C63 AMG (W204) 2008 - 2015
alignment cost and tire rotation
Old Jun 15, 2009 | 11:44 AM
bluejae's Avatar
'10 C63
i just took my car in for service B and they suggested an alignment and tire rotation.
i didn't feel i needed a tire rotation considering i had replaced the tires not too long ago. but that was $59 i think
and the alignment would be $265.
is this about right costwise?
update: they also noted to me that i would be due for a brake fluid and power steering change.
brake fluid $129
power steering $169
Old Jun 15, 2009 | 12:04 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Alignment usually cost $100.00 at any good alignment shop.
Tire rotation do they dismount and mount tires other wise is not worth it.
Old Jun 15, 2009 | 02:44 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
some shops even offer lifetime alignment service...
Old Jun 15, 2009 | 05:19 PM
Autoscope's Avatar
Former Vendor of MBWorld
E350 Sport & Rs6
brake fluid $129
power steering $169
Brake Fluiud and power steering? How many miles are on our C63?
Where are you located?
Our alignments are around $150...
Old Jun 15, 2009 | 05:48 PM
Blk04cobra1's Avatar
2002 S430, 2004 Cobra, 2004 Tahoe
I agree that $150 sounds about right for an alignment and btw you don't rotate the tires on a C63...
Old Jun 15, 2009 | 05:59 PM
bluejae's Avatar
'10 C63
20,161
Dallas
they said the fluids still have life in them. it's not black. but suggested it.
and yeah i know... it's just what they said to me.
Old Aug 6, 2009 | 06:59 PM
bluejae's Avatar
'10 C63
so do my brake and power steering fluids need to be changed?
Old Aug 6, 2009 | 07:48 PM
Balz's Avatar
C63, LR3
you can't rotate the tires on a C63...they are staggered...
Old Aug 6, 2009 | 07:51 PM
DFW01E55's Avatar
'14 ML BT
Call Adam (above), you won't end up with work you don't need done.
Old Aug 6, 2009 | 07:53 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
Something fishy here........Although I once had wheels swapped on a new M3 at the dealer and they tried to deliver the car with the unidirectional tread facing the wrong way. I had to explain to them what the rotation arrows were for. This was back in 99 and it may have been an unfamiliar issue at the time.
Old Aug 6, 2009 | 08:17 PM
hhughes1's Avatar
Just checked the 2 Pzeros that I still have and there is no rotation indicator only an "outside" stamp. Perhaps they can be rotated from side to side?
Old Aug 6, 2009 | 09:07 PM
Fangster's Avatar
Lotus 7 S4, 09 C63 Palladium with Black leather interior
They are directional so the only way to rotate side to side is to dismount the tyre from the rim and replace it in the opposite direction. Not worth it!
Old Aug 7, 2009 | 04:13 AM
GMW's Avatar
GMW
2013 ML63 AMG PP
actually.....
Actually they only have "outside" markings so you can rotate on same axle only. If they were directional like Goodyear F1 GSD3 then you get an arrow or directional marking. Therefore, you can switch one rear to the other rear side or front left to front right etc.
Old Aug 7, 2009 | 05:12 AM
Merc-Skycap's Avatar
AMG & RR
+1
