2016 C450 AMG
Have fault code P13B0-11 "Output for On Board Electrical system Switchover has a short circuit to ground"
I allready replaced teh Rear SAM module.
Any help would be appreciated
CaliBenzDriver
close
- Join DateApr 2019
- LocationSilicon Valley
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW212 MY'14 M276-3.5NA @75kMi
Liked:6,776 Times in 4,765 Posts
Sorry you got walked around with limited success. The true fix is tied to researching the fault criteria.Originally Posted by msduffy10
2016 C450 AMGHave fault code P13B0-11 "Output for On Board Electrical system Switchover has a short circuit to ground"
The code description is purposely kept vague however the code itself is tied to a specific criteria.
Fix may be 5mn cleaning oxidized connection, WHERE is the question @BenzNinja can help you answer.
As with all electric problems, isolate what works and what don't work?
Helps to narrow down the problem.
Its a long shot but check the trunk wiring that goes to the trunk lid.
Some models have had split insulation on the wires and shorted.
Near the hinge where they split.
Sorry you got walked around with limited success. The true fix is tied to researching the fault criteria.The code description is purposely kept vague however the code itself is tied to a specific criteria.
I am having the same issue so I would like follow on and see if you found a solution
Explore
