C63 AMG (W204) 2008 - 2015
AMG 6.3 high-flow airbox demystified
Old Apr 1, 2010 | 11:46 PM
  #101
Behike's Avatar
2011 G55
Originally Posted by Sincity
It probably won't show much or anything on the dyno. But the opening is larger and the tone from cold start sounds a little different now.
I see. Thanks.
Old May 2, 2010 | 05:19 AM
  #102
AbdullahROM's Avatar
2011 cayenne turbo ,2010 750 li,2010 c63, 2008 ml63,2008 lx570, 2006 modded f150
i live outside the US. is there any power gains if i install the EVOsport carbon airbox?
Old May 2, 2010 | 12:41 PM
  #103
jafores's Avatar
08 C63, 07 ML63, 92 500E, 70 300SEL 6.3, 63 220 SEB Conv. Sold 02 G500, 97 E50,92 C280,71 280SE 4.5
Here are 2 graphs of runs I made, the higher one is with the ROW airbox and the lower one is a run with the US airbox without the charcoal filters. sorry the operator made a mistake and labeled them carbon.
This is a comparative of runs I made with the US air box, the Highest graph is without the Charcoals while the middle one was with the charcoals still in place. Please disregard the lowest graph.
I guess you can infer that the Charcoal delete gave 5 horses while the ROW box added another 5 for a total of around 10 WHP for the mod.
Old May 2, 2010 | 01:24 PM
  #104
bhamg's Avatar
C63 AMG
Thanks for posting these. They make sense to me in that I installed the ROW tops a few months ago and noticed nothing different whatsoever in any kind of driving. Visually comparing the tops however, it quite surprising to see how much more restrictive the OE top might be as the ROW top looks almost aftermarket. I'd really be surprised if there were not measurable differences in power in real-world road driving conditions between the two, so what you experienced on the dyno makes a lot of sense to me.
Old May 2, 2010 | 09:41 PM
  #105
jafores's Avatar
[QUOTE=bhamg;4056368]Thanks for posting these. They make sense to me in that I installed the ROW tops a few months ago and noticed nothing different whatsoever in any kind of driving. Visually comparing the tops however, it quite surprising to see how much more restrictive the OE top might be as the ROW top looks almost aftermarket. I'd really be surprised if there were not measurable differences in power in real-world road driving conditions between the two, so what you experienced on the dyno makes a lot of sense to me.[/QUOT
Although the top graph is in miles, there seems to be a sizable increase in both power and torque between 3000~4500 rpm. Thing is considering what you have as a baseline the additional 20hp or so may not be as noticable
Old May 3, 2010 | 02:41 AM
  #106
harrower's Avatar
2009 C63, 2007 GL 450
I installed the ROTW airboxes and did not notice much of a difference at all EXCEPT through the powerband at 3000-5000 rpm where there seemed to be more punch than the standard airboxes. Now that been said the combination of ROTW airboxes and K1 tune may be the reason for this preceived increase in power.
Old May 3, 2010 | 05:23 AM
  #107
is there a diffance ( in terms of power gain) between the ROW and the Carbino box?
Old May 3, 2010 | 01:39 PM
  #108
bhamg's Avatar
C63 AMG
Absolutely true...I just don't know the car well enough yet and even if I did I doubt I could feel the difference 10 or 15hp makes. Your dyno chart indicates some really impressive gains in the sweet spot of the power band (from the perspective of a DD) which is very exciting to see. I'd rather have it there than way up on the power band. Notwithstanding my seat-of-the-pants experience I'm pretty confident that some useful additional power is liberated by the ROW top.
Old May 3, 2010 | 03:53 PM
  #109
Sincity's Avatar
I noticed the cold start sound has changed to a slightly more agressive note.
Old May 3, 2010 | 06:18 PM
  #110
boomer8800's Avatar
14 SL550
Before I go to the MB Stealer-ship confirming these are the correct part#'s
LT side A1560940306
RT side A1560940406
Old May 3, 2010 | 06:42 PM
  #111
bhamg's Avatar
C63 AMG
Hmmm, gotta get some more Q-tips.
Old May 3, 2010 | 10:31 PM
  #112
Jae Duk's Avatar
'09 C63
Get something better...I think it's called debrox or something. Available over the counter...put a few drops in and EVERYTHING comes out
Old Aug 22, 2010 | 10:10 AM
  #113
Dark_Knight's Avatar
GT2 C63 and yo sister
can someone answer tell me why there are charcoal filters there in the first place?
Old Aug 22, 2010 | 11:17 AM
  #114
Even Money's Avatar
'15 VW GTI
Emissions when u turn off car.
Old Aug 22, 2010 | 08:23 PM
  #115
you've gotta be kidding! I have to have the performance of my car decreased because it might give off emissions when I turn it off? Whats this world come to? I need a bumper sticker for when my car gets here that says "proud to get 12 mpg"
Old Aug 25, 2010 | 04:26 PM
  #116
SonnyakaPig's Avatar
MB
Based on the dyno graph above, the ROW box seems to provide a sizable increase in the meat of the power band, namely rwtq. I would think 20 rwtq increase in the middle of the power band could be felt for sure.
So, my questions are, does anyone know if AFR is affected by changing to the ROW box? Was AFR checked in the dyno run that is posted above? I am asking this because at this point, I am not getting a tune. Down the road I will.
Is there any surging or bucking at low speeds because of the change in air velocity that goes past the MAF given the larger opening in the ROW boxes? I know a tune can remedy these symptoms but like I said I don't want to get a tune yet.
I know that sometimes, when you change the air intake system on a car, you need to get a tune and other times you don't. I'm really curious to know if the USA C63's ECU will compensate for the increase in intake velocity given that the TB only opens part way because of the stock tune.
Any feedback to my questions would be appreciated.
Old Aug 25, 2010 | 04:37 PM
  #117
PetroC63's Avatar
2012 CTS-V
Based on tuner feedback given to me, the ECU will adjust accordingly
and a tune is not needed for this modification.
Old Aug 25, 2010 | 04:47 PM
  #118
bhamg's Avatar
C63 AMG
Sonny - When my MBH header/cat system and RENNtech tune was installed I was very specific about a desired post-tune AFR endpoint (12:1+), even if it meant sacrificing a few peak HP in the process. I was not around for the baseline dyno testing but with OE mapping, 6k miles with the ROW airboxes and new OE air filters the AFR ran well into the 13's at points. YMMV.
Old Aug 25, 2010 | 04:59 PM
  #119
PetroC63's Avatar
2012 CTS-V
Interesting, I was told the ecu would adapt but I think this particular
tuner may have been talking about a vehicle with a tune.
Old Aug 25, 2010 | 05:24 PM
  #120
MB
Thank you for the feedback.
I'm new to the AMG world. I am coming from a 5th generation Chevy Camaro. With that car, if you are staying naturally aspirated, and you have crappy 91 octane gas, you want your AFR to be max 11.6 I would say (+/- a couple points).
Stock, from the factory, I think the Camaro's a pretty rich, low 11's and even high 10's from what I understand. So, adding an intake can sometimes lean the car out a little, which can have a nice result.
When you add forced induction to a Camaro, you don't want the car to run too lean because it can be very dangerous.
Now that I am learning about the 6.2 AMG engine, I am noticin higher AFR numbers that what I was used to seeing in the Camaro world.
For example: https://mbworld.org/forums/c63-amg-w...-2010-c63.html
Now, obviously, Superlubricity's car makes great numbers and looks to be in great shape, but you can see that his AFR goes into the 13's often. Is this okay on these cars?
If so, then I would think changing out the US air boxes for ROW boxes would be safe, even without a tune, because if your car saw AFR in the 13's with this mod, that doesn't seem too different from what other "tuned" cars are seeing on this forum.
But, of course, that depends on what you mean by "well into the 13's." If you're saying it was close to 14, then I would say this mod needs an accompanying tune, because I would think running out of fuel might be an issue if the car is staying above 13 AFR.
Old Aug 25, 2010 | 05:25 PM
  #121
MB
That's what I'm trying to figure out. I appreciate the response, though.
Old Aug 25, 2010 | 08:28 PM
  #122
brad @ evosport's Avatar
PREMIER SPONSOR
None fast enough!
You do not need a tune for airbox. The cars run safely into he 13's. The ECU will pull timing if it sees detonation or knock.
thanks
brad
Old Aug 25, 2010 | 08:37 PM
  #123
cls55's Avatar
brad
do we need a tune for LT headers and the carbonio box`s?(ML63)
thank you
Old Aug 25, 2010 | 08:40 PM
  #124
PREMIER SPONSOR
None fast enough!
Originally Posted by cls55
brad
thank you
You will not need a tune for any airbox.
You will not "need" a tune for any mod on the 63 in fact. The ecu will not allow the car to run into danger zone.
However, and this is a BIG however, you will get sub-optimal results. What will happen is the car will sense knock, ping, detonation or other "out of normal parameter" readings and pull timing and/or fuel. So you will have a car that you spent a lot of money on mods that runs like crap (often worse than stock).
thanks
Brad
Old Aug 25, 2010 | 08:43 PM
  #125
cls55's Avatar
thanks
