C63 AMG (W204) 2008 - 2015
Best way to LAUNCH? ESP/Sport/ESP OFF...
Old Mar 2, 2009 | 06:41 PM
iLc63's Avatar
'09 C63 ///AMG
What is the best way to launch the C63? I either get way too much tire spin (esp off) or it goes into limp mode (esp on or sport on). Which mode do you race in?
Has anyone started the launch w/ either "esp on" or "sport on" & then turned "esp off" after the launch and in the midst of racing?
Old Mar 2, 2009 | 08:09 PM
qship5's Avatar
M5, C63, 335Ci
ESP off and learn to modulate the throttle. Trying to switch ESP off in the middle of a race is both silly and dangerous.
Old Mar 3, 2009 | 07:48 PM
mzporto's Avatar
2009 C63 AMG / 2007 BMW 130i M Sport
ESP off, sport on. Just dont floor it and you will be fine.
Old Mar 3, 2009 | 07:51 PM
BerBer63's Avatar
2009 C63
Used ESP-Sport, Sport mode today....just feather the throttle.
JAYCL600's Avatar
new balance
hmmmm, this sounds familiar
Old Mar 4, 2009 | 01:06 AM
Merc63's Avatar
C63 AMG
Why would you use sport mode? I'm pretty sure shifts are faster in Manual mode...
Old Mar 4, 2009 | 01:11 AM
C_63_UAE's Avatar
08 C63
They are
Old Mar 4, 2009 | 03:25 AM
Merc63's Avatar
C63 AMG
There we have it manual mode for the win.
Old Mar 4, 2009 | 04:24 AM
yooker's Avatar
a durr
The shifts are faster, but S mode is more consistent at shifting up every time at redline while you have to anticipate it with the paddle shifters in M mode. If you calculate the rate at which the tachometer needle is rising and the time required for the car to actually shift gears from the moment you click the paddle, then you will be faster than in M mode.
Old Sep 5, 2010 | 01:00 PM
jassimaljaber's Avatar
2010 C63 AMG 2011 G55 AMG
try this. ESP off manual mode and just floor it..
don't let the car take you sideways
Old Sep 6, 2010 | 01:14 AM
Sincity's Avatar
Ok. Which mode does Dad's and Jrcart use?
Old Sep 6, 2010 | 02:52 AM
SonnyakaPig's Avatar
MB
From what I hear, the best method is ESP-Off, and transmission in Sport, tap the downshift paddle one time to bring up another shifting option which only shifts at redline. Ease into the throttle.
Old Oct 2, 2010 | 02:39 AM
AL Hosani's Avatar
C 63
the easiest way is just ESP-sport + S mode + floor it = best time + less tire burning
you'll get the best timing
cuz sometimes when in M mode u rather shift up a little faster or slower
and in a race u DONT NEED THAT so ... this way is 100% the best and the easiest
Old Oct 2, 2010 | 03:15 PM
brian0473's Avatar
C63
Sounds like a good excuse to head to the strip and try each combo and report results back.
Old Oct 2, 2010 | 11:44 PM
Dios's Avatar
C63
Posted a 12.9 in sport mode, esp sport, and i floored it the whole way thru
Old Oct 2, 2010 | 11:55 PM
sighting's Avatar
e63s edition 1
Did you tune yours? i spin the tires starting in second if i floor it never mind first//
Old Oct 4, 2010 | 01:51 PM
Dios's Avatar
C63
No tune, it was a perfect run
R/T 0.349
60' 1.759
330 5.329
1/8 8.288
MPH 82.62
1000 10.842
1/4 12.989
MPH 105.06
With bf goodrich gforce (soft tire)
Old Oct 4, 2010 | 05:11 PM
Ubermensch's Avatar
2010 C63
Only a 105 trap? Shouldn't our cars be trapping around 115?
Old Oct 4, 2010 | 06:58 PM
Dios's Avatar
C63
Thats what the ticket said, i was running 13.2s and 13.3s before
Old Oct 4, 2010 | 07:34 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Must be high DA.
Old Oct 4, 2010 | 07:36 PM
The best way I do it is put in esp-sport, manual mode,feather gas,gradually WOT going into 2nd.
Old Jan 27, 2011 | 05:57 PM
skoobz2001's Avatar
2011 C63 P31
I'm excited to hit the track with the C63 this spring - I'm coming from an AWD Jeep SRT8 that had similar HP numbers (and ran a 13.49 1/4) - but was pretty much "drag racing for dummies". Basically, it went something like:
1. Autostick on
2. Wait for second light
3. Stomp it
Looking forward to a little actual skill involvement - but I'm scared my times will be a disappointment. Our track is at 2200'! That, plus the learning curve, is a recipe for a frustrating (but fun) first track day. I guess the only advantage we have here in Northern Alberta is that our air temperatures when the track opens tend to be nice and cold...
Old Feb 23, 2013 | 04:06 AM
kaz109's Avatar
E46 M3,15 Yukon Denali,09 C63
Bump to find out if my way will yield me the best time on my PSS street tire...
ESP sport mode
Trans in S+ mode
Launch at 2200rpm and feather until 2nd then floor it
Sound like a winning formula? Also what psi should my tires be at?
Old Feb 23, 2013 | 04:29 AM
C-63AMG's Avatar
C63 AMG
I went out to open roads when I fitted the 295 PS2's.
I tried:
ESP off - Sports mode & Comfort mode
ESP on - Sports mode & Comfort mode
ES Sports - Sports mode & Comfort mode
The best times I clocked from launch repeatedly was with
Sports ESP and Sports mode and just slam the pedal from the lights.
Old Feb 23, 2013 | 04:37 AM
kaz109's Avatar
You had a better time is sport mode? How did S+ not give u better results
