Oil Drain Plug(s)
And while I'm the subject, would the top-side way extract the oil in the cooler (about 1 qt according to post above)? I was under the impression the oil from the cooler drained into the sump after shutting the engine down
On a different note, the SA where I bought my filter claims synthetic oil has a functional life of over 13000 miles and hence the reason MB calls for oil changes at 10000miles. He recommended that I just replace the filter element to filter out any contaminants in the oil the old filter has stopped filtering. In his opinion, new oil is not needed. Thoughts?
My beast is going in for it's first oil change (to the dealer) and I've reread SuperLube's post on the Minivac deal and at the end of the post he showed pics of the oil being drained from the pan and the cooler. I know most people are just happy with a suck job
and call it done, but I think I want the dealer to drain everything, including the cooler.I am worried that the tech will cross thread a plug or mess something up, especially if getting to the oil cooler drain is a biatch
So what has to be done/removed to get to both the pan drain and the cooler drain?
How much disassembling needs to be done?
Maybe I can live with a standard suck jobber!
Can anyone answer this?
Thanks in advance
https://mbworld.org/forums/c63-amg-w...-photos-4.html
Should I have the dealer order new plugs and washers?
I had them replace my plugs when I had my LSD serviced, they wanted to reuse with loctite.
So if it just involves removing the lower plastic shields and drain plugs, I guess it's not too involved for the tech? I just wish I had the ability to do this myself, but I don't have the facilities.
This all got me thinking, if there's roughly a quart left in the cooler, etc wouldn't the new oil and filter eventually filter out most of the old contaniments via the new filter?
So maybe the minivac approach is not the end of the world? And the tech doesn't have to do much to my car, thus limiting the possibility of cross threading, over/undertightning plugs, leaky drain plugs, loose plastic panels, etc.
I just like to limit the time the dealer spends on my car.
There's no doubt, IMO, draining the pan and cooler is the best approach--but maybe the minivac approach is "good enough."
Thoughts?
I just can't decide what to do.
I wish I could find a mechanic like the old timers who actually cared about the cars they work on and respected the machine.
Unfortunately, with the advent of financing, just about anyone can buy or lease an enthusiast car and they have become common place and no big deal to own and many people treat them like throw aways and unfortunately the dealerships feel the same way.
I'm just very type-a and treat all of my things the way they should be treated because I know how much work I had to do to buy them!
The drain plug at the front of your E 63 AMG engine is not convenient for draining the oil. Following the service instructions on the E 63 AMG, only the drain plug in the oil pan at the back of the engine is appropriate for draining the oil. Extracting through the dip stick is not possible either. A nearly complete emptying is guaranteed while your engine is at operating state temperature. A possible remaining quantity in the front area is negligible.
We hope this information finds you helpful.
Best regards,
AMG Private Lounge Team
