Dyno: Kleemann K1, "ROW" airbox, K&Ns
Mods:
-Kleemann K1
-"ROW" AMG airbox tops
-K&N filters w/charcoals removed
Conditions:
-65 degrees
-17% humidity (approx)
-2000 ft elevation (approx)
-1673 current mileage at dyno time
Max results after 3 pulls in 4th gear (SAE smoothing 5):
421.75 HP/384.30 TQ
It was good to meet you, Tony.
My tuned numbers are pretty close to what you have (K1, filters, charcoals removed). I also noted that temp was close to the same, but our humidity is much lower and elevation is much higher.
605 to the wheels
what a beast.. Ok, so NOW we have your base line
from here on out your clime begins.. Have some fun Next time you go to that dyno, bring a USB flash drive. You can download the runfiles (even today's) and view them at home in WinPEP software (free from dynojet.com). This will allow you to play with the data and even see the actual uncorrected horsepower/torque from each run.
My budget is nowhere as big as yours. I will be taking "baby" steps. Can't wait to see what power your new mods will net.
A full 4th gear dyno run was performed with the parking brake on?
What's your opinion when comparing EC to K1? Is one better than the other? It's an honest question because I don't know and can't find any unbiased direct comparisons.
Here is a post worth reading -> https://mbworld.org/forums/c63-amg-w...iscussion.html
Airbox: https://mbworld.org/forums/c63-amg-w...mystified.html
Appreciate your feedback.
