ME 97 Data Logger/Programmer... Do you know what your car is doing? I do !
Subscribe
Jul 12, 2010 | 09:37 PM
If you dont know about this, read this thread ASAP. I just got an ME97 Data logger... A neat little device that is so easy to use and install....
This device comes with Software,OB2 Device & Adapter for ECU Programing. First off let me say I am not a computer guy at all... But this was very very simple.. First I installed the software given to me on a CD Rom.
Then I connect the OB2 Device into my computer USB and set it up for data logging. This thing can log everything. I has so much info you would not believe it. From RPM, EXHAUST TEMP, TORQUE AT THE CRANK, LOAD, SPEED, & THE LIST GOES ON...
THEN I CAN REVIEW THE DATA ON MY PC... YOU CAN ACTUALLY SEE YOU CAR AT WORK...
WITH THIS I CAN ALSO GET MY ECU PROGRAMMED WITHOUT LOSING MY CAR ANYMORE... EXAMPLE, I AM GETTING AN X PIPE INSTALLED THIS WEEKEND , MY TUNER LOOKS AT DATA BEFORE INSTALL THEN AFTER. TUNER CAN MAKE ANY ADJUSTMENTS AND SENDS ME NEW FILE, I PUT IT ON THE CAR MYSELF..
OH YEAH ONE MORE THING.. I ALSO GOT MY STOCK TUNE FILE THAT I CAN PUT BACK ON THE CAR AT ANYTIME...
THIS THING IS BAD ***!! AND YOU CANNOT ASK FOR ANYTHING EASIER... ANYONE CAN DO IT...
THANK YOU LOLA CHAMP CAR FOR YOUR ENGINEERING AND DEVOLPMENT OF THIS PRODUCT... I FEEL LIKE I AM PLAYING WITH ALL OF MY POWER NOW...
ME 97 Data Logger/Programmer... Do you know what your car is doing?  I do  !-photo.jpg   ME 97 Data Logger/Programmer... Do you know what your car is doing?  I do  !-photo2.jpg   ME 97 Data Logger/Programmer... Do you know what your car is doing?  I do  !-untitled.jpg
Reply 0
Jul 12, 2010 | 11:25 PM
So where do we get them?
Josh
Reply 0
Jul 12, 2010 | 11:31 PM
Is this from Lolachampcar?
Edit-NM. I see it is.
Reply 0
Jul 12, 2010 | 11:45 PM
how much does it cost?
I really need one.
Reply 0
Jul 13, 2010 | 07:41 AM
NOSONYXC63, thanks for your kind words. I am a nerd and really love tons of data when tuning. I am glad to hear non-nerds have a use for it as well.
.... A thank you as well for the use of your car to get the Data Logger up and running on the new gateway enabled AMGs.
With respect to buying programmers/loggers, they are sold through several tuners in the US. TTM or Tuning Technology Motorsports is a registered forum vendor and can supply the programmer/logger for the 63s (and Kompressor and turbo cars as well).
I made an offer in another thread to provide a couple logger/programmers for testing. Please see https://mbworld.org/forums/4152028-post148.html . I sent one out yesterday to a forum member in CA and am willing to support one more member. Please PM me if you are interested.
Reply 0
Jul 13, 2010 | 08:04 AM
We are all interested in knowing cost of the programmer and I am not sure I read the posts correctly but do you have to buy a software specific to our C as well. Please expand.
Reply 0
Jul 13, 2010 | 09:41 AM
There are two different MB versions of the device, one for the ME97 ECU found in the AMG 63s and another for the ME2.7.1 and ME2.8.1s found in the earlier cars (Kompressor and Twin Turbo).
The ME97 version supports data logging and reflashing. The log data viewer is a free download at http://www.efidude.com/downloads/ME97_Logger/install.htm . PM me with your email address and I can send you a sample .dat log data file from a tuned C63 so you can give it a go. I would post it here but .dat files are not permitted. The programmer part requires that the ECU be enabled for programming after which the end user can switch calibrations in under a minute (stock, tune 1, tune 2, tune 3, etc.). It works like having several ECUs married to your car without the cost or the bother of swapping out the ECUs. There is no software required on the PC for the programmer. The device looks like a memory stick and you just drag and drop files on it.
I hope the above removes the confusion.
Reply 0
Jul 13, 2010 | 11:42 AM
Lola: Are you looking for non-tuned vehicles only?
Reply 0
Explore
Jul 13, 2010 | 11:58 AM
Valet mode will be nice. Limit the car to 50 HP. It would be nice if it was like the GIAC hand-held.
Reply 0
Jul 13, 2010 | 01:45 PM
Quote: Lola: Are you looking for non-tuned vehicles only?
I joined a thread talking about tuning the C63 and proposed the idea of a cost effective entry level state of tune for the car that consisted of migrating AMG's E63 maps to the C63 firmware. Only the maps that serve to restrict the C's output would be moved of course. As part of that discussion, I offered to support two forum members with the technical support and loaner hardware if they would document the process and post the logged data. The idea was to evaluate an "E on C" tune to see if it was worth the effort. If it is, then perhaps there are some tuners out there that would like to step up to the plate and provide such an entry level tune.
Reply 0
Jul 13, 2010 | 06:41 PM
Quote: Only the maps that serve to restrict the C's output would be moved of course.
Would this mostly be in the Torque Management tables?
Reply 0
Jul 13, 2010 | 07:05 PM
Quote: Would this mostly be in the Torque Management tables?
Throttle Limit.... My foot was too the floor on this pull but look at where the ECU caps throttle opening on this stock C63!
ME 97 Data Logger/Programmer... Do you know what your car is doing?  I do  !-c63-limited-wot.jpg
Reply 0
Jul 14, 2010 | 12:42 AM
Will it work on a mac?
Reply 0
Jul 14, 2010 | 04:31 AM
this can can let the end user alter target values then?
Reply 0
Jul 14, 2010 | 08:12 AM
Quote: this can can let the end user alter target values then?
https://mbworld.org/forums/4157670-post10.html
Reply 0
Jul 14, 2010 | 08:41 AM
I gotta admit this is very interesting.
/sub'd
Reply 0
Jul 14, 2010 | 12:03 PM
what is the sampling rate of this unit with the ME 2.8.
Is it true that the more parameters you select the slower the sampling rate becomes?
Reply 0
Jul 14, 2010 | 03:29 PM
Quote: https://mbworld.org/forums/4157670-post10.html
so this is just a way to upload info into the ecu, but not alter it. i will look further into this matter with the engineers who hacked the evos ecu. there is a way to connect to the ecu via the obd2 port and alter your own maps for a very minimal cost
Reply 0
Subscribe
Currently Active Users (1)
