shaft speeds of a first start...
Old Nov 16, 2021 | 10:43 AM
  #200
Star4life's Avatar
2017 C43 AMG
just pmd you man!
