SUPERCHARGED m156, 63 amg !!!!
Why would we be talking about something more than a base kit? Weren’t we just talking about all the problems the trans will have with the additional torque?
Many piggybacks, and a few ECU flashes do and did exist for the DME. Additionally, DI does have its disadvantages. Are you familiar with the # of BMW 135/335/535 high pressure fuel pump failures? Not to mention their issues with carbon buildup? Injectors/plugs? These issues plagued not just modified cars running higher boost but completely stock cars that never were flashed or ran a piggyback.
My 335 (brand new 2008) sat at the dealership for 4 weeks because they couldn't determine what was causing the long cranks/stalling/rough idle.
Carbon buildup, changing injectors/plugs, low pressure fuel sensor, a DME upgrade and finally after swapping the HPFP the problem went away. The car was almost lemoned by BMWNA except for the fact that the car had 28k miles on it. In VA the law states 24 mos or 25k miles if I recall correctly and I was just over that.
DI is certainly not a cure all as you've pointed out, even Porsche had sooting issues prior, but in this department it gives BMW owners a leg up, as do the factory forged pistons.
I've posted the same comments about this being a base blower kit and that that's all the size of this supercharger is adequate for so we agree there.
Point being for someone looking to go ***** out, after swapping internals, doing fuel system, figuring out trans/converter, they are still left with the need to upgrade to a larger supercharger.
They could have just used a 2.8L spun it slower and had lower discharge temps even on the base kit though.
No comparison to a 1.9L TVS in the CTS-V, you can turn the boost up past 15psi easily with an otherwise stock car. Not so with a M156 (I know it's a high C/R NA motor I've posted that 20x in this thread alone
). We are talking about problems facing any owner that wants to apply FI to a m156 in both base and advanced platforms, or at least I thought we were. This includes the trans, converter, and a whole bunch of additional items if someone wants to push it harder.
I've actually addressed this multiple times already, nitrous is not the same as a positive displacement blower. You only stress the bottom end with spray when you hit the button which is rarely if ever vs getting into boost with a small twin screw which operates any time the car is moving.
When was the last time someone put the stress of a 2.3L TS on a 11.3:1 PFI engine with cast pistons? Hasn't been done, as it's far beyond what any other production motor with the same specs and components has endured.
Based on what? Again you've never seen a motor with this much compression and cast pistons get blown.
Our chambers are significantly better than any chevy head, all 4 valves due to central plug location are significantly less prone to detonation than 2 valves by design as well.
Ok, say this kit makes 80rwhp and 100rwtq with tuning on 6psi (just throwing it out there), that's still enough to toast the trans unless they modify software and hardware. Turning it up past that point requires new internals, etc etc $$$$.
If we had DI or piezo elect inj. and forged pistons there would be less of an issue with the bottom end, however we do not.
Redesigned billet stator fins have already been tested and failed with 722.9 converters.
It's not just line pressure but clutch pack application rate, volume fill, etc that need to be modified to accomodate the output. So again even if someone hacks the TCU software, who has a RAM map? So no one would even know what tables or values to change.
There are so many factual issues that need to be worked through to make this possible, as others that have tried and given up have said, it's just not cost effective and the trans/converter make it impossible at this point.
The LS7 specs are close to the M156 with 11:1 compression ratio and cast pistons, and it handles low boots FI very well.
As far the M156 having durability issues with low boost FI, your argument should be considers null and void. Now problems that may occur with the transmission, that is an entirely different story.
Did I say boost at idle? No. Even at 1/2 throttle this blower will be making boost, and of course at WOT. The largest difference being that nitrous isn't sprayed all the time a blower is engaged, not even close.
Boost is a measurement of backpressure or restriction, boost is a measurement, it doesn't physically do anything. Engine 1 can have 20psi, while engine 2 has 40psi, however both can be moving the same mass of air through the motor. Boost means nothing in reality except when measured on the same motor.
It's the IAT temps created by a blower combined with high static compression in a PFI application that are the issues we're dealing with.
Again, driveline components are measured in TQ and rpm not HP. HP is simply a mathematical function of torque. If the torque exceeds the mechanical strength of the parts it will fail.
Notice I had to correct every statement you just posted?
Also most LS7 blowers are centrifugals not Pos displacement, huge difference in the amount of stress they place on the internals and drivelilne, HUGE.
Please read my posts, I mean actually read them. Have you had a M156 apart, have you seen the ringlands, ring package? Then don't comment. CTS-V pistons may be cast but they were still made for boost, M156s were not.
I didn't say low boost was going to hurt the motor, I said it's not setup for boost period. If going higher XXX was going to need to be replaced and you agree.
Ultimately however this stock bottom end will only take so much abuse from a pos displacement blower.
Hand built means nothing, are the pistons cast by hand, rods, rod bolts? Of course not, who cares if it's screwed together by man or machine that has zero bearing on this discussion.
I know they weren't planning (supposedly) on releasing any info yet, but since the ship has sailed anyway you'd think they'd be on the ball about it.
Anyway, all we can do is be patient and wait.
You are forgetting about the trans, and converter issues. Also as far as very well goes, I don't think so. You have very little gasket seating area between bores on an LS7 block, which is exactly why Chevy switched to the LS9 6.2L for the ZR1 and CTS-V and soon to be Z28. Aside from that bores move under boost (in higher boost apps), causing ring issues and the poor gasket sealing can cause coolant to leak into the cylinder causing hydralock.
I think you need to do a lot more homework before making a post like this, right back at you with the garbage comment.
In dynamic system, there is much more to mechanical part failure than just torque. Velocity (speed) of the rotating massing is very important as it relates to dynamic force. If engines were static torque would be all that mattered. This is why engine and some drive train components are rated in horsepower typically (specially in an industrial setting). However many drive line components(trans, diff, and axel) are ratted in torque. This is for a few reason. 1 there are a lower number of dynamic forces involved (typically only one in one direction i.e. rotational) 2 They typically have a speed/rpm limit ratting (this in essence is a HP ratting). Think about it. You could have a car with a transmission that has a torque rating higher than the torque output of the engine, but if you take the engine up to the redline at a standstill and drop the clutch in firs gear, you can definitely break the trans mission. Why is this? The short answer is dynamic forces vastly increase stresses. If you would like, I can recommend some engineering textbooks to read up on.
I NEVER said the trans would not be a problem. I specifically stated that it may very well be. They moved away from the LS7 for ease of manufacturing reasons, and they are moving to smaller displacement engines across the board. The next LS will be 5.5L. None of the low boot LS7s I have seen have suffer this problem. There are many high boost LS7s with forge internals that have had not had any problems with block rigidity. Also, the M156 has a closed deck block, so this should be much less of a concern.
The Magnusson TVS positive displacement blower has been successful so far on the LS7.
I think I have a done a decent job on my homework. The weakest link in the M156 is the cast pistons, and cast piston seem to hold up decently in low to mild boost applications. Other N/A MB engine hold up well to aftermarket FI setups. Are we to believe the AMG engineers designed the M156 with lower safety factors than the MB engineers do for there more pedestrian engines?
Notice how I just corrected every statement you posted? Man, we must be idiots if we are both being corrected all the time.
It's called mechanical torque multiplication and can occur in the trans, diff, clutch, etc. LOL, no thanks on the books. The most talented engine builders I've ever met had nothing higher than a high school diploma, experience is King in this business, and half the computerized engineering/design programs for cylinder heads will tell you the wrong places to port a head. There's more to it than text books, always has been, always will be.
Seen it before in big bore modular Fords as well, same issues, same problems. It's not a one off ordeal.
I know the CI of the next LS motor, it has no bearing on this discussion whatsoever.
LS7 is a poor comparison to the M156 because the block of the M156 was designed for FI from the get go, LS7 not at all. No question the M156 block can take all the boost in the world, the OEM pistons, rods, rod bolts, rings, not so much.
The M156 shares no parts with any other MB motor ever, so your comment is really irrelevant based on that alone.
Again as I've told you multiple times, I don't expect the pistons to become an issue until higher boost, which AGAIN means rebuilding the bottom end, fuel system, trans/converter solution, etc the whole shebang. Why are you still trying to argue this? No one is debating it.
edit: can you please post in standard font and sizing?
Anyhow. you need to stop comparing lsx motor to MB motor, they vary alot and should not be grouped together
No, they moved away from the LS7 for the reasons I stated above with boost. More gasket sealing area and meat around bores.
Define successful? It's the stock blower on the LS9, sure it can make 700rw on race gas in that application but 2.8L TS's can make upwards of 800rw on pump gas. 2.3L is small for a 6.2L engine for anything other than low boost or an otherwise stock motor. How many chevy or ford guys do you see swapping to a standard size blower to get more power? Take a GT500 for instance (4v, PFI, closed deck block much better comparison than a LS7) swap on a 2.8L Mammoth KB and bam 750rw without any other changes save a tune. Never happen in a million years with a 2.3L.
You've admittedly never seen a M156 cast piston, or the rest of the inside of a M156 so please explain how you deduced that? I'll ask again, what's the ringland thickness of a M156 piston?
No I didn't notice that at all sorry. You need to expand your horizons beyond Chevy's.
Are you going t sit there and tell me, the AMG designed the pistons of the M156 to a lower stander than other cast pistons out there in MB engines. The MB engines and the M156 do not share anything in common other than they are both under the MB company and therefore, thinking logically and a German would do, would both design to the same minimum standard. If anything the AMG motor would designed to a higher standard. I don’t care if you have seen it. The fact that you have looked at it doesn’t mean you have done a stress test or analysis on it. From what you have posted here, I don’t believe you would even understand those processes.
Define successful? It is the same thing I have been talking about the whole time. A low boost bolt-on application for NA engine. 600 RWHP on a very, very mild and streetable LS7 setup is successful in my mind. I think many here would like 600RWHP with bolt-on equipment.
You really think you are smarter than you are. Good, you have yourself fooled. I am sure you have been playing around with engines for a long time right? You must have picked up quite a bit of experience building, but you seem to have no clue on the fundamental principles of engineering, design, and theory that are used to conceive and build the thing you have been tinkering with your whole life. There is always more to it than text books, but you will never really fully understand the subject unless you start with the text books and not the other way around. To say that text books are irrelevant is to stay 1 that you cannot learn from those who came before you and 2 just wholeheartedly stupid.
So you are saying because the two engines are dissimilar would should never compare the two to draw logical conclusions? What other applications are out there that we have examples of that we should compare it to? Should we just not discuss or compare at all. I thought this forum was all about technical discussion. If you have a better comparison or point to make, I am all ears.
I was making a point to RS since they do not seem to get the difference. Your examples should more or less compare a 4v DOHC motor like the cobra instead of a 2v ohv valve motor. You can compare, to each their own.
Its fun to read though.. I personally wanna hear more about torque converters and how they work. They have always been a mystery to me.
Btw, I was just trying to say, MBWorld might actually be better than textbooks. Kind of a joke, but in some ways it's much better. Love the technical discussion. Great input in this thread.
It was intended to be TT'd by AMG, but not this generation of M156.
