C63 AMG (W204) 2008 - 2015
Wheel Align specs for lowered C63
Old Jan 9, 2011 | 03:22 PM
AMG-010's Avatar
2017 AMG C43
Does anyone know the wheel alignment specs for C63 when car is lowered on coilovers? There are very few people in Australia that have lowered C63's. Apparently Mercedes have shims for adjustment.
I am not to concerned on handling as i don't drive the car that hard, I just want maximum tyre wear on my new 20's.
Is the rear adjustable?
Old Jan 9, 2011 | 03:24 PM
GHAZAN's Avatar
MBUSA
rear only toe is adjustable, you'll need camber bolts if you want to adjust
front camber and toe adjustable as far as i recall
Old Jan 9, 2011 | 03:26 PM
AMG-010's Avatar
2017 AMG C43
Where do I buy camber bolts from ?
Old Jan 9, 2011 | 03:28 PM
GHAZAN's Avatar
MBUSA
i might of been mistaken...and toe is just adjustable.
camber bolts 000-333-09-71 you'll need 2 sets for front and 2 for rear, try your dealer
someone else should confirm this tho
Old Jan 9, 2011 | 03:37 PM
AMG-010's Avatar
2017 AMG C43
Thank you, I will check with dealer when alignment is done.
Are they the shims? If they are installed does it allow for full adjustment front and rear?
Old Jan 10, 2011 | 05:03 PM
Palladin's Avatar
2009 C63 with Eurocharged tune and charcoal delete
Sir, if you get a chance please ask the dealer for the stock C63 wheel alignment specs and post them up. Looking for front and rear camber and toe specs and acceptable plus/minus ranges. The dealers keep this info secret like it's paramount to national security. Always been curious what the benchmark specs and ranges are for our cars. Thanks.
Old Jan 12, 2011 | 12:31 AM
exdes's Avatar
2015 C300 4matic
this is what I had after I got my alignment done. I can't find the spec sheet so not sure what the acceptable ranges were..
https://mbworld.org/forums/c63-amg-w...alignment.html
Old Jan 12, 2011 | 10:10 AM
Palladin's Avatar
Thanks for the info. Your specs are pretty much exactly what I ended up with after my last visit to the dealer and install of new tires. As Kojo911 commented on the original thread that is a lot of toe-in at the rear and that is the major factor in our rapid rear tire wear. I was just curious if the specs the dealer gave me were consistent with other results. Guess I just need to keep feeding this little monster rear tires.
