ESP
If you want to 'test' out your (non PP, non-LSD) C63 AMG and do a couple runs with your accelerometer (or at the track), what ESP setting do you use...ESP auto (if that's even a setting), on, sport, or off?
What are the differences?I did a couple runs without touching the ESP button (whoops, I forgot to switch it
) and obviously got major intervention, bogging, and some seriously bad times, lol.Thanks.
esp sports has a higher tolerance level than esp on, where the computer kicks in to ensure that your vehicle does not slide left, right and center at higher speeds..
having esp off = pure driver skills and confidence is required to handle the vehicle..
take your time to you know your C63.. try out some advance driving lessons too.. you'll appreciate the engineering better that way
just my 2 cents worth..
I have been so completly out of control with my car in esp OFF mode. Fishtailing like a *&%$ and thought I would be in the wall. I tried everything I know to straighten it , gasing it, stearing, everything, and NO LUCK wall coming quick. I did a hard brake complete to the floor, and stright wheel and the car came around. It straightned up and came to a good safe stop. To me it did seem the ESP kicked on or something helped to correct the car to straighten up and stop fishtailing. After I got the car stopped I did floor it and the tires broke loose again and the ESP was off and could tell it was off. Even under hard braking the ESP will go back to its set position you selected. If it changes to "on" under critical situations, like A$$ savers, I am not sure but sure seems like it, but will go back to preselected modes. Thats just my observation. Maybe more expeiranced drivers can say more.
Be safe.
ESP ON - Wont allow spinning of the tires and controls engine torque in tight turns.
ESP SPORT - Will allow the back end to spin slightly, but not out of control.
ESP OFF - Will allow you to spin continuously. If the brakes are hit during a spin or while the back end is out hard, it will kick in then go back off once your off the brakes.
I drive with ESP off all the time.
You definitely need ESP off at the track otherwise it will come on and wreck your times. Learn throttle control to stop wheel spin.
Be safe
