C63 AMG (W204) 2008 - 2015
AMG door pins - Ebay alternative.
Old 10-18-2010, 04:56 PM
HBC350's Avatar
'18 C63A Cabriolet
On their way. Thanks. Great find.
And I finally just installed black plastic caps to cover the rusty lug bolts since it seems there are no cost-effective black lugs that will do the job on the market right now. They look great. $20.
Old 10-18-2010, 07:52 PM
cbcharlie's Avatar
2009 C300 4Matic Sport P2/MM/Steel Gray
I ordered the chrome ones, hope the rears aren't to much trouble.
Old 10-18-2010, 09:09 PM
VCA_AMG's Avatar
'15 E63S wagon
The metal ones look very trick, much better than the OEM chrome-plated plastic.
Old 10-18-2010, 09:20 PM
techt0nix's Avatar
Silver C63 2009
Damn. I wish you posted this 3 days earlier. I just bought the AMG doorpins from getmercedesparts.com for $210.55 on Friday, 10/15/10. I just lost $160. FML
Old 10-19-2010, 08:55 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Great find Petro... gotta love this forum... great to have members like you, superbubblicity & harrower.
Old 10-19-2010, 09:20 AM
emericr's Avatar
2021 Porsche TTS
Is there a DYI out there to install the rear pins or do people go to an MB shop to get them installed?
I assume the front is just a matter of unscrewing the OEM and screwing back the new ones.
Old 10-19-2010, 09:22 AM
  #32
Roswell's Avatar
Members here said you just need to pop them up & push down the new ones... so it should be an easy install.
Old 10-19-2010, 11:40 AM
  #33
Philipangoo's Avatar
Tesla 3, E30, CayenneS
I just noticed the shipping time is 21-30 days!!! I remember seeing 15-20 days for the Idrive cover but it only took like 5 days to arrive.
Old 10-19-2010, 12:11 PM
  #34
PetroC63's Avatar
2012 CTS-V
I was told by the MB tech the fronts screw on and the rears have
a two part procedure and need to be popped on twice.
For the rears, after the plastic pins are removed make sure the
doors are unlocked and push the new pin on until you hear a pop.
Lock doors and push down on pin again until you hear a second pop,
this will seat the pin on the ball joint.
Old 10-19-2010, 12:13 PM
  #35
emericr's Avatar
2021 Porsche TTS
Thanks for the update but how do you take out the panel. I do not want to be breaking expensive tabs.
Old 10-19-2010, 12:14 PM
  #36
PetroC63's Avatar
2012 CTS-V
Just helping out fellow enthusiasts.
Old 10-19-2010, 12:17 PM
  #37
PetroC63's Avatar
2012 CTS-V
Panels do not need to be removed. Pins just pull off. The fronts
have to be twisted and pulled and the rears are just pulled straight
up.
All my info is from the service tech. I had my car in for an oil change
and had them do the pins for me.
Old 10-19-2010, 12:20 PM
  #38
PetroC63's Avatar
2012 CTS-V
I received mine in a week. I think their shipping estimates are just
on the safe side.
Old 10-19-2010, 12:46 PM
  #39
emericr's Avatar
2021 Porsche TTS
Cool. Thanks Petro
Old 10-19-2010, 01:52 PM
  #40
derspi's Avatar
2009 C63
PetroC55, do these pins protrude less than the stock ones? If these pins are shorter and result in me getting stabbed less in the arm every time I go through a drive through then they are well worth it!
Great find, thanks!
Old 10-19-2010, 02:01 PM
  #41
PetroC63's Avatar
2012 CTS-V
Great find, thanks!
Yes, the fronts sit flush but the rears stick out about a 1/4"
Your welcome.
Old 10-19-2010, 02:14 PM
  #42
osubeaver's Avatar
2016 C450 (on order)
Could you post pictures of the final install? Does the set come with the base ring surround as well as the pin? Does the base ring mount in correctly? I only ask as I've previously purchased two similar sets from Ebay only to find out they do not fit- they had to be returned. Real picture would help put my doubt at ease. Thanks.
Old 10-19-2010, 02:37 PM
  #43
PetroC63's Avatar
2012 CTS-V
There is no base ring included or needed. It shows a picture
of the base ring on the box but they are not needed on w204.
I'll try and post pictures later today.
Old 10-19-2010, 06:23 PM
  #44
PetroC63's Avatar
2012 CTS-V
Here are some pics as promised.
First picture is of the pins and the box they came in.
Second picture is of front driver side with door unlocked.
Third picture is front driver side with door locked.
Attached Thumbnails AMG door pins - Ebay alternative.-photo003.jpg   AMG door pins - Ebay alternative.-dscn1040.jpg   AMG door pins - Ebay alternative.-dscn1041.jpg
Old 10-19-2010, 06:33 PM
  #45
derspi's Avatar
2009 C63
These look about perfect. Appreciate all your efforts - thanks again!
Old 10-19-2010, 06:34 PM
  #46
PetroC63's Avatar
2012 CTS-V
No problem
Glad to help.
Old 10-19-2010, 09:04 PM
  #47
iatacs19's Avatar
axe muderer with headlights
That looks great!
Any pics of the rear ones?
Old 10-19-2010, 10:06 PM
  #48
KCviper's Avatar
13 Lamborghini SL, 20 Porsche 911 (sold), 09 C63(sold), Vipers (sold)
I want to do this. Could someone post a step by step if you have the time please? Thanks!!
Old 10-19-2010, 10:59 PM
  #49
techt0nix's Avatar
Silver C63 2009
Took a quote from this thread:
https://mbworld.org/forums/c63-amg-w...ck-pins-3.html
Originally Posted by bhamg
I've installed two sets of these pins now. The fronts are easy to screw down and to align the logo to your preference. To install the rear pins is even easier. In the unlock position align the logo and push down on the new pin. You will feel a slight "pop." Lock the door and push down on the pin once more...you will feel a second "pop" and the pin is now seated...it's that simple. Do not glue it, it's absolutely not necessary!
Old 10-20-2010, 12:17 AM
  #50
Roswell's Avatar
Great infos everyone... can't wait to receive mine!!
Quick Reply: AMG door pins - Ebay alternative.
